05-31-2022, 08:43 PM
#841
1971 21' Globetrotter
Arvada
Originally Posted by dbj216
Thank you Aerowood for your description of how you make and install the domed aluminum segments. Kinda like trying to make skins for a football. It sounds way too complicated for me. Heck, I have trouble cutting a 2x4 to length.
I got an idea. You could just design and build a thermoform tool for ABS plastic and make it as one piece.
David
Maybe on the 8th one
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
06-01-2022, 05:50 AM
#842
Sunset Beach
, North Carolina
metal interior end caps
Kip, Did you ever build a roller tool for the small flange on the end cap panels, like demo'd at the New Mexico workshop, and if so are any for sale? I ordered 12 pre-cut flat panels from a wholesaler, and am wondering if I really need to put that small bend in the panel. There is a fellow on YT that shows how he installed the panels without the bend, and it seems to look ok.
Thoughts?
thanks
Mike
06-01-2022, 06:48 AM
#843
Arvada
No Mike I did not. They are easily made with a couple of bearing. They are also available commercially where ever fine aircraft tools are sold. Zep was at my house the other day and stated he had found some. Maybe he will respond. Zep??
I did not roll a flange on my interior panels
06-01-2022, 04:33 PM
#844
Arvada
06-01-2022, 08:22 PM
#845
Sunset Beach
, North Carolina
Thanks a bunch!
06-02-2022, 08:03 AM
#846
Arvada
06-03-2022, 07:53 AM
#847
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
06-03-2022, 02:10 PM
#848
Arvada
Rear segmented section is done, now to start on the lower panels.
06-11-2022, 11:37 AM
#849
Arvada
CAD design for the rear lower panels
06-11-2022, 12:04 PM
#850
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Cardboard Assisted Design, works great!
Hittenstiehl
06-12-2022, 08:18 AM
#851
1972 31' Sovereign
Lexington
Good for furniture too when you're planning the interior!
Kay
06-12-2022, 03:30 PM
#852
Arvada
Right rear lower done, also running lots of wire
06-13-2022, 06:41 AM
#853
1972 25' Tradewind
fort lauderdale
Kip,
Have you "treated" or modified the surface of the interior aluminum you've installed? It may just be the picture but it looks matt or sanded.
Looks great!
thanks
Eric
06-13-2022, 07:11 AM
#854
Arvada
It's sanded because my wife told me I wanted to paint the interior aluminum white.
06-13-2022, 08:03 AM
#855
1966 22' Safari
Fredericksburg
Will you be using Zolatone or something local that’s more available? We used Kilz Adhesive for a primer. It really sticks.
06-13-2022, 08:58 AM
#856
Arvada
I will be using an aluminum acid prep followed with alodine. Epoxy primer next followed up with polyurethane white. I will most likely spray the first coat normally and then turn the atomizing pressure down on the gun and up on the pressure pot. This will create a textured white surface.
06-13-2022, 09:17 AM
#857
1958 26' Overlander
Battle Ground
What is your reasoning for wanting a textured surface versus a smooth surface that's easier to clean? I plan on using the same materials on my roof if it ever stops raining.
06-13-2022, 09:43 AM
#858
Arvada
Right now it's esthetics, although it has not been approved by the higher authority.
06-13-2022, 07:15 PM
#859
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Gotta have all the necessary approvals or you will go on report for insubordination.
I painted my 69 Globetrotter interior a slightly off white. I used paint designed for exterior aluminum windows. I was guessing it could take the "coefficient of thermo-expansion" of the aluminum between summer hot and winter cold. Mine is textured as I painted right over the vinyl. My skills are nowhere close to yours.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
06-13-2022, 07:20 PM
#860
Arvada
Don't cut yourself short David, you do nice work. Stop by sometime when you come down from the mountains.
