08-02-2022, 02:09 PM
#921
1971 21' Globetrotter
Arvada
A lot of time after cleaning up corrosion you can alodine, acid etch and then prime, it's not really necessary on an Airstream especially if you are going to shoot an assembly back together wet. A faying surface seal is just sealing between two mating surfaces. Filing or polishing the edges is a way to prevent corrosion, I use a blue roloc surface conditioning disc as it is faster. An edge does not need to be separately sealed after a wet install, you should have some sealant extrude out that will require cleanup anyway.
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
08-02-2022, 03:42 PM
#922
Arvada
Fabed up the insides of the fridge access inlet door, latch to go. Hopefully I can shoot in tomorrow.
08-03-2022, 03:28 PM
#923
Arvada
Latch installed. My brother is coming over tomorrow morning to buck the rivets.
08-03-2022, 06:50 PM
#924
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I bet your brother has a lot of experience behind a bucking bar in your Globetrotter. You guys should invent a bucking bar holder that can be adjusted to fit tight over the hole, or holes that are to receive a solid rivet. The device would provide an adjustable amount of push on the bar so the rivet would get squished in place.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
08-03-2022, 08:27 PM
#925
Arvada
It's called a right hand
08-04-2022, 01:21 PM
#926
1967 17' Caravel
Oak Creek
Originally Posted by Aerowood
Dingo Girl, I see you are from Oak Creek, between there and Yampa, gateway to the north side of the Flat Tops, one of our favorite places to camp. I would like to hear of some additional places in the area to boondock.
PM'd you.
08-04-2022, 06:42 PM
#927
1986 34' Limited
1975 27' Overlander
Conifer
You are right if you have access with your hand. Or is your "right hand man" your brother?
Why don't you invent a blind rivet that is just as strong as a bucked rivet, and doesn't leak. Olympic tri fold rivets aren't the answer. Think of all the manpower Airstream would save. And all those folks building experimental aircraft in their garages. You would make a fortune. Get Aerowood rivets, they are the best.
David
08-10-2022, 04:25 PM
#928
Arvada
Well David there is a blind rivets that is stronger then the solids Airstream uses, it's called a CherryMax but it would be cost prohibited to use them.
Progress pictures are of the installed fridge access door and the right side lower skin.
FWIW, if I ever decide to reskin the interior of another Airstream, I give permission to cut me deep and bleed me out, it's not really hard to do but it is just taking FOREVER!!!
08-11-2022, 07:01 AM
#929
1972 25' Tradewind
fort lauderdale
Kip,
Maybe I missed it in a previous comment, but what kind of rivets are you using to install your interior skin?
Mine was originally installed with pop rivets but yours look a bit larger.
thanks
eric
08-11-2022, 08:53 AM
#930
Arvada
The panels are all held on with 10-32 bolts with nutplates riveted to the frames and stringers. They are all placed to mount interior components, like the walls, galley, water lines etc. For the hardware that is exposed I am using hex drive washer head 10-32 stainless steel screws. I will be using some pop rivets on the panel seams but absolutely no sheet metal screws throughout.
08-11-2022, 11:59 AM
#931
1972 31' Sovereign
Lexington
"What Kip has put together, let no man (or road) tear asunder..."
Kay
08-12-2022, 04:40 PM
#932
Arvada
Progress Report today, I fabricated and installed mounts for the fridge exhaust fans. I cracked one of the pieces while stretching it, but it won't matter. I briefly though about making another but it just doesn't matter. It was the second radius that I stretched and I tried to cut a corner. The first radius I sanded the stretcher marks out and annealed it halfway there, I didn't on the second. I did on the 3rd and 4th radius. Oh well just me and the forum know I cracked it. Oh by the way David, I used CherryMax blind rivets to shoot the pieces on. I couldn't find my long #4 offset rivet set to shoot solids. I must have loaned it out at sometime and never got it back.
08-12-2022, 04:45 PM
#933
2013 23' FB International
aldinga beach
, south australia
FWIW, if I ever decide to reskin the interior of another Airstream, I give permission to cut me deep and bleed me out, it's not really hard to do but it is just taking FOREVER!!! Attachment 420766Attachment 420767
very nice work mate ...carry on
08-12-2022, 06:07 PM
#934
Arvada
No worries, I spent quite a bit of time in Hobart Tas a few years ago flying over the ice with our GV
08-12-2022, 06:23 PM
#935
1986 34' Limited
1975 27' Overlander
Conifer
Maybe Zep knows where it is. Or maybe it will show up in the kitchen utility drawer.
David
08-13-2022, 11:06 AM
#936
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
If I knew what it was, I'd look for it ...
08-13-2022, 11:52 AM
#937
Arvada
I'm guessing it was one of my previous coworkers
08-13-2022, 06:00 PM
#938
Sunset Beach
, North Carolina
Did you use a torch or a heat gun to anneal the radii?
Mike
08-13-2022, 08:01 PM
#939
Arvada
Heat gun, don't know exactly how well it worked, but it worked in my mind. Stretching is harder to do then shrinking
08-14-2022, 05:56 AM
#940
Sunset Beach
, North Carolina
missing items
Originally Posted by dbj216
.... maybe it will show up in the kitchen utility drawer.
David
After thinking about David's response, I recall all of the times I found my TV remote in the refrigerator
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Bauxter
