Old 06-09-2008, 10:49 AM   #197
vhord's Avatar
Images: 96
Originally Posted by Zeppelinium View Post
I use nutplates on Zip Dee installations whenever I can get at the inner side of the shell in those locations.
Zep
My plans WERE to purchase my Zip Dee awning after I completed my restoration. Do you suggest that it might be better to install it (at least the brackets) while I still have access to the backside of the outer skins? There were some old brackets (not Zip Dee I think) that I removed from the lower belt line that had been attached with large lag bolts (3/8" I think) that were pulling at the skin. I was thinking there must be a better way.
vhord is offline   Reply With Quote
Old 06-09-2008, 12:13 PM   #198
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I think it makes is easier to properly seal things up with the walls out, if that's what you mean.
www.nesa.org
Air No. 6427
Old 06-09-2008, 01:11 PM   #199
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Now would be the best time to, at the very least, install the Zip Dee mounting hardware. This is where nutplates are very handy. You will never have to worry about hardware coming loose, pulling out, or stripping out.
Old 06-09-2008, 02:07 PM   #200
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Belly pan and nut plates
Now the images in #178 are showing up in my browser. Cool!
Originally Posted by monocoque View Post
Check out post number 178 for the belly pan. The photos aren't close ups of the nut plates. However, maybe Kip will post some close ups of them. I would be interested in seeing them too.
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 06-09-2008, 02:34 PM   #201
Makes sense. Is it possible to order just the mounting hardware and not the entire awning, in order to put off the expense of the awning until it's necessary?
Old 06-09-2008, 02:43 PM   #202
vhord's Avatar
Images: 96
I do not know if it would be cost effective buying it in parts. Maybe no difference. However, I am not sure how you would know the bracket locations without the complete awning being available. I have never installed one. Someone with experience might be able to shed some light on this.
I need to move this to another thread so as not to hijack Kip's.
Old 06-12-2008, 04:02 PM   #203
Aerowood's Avatar
Arvada , Colorado
door hinge
I was able to get my hands another main entry door hinge but it was worn like my current one . I ordered bronze bushing from Mcmaster & Carr and installed them to day. The hinge is now real tight, almost to tight. Pic #1 shows it in the mill followed but installing the bushings then lapping the hinge pin to the bushing and then assembled. I also ordered new stainless steel rod for the hinge pin.
ID:	62268   Click image for larger version
ID:	62270   Click image for larger version
Old 06-12-2008, 05:19 PM   #204
Baltimore , Maryland
blown away again...
Old 06-12-2008, 05:35 PM   #205
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Nice! Is the mill used to install the bushings? Just curious but is that a rivet gun I see sitting there?
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 06-12-2008, 05:40 PM   #206
Aerowood's Avatar
Arvada , Colorado
No, I just pulled them in with a nut and bolt. The bushing compressed a little so I had a hard time removing the bolt on the first one, so after I got it out I turned it down in diameter for the rest.
Old 06-12-2008, 06:30 PM   #207
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
What role does the mill play in the process?
Todd
Old 06-12-2008, 07:14 PM   #208
Aerowood's Avatar
Arvada , Colorado
I had to bore the exisiting oblonged hinge pin holes to .311 to recieve the bronze bushing that had an OD of .3125 and an ID of .250. I then used lapping compound on the new hinge pin to open them back up after the bushing compressed due to the interferance fit of .0015. The pin is still pretty tight but it will wear in. It has zero slop at this point. I can now start the door reskin and new style latch now that I have a zero droop door hinge.
Old 06-12-2008, 08:56 PM   #209
Central , Mississippi
... I then used lapping compound on the new hinge pin to open them back up after the bushing compressed ...
I'll toss this to the folks that may not be familar with bronze bushings, ya' gotta flush 'um pretty good after lapping or cutting because the same properties that allows them to hold oil for self lubing, also holds abrasives when your done.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-12-2008, 10:19 PM   #210
Aerowood's Avatar
Arvada , Colorado
Yes it took a bit to get the lapping compound cleaned out. First was the solvent tank and a bore brush followed with acetone and a cleaned 32 caliber bore brush followed by rifle cleaning pads.
Full Monte or not? I get what I deserve! Chlyman General Repair Forum 12 10-04-2011 08:48 PM
Full Time living in an Airstreaam bmccomb On The Road... 0 08-28-2011 02:59 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 07:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 11:59 AM
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 04:42 PM
