04-05-2022, 03:56 PM
#781
1971 21' Globetrotter
Arvada
04-05-2022, 06:53 PM
#782
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hello Aerowood: Nice grab handle, it looks like an Airstream original. I noticed the door lockset. I figure your trailer came with the KT lockset, which are prone to trouble when they wear out. Did you change from a KT to something else. If so, what is the else. I don't see any patches around your lock set, so it too looks original.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
04-05-2022, 08:41 PM
#783
Arvada
The grab handle is a marine unit made from 316 stainless steel, I ordered it through West Marine. I'd have to look up the P/N to the door latch but it's just a standard RV unit, I think I paid 42 dollars for it. I reskinned the door as it was a train wreck. Cast frame broken in several places. Details are way back in this thread somewhere.
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
04-06-2022, 07:00 PM
#784
1986 34' Limited
1975 27' Overlander
Conifer
Thanks Aerowood. Marine parts are almost as good as aircraft parts. Nice to know the 71 trailers still had the cast aluminum door frame. My 75 Overlander does not. I bet the 1972 trailers don't have a cast door frame either, although I don't know when they changed. The cast frames require a lockset with a 3 1/2" set back like the old Bargman lock set had. It's a long lock bolt. My son's 69 Globetrotter had a Bargman lockset. The KT locks don't have such a long set back. Maybe you had to modify the cast door frame to get that standard RV lock to fit. I installed a similar lockset made by Korhee on my Overlander. It works good and comes with a deadbolt built in.
David
04-07-2022, 07:32 AM
#785
1972 31' Sovereign
Lexington
Our '72 has a cast aluminum door frame, and it's cracked. Chris is unsure how to fix it at this point....
Kay
04-07-2022, 02:40 PM
#786
Arvada
Mine was cracked in multiple places, that was the reason I deskinned the door. I had it welded up. While it was bare was when I removed the KT latch and replaced.
Kay, where is yours cracked at?
04-08-2022, 07:34 AM
#787
1972 25' Tradewind
fort lauderdale
door hinge
04-08-2022, 08:58 AM
#788
1972 31' Sovereign
Lexington
Hi Kip,
Here's a pic of our door frame. It was drilled out because a previous owner installed a regular house exterior door latch. We replaced that with a new KT lock back in 2009, but still have this hole and crack that I would like to get fixed. I was thinking about using a brazing kit from Menards or Home Depot to fill the hole and crack, but have not had the courage to try it yet.
Any thoughts? Should we remove it and bring to a welding shop that can weld cast aluminum?
Thanks!
Chris (and Kay)
04-13-2022, 05:44 PM
#790
Arvada
Chris/Kay
I had mine welded up, although I did put in a reinforcement aluminum angle over the top where my new latch plunger came out. My welder friend said that the aluminum cast was very porous.
04-13-2022, 05:52 PM
#791
Arvada
About done with the water service panel. One more latch to cutout for. This type of latch is very labor intensive to install. Chain drill then filings. Hopefully I can cut out the trailer skin tomorrow and drill to final size. I still have to install the water service thingys too.
04-14-2022, 06:01 AM
#792
Sunset Beach
, North Carolina
water door
I think the word awesome is appropriate...now we all need to know, cost, lead time, options, and aprox shipping costs
A bigger version would be a great replacement for those dang outside access doors, with the wonky factory overhead hinges
I think you could be busy making these things for a long time..forget about retirement
04-14-2022, 08:11 AM
#793
Arvada
Well....I can be bought, but I ain't cheap. I do plan on making 2 more similar ones, one for the fridge air intake, and a rear storage compartment. That compartment will be after the rest of the trailer is done though. I've got about 16 hours in this install so far, several more yet to go.
04-14-2022, 03:17 PM
#794
1967 17' Caravel
Oak Creek
if i weren't a human, pretty sure I'd be a raccoon. i adore shiny stuff & the grab handle is very attractive
thanks for sharing!
04-14-2022, 04:35 PM
#795
Arvada
Thanks DG
Almost ready to shoot the water service panel in. I still have to make the gravity flow/vent. Parts just came in from McMaster Carr this afternoon. A metal lath would be helpful but alas I don't have one.
04-14-2022, 06:22 PM
#796
1986 34' Limited
1975 27' Overlander
Conifer
That is quite a compartment. Does it service the fresh water tank, or is it a fire department connection for your sprinkler system?
Don't laugh, but here is a photo of my city water inlet connection that I purchased for about $50. It is solid plastic. It has a built in pressure regulator and check valve. It squeals like a castrated pig when I blow out the trailer's plumbing. Otherwise it works well enough. It is mounted below the shore power inlet.
David
04-14-2022, 06:37 PM
#797
Arvada
Fwd fitting is the pressurized tank fill, the aft is the city water connection. The middle one (making tomorrow) is going to be the water tank vent/bucket fill port
04-14-2022, 11:21 PM
#798
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Fwd fitting is the pressurized tank fill, the aft is the city water connection. The middle one (making tomorrow) is going to be the water tank vent/bucket fill port...
What? No outside shower?
04-15-2022, 04:53 AM
#799
1956 22' Safari
1962 28' Ambassador
Williston
, Vermont
That looks like it would be right at home on an aircraft. Beautiful work.
Couple of questions: - What thickness and material did you use for the door and also the interior box?
- How are you dealing with water penetration? Sealing or maybe drain path?
Thanks - Mark
04-15-2022, 08:34 AM
#800
Arvada
I have a bucket for that, or I just wait for it to rain.
