Old 05-03-2016, 11:40 AM   #71
2015 30' Classic
Houston , Texas
Unless I'm looking at the wrong thing, the FE 70-200 ($1,398.00 at B&H) cost about twice as much as your initial camera and lens purchase ($598.00). I have the 55-210 and it is as good as you will ever need. We're also leaving for Alaska at the end of the month.
veratipton is offline   Reply With Quote
Old 05-03-2016, 11:53 AM   #72
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I have the 55-210 but use the NEX 5n. If you are interested in wildlife photography even 200mm is probably not enough. For landscape the 16-50mm will be fine. The FE 70-200mm will be heavy also, which defeats the purpose of the size of the A6000. Try testing the 55-210mm and then crop to enlarge the subject then revaluate your requirements.
Kelvin
Old 05-03-2016, 03:00 PM   #73
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Thank you for your responses. I do understand the expense of a new lens, however, I was only using the 70-200 as one example. Also I am not am displeased with the E 55-210 lens. It shoots some great photos. It just that I want the best lens for Alaska as we are takinig our grandson and expect to do some trips in Denali and also whale watching etc. along with probably a flight to the Nort Pole. So I guess I am looking for a lens that is kinda all around to include one that exceptional videos.
Again thanks for any insight
urnmor is offline   Reply With Quote
Old 05-03-2016, 05:34 PM   #74
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by urnmor View Post
I recently purchased the Sony A6000 with kit lens. One of which is the E 55-210. As we are going to Alaska at the end of the month I was thinking of buying the Sony FE 70-200 and use that in Alaska instead of the 55-210. Any thoughts on this lens or other lenses for the A6000 would be greatly appreciated.
What would be the advantage of having the FE 70-200?
I'm thinking of getting the A6000 based on the positive comments in this thread.
Grant
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 05-03-2016, 07:38 PM   #75
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
Seems we have quite a few Sony Alpha users here.
For those of you that are, I am one of the hosts of the AlphaMirrorless podcast. We discuss all the Sony Alpha Mirrorless cameras, lenses, techniques and more.
Take a listen: http://alphamirrorless.com/
-J
jpons is offline   Reply With Quote
Old 05-03-2016, 08:21 PM   #76
urnmor's Avatar
Berlin , Maryland
thanks for the info. Will take a look
Need fireworks photography advice nilesrob Photography 6 06-20-2007 09:55 AM
Photography Rally at the North Rim Boondocker Forum Rallies & Meet Ups 44 05-15-2007 07:27 PM
Newbies - photography fans Dolph Photography 6 03-16-2007 05:26 PM
photography forum anyone? 2airishuman Photography 9 05-13-2006 07:00 PM
