Old 08-12-2008, 05:44 PM   #253
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I took the day off today to finish up the Door. I trimmed the panel to fit and drilled a few more holes and got the panel ready to install. I then insulated the door with pink foam board spaced a 1/4" away from the exterior skin. This is probably the only place that I will insulate with foam. I wanted that thud sound when closing the door, and I think I achieved it. I then installed the inner skin with flush rivets as I plan to veneer the skin with cherry later on. Did I say that the new latch works good?
ID:	65568   Click image for larger version
Aerowood is online now   Reply With Quote
Old 08-12-2008, 06:10 PM   #254
modarch's Avatar
1967 17' Caravel
Thompsons Station , Tennessee
Originally Posted by Aerowood View Post
Does anyone know if the "D" shaped door and window seal (Inland Part# 45370) is self adhesive on not?
I purchased some from Andy and indeed it is self adhesive. Be sure to clean the surface your applying to really good. I use a fine grade rotary wire brush in a drill and then clean with mineral spirits.
modarch is offline   Reply With Quote
Old 09-23-2008, 02:31 PM   #255
Aerowood's Avatar
Arvada , Colorado
We had some epoxy floor paint left over at work from when got the floor painted. My boss was going to get rid of it so I grabbed it. Today I put the first coat on the subfloor to just seal it all up abit.
Old 09-23-2008, 05:55 PM   #256
Aerowood's Avatar
Arvada , Colorado
Last weekend I plugged some holes on top of the shell, The two aft vent holes, the old bathroom vent, and on the front, the TV antenna coax hole, and the TV antenna hole.
ID:	68076   Click image for larger version
Old 09-25-2008, 08:27 AM   #257
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I took the day off today to finish up the Door. I trimmed the panel to fit and drilled a few more holes and got the panel ready to install. I then insulated the door with pink foam board spaced a 1/4" away from the exterior skin. ...
I need to come up and check your door fit. How'd the curve work out after you got the frame welded? It has been my experience that the doors seem to "un" bow so that the top and bottom aren't snug. Maybe it's the shell changing shape a little, due to road bumps. Don't know.
Your foam idea is great, especially spacing it away from the outer skin.
Zep
Old 09-25-2008, 10:56 AM   #258
Aerowood's Avatar
Arvada , Colorado
There was alot of work getting the top and bottom to fit correctly. What I did was install the the door on the hinge in the position I wanted on the trailer and then do the final drill of the new skins with the door frame clamped in the trailer door frame. After riveting on the outer skin with the door removed (you can't buck the rivets with the door in place) I then drilled and installed the inner skin with the door in place. I actually had to shim out the top because it was to snug before I blind riveted the inner skin on. I had cut the outer skin big so I then had to trim the skin for the reveal. I towed it down several miles of dirt road last weekend and had zero dust intrusion. It then rained like a cow pissing on a flat rock Sat. night and I had zero water leakage.
Old 09-25-2008, 10:56 PM   #259
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
The hard way?
Hi, Aerowood. This seems like the hard way to remove a WBCCI decal.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-26-2008, 07:05 AM   #260
Aerowood's Avatar
Arvada , Colorado
We all have our own way of doing things
Old 09-26-2008, 07:55 AM   #261
1975 31' Sovereign
1977 23' Safari
Damn, you used 14 rivets on the bigger patch up front, and more on the vent hole? I'm only using 8 or 12 on that size. Yours looks good. What's the standard, here?
Roger
Old 09-26-2008, 08:10 AM   #262
Aerowood's Avatar
Arvada , Colorado
Standard rivet spacing is 6 to 8 Diameters of the rivet.
Old 09-26-2008, 08:37 AM   #263
Sure wish I'd known that a couple of weeks ago...
Ah well, live and learn!
Old 09-26-2008, 09:56 AM   #264
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
I too need to patch some holes. Where would be a good source for small quantity of Aluminum? And what kind/spec should I buy? Thanks guys!
J
1956Safari is offline   Reply With Quote
Old 09-26-2008, 11:03 AM   #265
Aerowood's Avatar
Arvada , Colorado
2024T3 ALCLAD ALUMINUM from Aircraft Spruce
You'll need .032 2024-T3, They sell 2'X2' pieces
Old 09-26-2008, 12:51 PM   #266
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks! Same guys I got my rivet gun from. I read in one of your earlier posts that approx 3/16 of the rivet should be protruding through the hole before bucking. Any other tips you can pass my way? I've been practicing with the new 3x gun and I can't tell if the rear is mushrooming enough to hold. Been also searching for a Riveting 101 video on the net to no avail. Thanks Aerowood!
Full Monte or not? I get what I deserve! Chlyman General Repair Forum 12 10-04-2011 07:48 PM
Full Time living in an Airstreaam bmccomb On The Road... 0 08-28-2011 01:59 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 06:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 10:59 AM
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 03:42 PM
