Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1970 - 1978 Globetrotter
Old 04-15-2022, 08:47 AM   #801
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by steinVT View Post
That looks like it would be right at home on an aircraft. Beautiful work.
Couple of questions:
  • What thickness and material did you use for the door and also the interior box?
  • How are you dealing with water penetration? Sealing or maybe drain path?
Thanks - Mark
The whole thing is made from .063 6061-T6 except one .032 shim. Need the shim to increase the skin cutout thickness for the .063 door to set flush on the doubler. The whole assembly is shot together wet with Sikaflex 221 so the cavity is completely sealed off from the inside of the trailer. The extruded hinge is the drain. I've done this type of access panels on aircraft.
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
Old 04-15-2022, 12:50 PM   #802
Aerowood's Avatar
Arvada , Colorado
Final configuration of water service panel. I need to clean off my bench. Click image for larger version
ID:	414473Click image for larger version
ID:	414474Click image for larger version
Old 04-16-2022, 12:46 PM   #803
Aerowood's Avatar
Arvada , Colorado
InstalledClick image for larger version
Old 05-07-2022, 05:36 PM   #804
Aerowood's Avatar
Arvada , Colorado
Well I'm going to have to eat some crow here. Way back in this thread somewhere, I stated my hatred of pop rivets. Well today is the day I started using them. I started the forward interior dome, and I just couldn't get my old arthritic hands in between the inner and outer panels to install solid rivets. Anyway below is where I'm at. Heat finally drove me into the house. 90° outside now and inside the trailer is a lot hotter. I'm thinking the AC install is moving up the to do list. Click image for larger version
Old 05-08-2022, 05:47 AM   #805
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Having eaten more than one crow, I have some excellent recipes and I recommend pino grigio to go with it.
BTW, that one row of pop rivets in my dome don't seem all that visible and I couldn't have installed it in one piece, no way.
Zep
Zep@Charmedquark.net
Old 05-08-2022, 09:10 AM   #806
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Uh, Kip, you have no insulation?
Chris just installed an aluminum headliner that we got from Colin Hyde in our trailer, and used over 400 pop rivets. He could never have put it together before installation (as the instructions said). He installed it in place. He'll post pics in our Little Girl Refurb thread today.
Kay
Old 05-08-2022, 09:46 AM   #807
Aerowood's Avatar
Arvada , Colorado
Excellent choice on the wine Zep.
Chris and Kay, insulation going in as I go. Riveted section has Havewool insulation already installed.
I have to take down what I have already installed though. I forgot to install the speaker wires. Stupid mistake, I got in a hurry.
Old 05-08-2022, 12:12 PM   #808
Minno's Avatar
1972 31' Sovereign
Well, I had to take interior skins off a couple of times during our refurb because I forgot wires... That's easier than rebuilding a plywood skinned wall!
Chris
Old 05-12-2022, 06:05 PM   #809
Aerowood's Avatar
Arvada , Colorado
Couple more days to go yetClick image for larger version
Old 05-12-2022, 07:22 PM   #810
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Eat an elephant one bite at a time.
Build an interior aluminum end cap one rivet at a time.
Making all those segments fit must be a rear bear.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 05-12-2022, 08:21 PM   #811
Aerowood's Avatar
Arvada , Colorado
It's not hard, just time consuming.
Old 05-12-2022, 08:51 PM   #812
1979 31' Excella 500
Desert , California
Aerowood, I am just discovering your thread and I love what I am seeing. Quick question what are these flush latches that you are using on your water inlet door? Any reference?
My 79 Excella 500 31ft rebuild:
https://www.airforums.com/forums/f20...ld-224367.html
Sylvain is offline   Reply With Quote
Old 05-13-2022, 06:30 AM   #813
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
I saw that a lot of experimental /home made plane builders were using a particular Sherwin Williams spackle in the pop rivet head holes; it seemed like an awful idea but for my project at least has worked flawlessly. (I did use a hypodermic syringe though).
truckasaurus is offline   Reply With Quote
Old 05-13-2022, 09:36 AM   #814
Aerowood's Avatar
Arvada , Colorado
The latches are made by Hartwell and are called a Trigger Lock. I believe the base p/n is H-5000-2, there is also thickness numbers for the thickness of the panel it's to be installed on. In my case the latch if for a .072 panel and my door is .063, close enough.
Just do a Goggle search for "Hartwell Latch" several should show up. I hope this helps.
Old 05-13-2022, 09:37 AM   #815
Aerowood's Avatar
Arvada , Colorado
That's a great idea, I had not though of that.
Old 05-13-2022, 08:41 PM   #816
Desert , California
Thanks! I will look into that. They look really nice
Old 05-13-2022, 08:50 PM   #817
Desert , California
Do you have a specific supplier for these?
Old 05-14-2022, 07:41 AM   #818
Aerowood's Avatar
Arvada , Colorado
I don't have a specific supplier, I've been collecting these for years including removing them from junked panels and such. I really have a variety pack of different styles and sizes. I scored big time a few years ago when I found a box of them at a military surplus store in California, I think it was Mojave or could have been Palmdale. I can't resist a surplus store regardless of wherever I am at the time.
Old 05-14-2022, 05:04 PM   #819
Aerowood's Avatar
Arvada , Colorado
Fwd interior segmented dome installed. Still have to trim around wing windowsClick image for larger version
Old 05-14-2022, 06:00 PM   #820
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You did it. Another Globetrotter build milestone. A lot more robust than the thermo-formed plastic one. It is interesting to see in the photo how the reflection of the trailer interior makes the new aluminum segment end cap look convex out instead of the physical concave in.
David
Full Monte or not? I get what I deserve! Chlyman General Repair Forum 12 10-04-2011 07:48 PM
Full Time living in an Airstreaam bmccomb On The Road... 0 08-28-2011 01:59 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 06:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 10:59 AM
64 globetrotter front sofa bed Airstream76 1960 - 1964 Globetrotter 26 02-11-2011 03:42 PM
