Old 11-14-2009, 03:39 PM   #1
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
Whale of a deal - '56 Flying Cloud
After a year searching for parts for the 64 globetrotter I finally came to the realization that it was too far gone to salvage (it had been rolled into a mountain side and severe structual damage and cosmetic issues) and while helping a fellow airstreamer find parts he informed me he knew where there 5 13 panel trailers.
He led me to believe I might be able to buy one and I couldn't pass up a two for one sale (for $2200 I got both).
One is a 56 Flying Cloud, the other is a 56 Overlander, both gutted, but both whale tales. Both require full restorations, which should keep me out of trouble for awhile.
Here's the Flying Cloud
Name:	56 Flying  Cloud  front.jpg
ID:	90916   Click image for larger version
Name:	56 F-C  Whale Tail.jpg
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 11-14-2009, 03:44 PM   #2
Kevin245's Avatar
Hey Wally,
Congrats on your new projects.
Kevin
Eleanor Roosevelt
Old 11-14-2009, 03:45 PM   #3
flyrc's Avatar
Yakima , Washington
Interior Photos
Here's the interior as found. How in the world did they use a 24"x24" shower?
Name:	Bath partition and closet.jpg
ID:	90919   Click image for larger version
Name:	Gas Lamp location.jpg
ID:	90921   Click image for larger version
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 03:45 PM   #4
FLYNCLD's Avatar
Bend , Oregon
OMG! What a deal! I believe that would be considered theft in most states!
FLYNCLD is offline   Reply With Quote
Old 11-14-2009, 03:48 PM   #5
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
They have potential. LOL- have fun!
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 11-14-2009, 03:53 PM   #6
flyrc's Avatar
Yakima , Washington
As with most restoration projects I'll have to start replacing floor since the back 6" are gone, and I presume the same is the case in the front. Floor by the door is nonexistant.
At one time the PO had a tire blow and destroyed the street side wheel well, which a local sheet metal shop has fabricated for me.
Someone scabbed on a makeshift black tank, and the toilet rust-mounted to it. There was homemade gray water tank that was 6"x6"x60" slung under the belly just behind the wheel wells. Neither will possibly work so after the floor is replaced I'll start the tank search.
Name:	Back bedsupport on wall and missing floor.jpg
ID:	90923   Click image for larger version
Name:	Bad wheel well cover side view.jpg
Name:	old toilet and improvised tank..jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:01 PM   #7
flyrc's Avatar
Yakima , Washington
I pulled the lower skins down, and removed the belly pan and the back 8' of floor.
There was some frame damage, but had a local welder come in and make the repairs.
Name:	hole in frame.jpg
ID:	90926   Click image for larger version
Name:	Rusty frame member.jpg
ID:	90928   Click image for larger version
Name:	Pink bath wall.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:02 PM   #8
Kevin245's Avatar
While I worked overseas I had a similar sized shower in my flat. It wasn't bad for me unless I dropped the soap. You had to open the door and step outside so you could reach in to retrieve the dropped item.
Kevin
Eleanor Roosevelt
Old 11-14-2009, 04:06 PM   #9
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Soooooo, dose this mean the overlander is for sale?
Xbob2 is offline   Reply With Quote
Old 11-14-2009, 04:12 PM   #10
flyrc's Avatar
Yakima , Washington
I got sidetracked after reading a forums post about paint removal and decided the pink had to go and that I'd like to not make that mess on the new floor.
I never thought I would work so hard and it would take so long to get rid of that many layers of paint. The latex wasn't so bad, but getting that last layer of Zolatone was a real
I tried every stripper in the book and finally read a post that recommended 0000 steel wool to get through the last of the Zolatone layer. I highly recommend the steel wool because it saved my bacon.
After two weeks and $200 worth of paint remover I decided that buying new lower metal will be by far the best way to go.
I really like the look of her tail in all natural. Don't you?
Name:	Front curb  Don't  buy  pink.jpg
ID:	90932   Click image for larger version
Name:	Interior stripped rear curb.jpg
Name:	Interior stripped street rear.jpg
ID:	90934   Click image for larger version
Name:	looking back   street side.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:17 PM   #11
flyrc's Avatar
Yakima , Washington
Front end cap interior center panel
The front end cap, interior center panel is discolored, almost like a water marked hue/stain. I started trying to remove it with a cyclo with F7 (see photo) and only was able to break through it in a few places.
Does anyone have any suggestions on how to address this? Should I try to sand it with 1600 WD paper or, high speed buffer, or should I pull rivets and replace the panel?
If replacement is the only option, do you think it can be done without pulling the whole end cap down?
Name:	front cap cyclo made the stain.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:18 PM   #12
flyrc's Avatar
Yakima , Washington
My wife would kill me... Here's the Overlander
OLD TIMERS LOOK GOOD TOGETHER
Name:	Old timers look good together.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:29 PM   #13
1962 28' Ambassador
1962 30' Sovereign
Beautiful! Single or double axil?
Old 11-14-2009, 04:35 PM   #14
1962 28' Ambassador
1962 30' Sovereign
Lets see ... she didn't kill you for BUYING them but would kill you for SELLING them? She have an available sister?
whale tail
Leaky AC on new Flying Cloud scubadog Furnaces, Heaters, Fireplaces & Air Conditioning 91 07-16-2013 12:42 PM
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
