Old 05-29-2008, 10:14 PM   #169
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Kip, from the photo I see the "reverse" but I don't see the 1" rise.
Roger
Old 05-30-2008, 10:40 AM   #170
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It's there but not real obvious in the photo. And did I mention that it's heavy. I though that I was going to have a higher pitched voice after loading it in the truck.
Old 06-03-2008, 03:33 PM   #171
Aerowood's Avatar
Arvada , Colorado
Well I though that I was going to replace the axle on Sunday but family obligations got in the way. I had today off so I removed the old axle from the GT, cut off the shock mounts, ground them to fit the new dexter, and then took them over to my dad's to weld them on (my gt is at my house so I could remove the axle on a concrete slab). Dad only lives a couple of miles from our Airstream dealer so I went over there to check on shock prices. The nice lady quoted me 32 dollars each so I bought two. I also stopped at our local hardware store and bought new mounting bolts, nuts, and lock washers. I was able to remove the axle by myself but I am going to have to enlist some help from my brother to reinstall it.
ID:	61701   Click image for larger version
Old 06-03-2008, 03:49 PM   #172
vhord's Avatar
Images: 96
I didn't realize how heavy those suckers were (unloaded mine with a fork lift) until I looked on the freight bill and they were listed at 230# ea. I ended up having four of us to man handle them which was a lot better than the three I started with but then mine was installed over grass.
Looking gooood though!
vhord is offline   Reply With Quote
Old 06-03-2008, 03:49 PM   #173
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Kip, I like performing these stunts solo too although unfortunately or fortunately I will likely have the welder's help since my new frame will still be at his shop when the new axles arrive. But I'm curious what part of the work will require your brother's help to reinstall it?
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 06-03-2008, 04:06 PM   #174
Aerowood's Avatar
Arvada , Colorado
The axle will try to swing down from the mounted position (like it did when I removed it) so I need an extra body to get it in position with another floor jack under one of the swing arms. I unloaded it at my dads to weld on the shock mounts with dads John Deere front end loader, but had to do it at my house, again, by myself.
Old 06-04-2008, 01:54 PM   #175
1973 31' Sovereign
Portland , Oregon
Images: 22
You might possibly be able to just bolt the brackets on at one hole so that the axle is held up by those bolts so that you can then use your jack again to rotate the axle into place for the other two bolts. Just a thought but it might work. I will be interesed to hear how this goes since I still have my new axles sitting on the ground awaiting installation.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 06-04-2008, 02:48 PM   #176
Aerowood's Avatar
Arvada , Colorado
Well the dexter mounting holes are 9.250 center to center and the henchen (sp) are 9.5 center to center. I also want to check the alignment of the axle to make sure it is square with the frame, so I will need it in the saddles in order to check the alignment before I make the holes work.
Old 06-05-2008, 06:53 AM   #177
1975 31' Sovereign
1977 23' Safari
Originally Posted by malconium View Post
You might possibly be able to just bolt the brackets on at one hole so that the axle is held up by those bolts so that you can then use your jack again to rotate the axle into place for the other two bolts. ...
Exactly how I got my Axis axle on the Caravel. But I didn't have to bolt it first. Just got it lined up close, used additional hydraulic cylinder jacks to rotate the arms up, then a mallet to get the holes lined up. The Axis bracket was also off by about 1/4", which results in a nasty chattering hole when you drill it out. durn.
Zep
Old 06-07-2008, 12:36 PM   #178
Aerowood's Avatar
Arvada , Colorado
My brother Kevin, came over this morning and helped me install the new axle. It took us about an hour to finish. I still need to splice the drake wires to be done. All in all, this was a really easy project. First picture is a before, the second is an after.
ID:	61945   Click image for larger version
Old 06-07-2008, 01:00 PM   #179
vhord's Avatar
Images: 96
Quite a difference. Looks great. Let us know if you can tell any difference in towing. I know the GT will appreciate it.
Old 06-07-2008, 02:05 PM   #180
1975 31' Sovereign
1977 23' Safari
looks like you got about 3" of rise! wow.
and look at that armor-plated 0.040 belly pan with all the machine screws and no rivets!
Zep
Old 06-07-2008, 02:27 PM   #181
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Looks great. And, yeah, I agree with Zep. That's a marvelous looking belly pan! Those rivet lines on the panels are amazing too!
Todd
Old 06-07-2008, 02:33 PM   #182
vhord's Avatar
Images: 96
Screws? You holding out on us?
I'll admit that I used rubber washer headed screws to hold up some loose banana wrap before I brought mine home. Seemed to hold pretty good. However I figured I would get strung up for using them in my final install.
Full Monte or not? I get what I deserve! Chlyman General Repair Forum 12 10-04-2011 07:48 PM
Full Time living in an Airstreaam bmccomb On The Road... 0 08-28-2011 01:59 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 06:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 10:59 AM
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 03:42 PM
