Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1956 - 1959 Flying Cloud
Old 01-30-2010, 09:05 PM   #81
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
62 frames=67 frames?
Originally Posted by Xbob2 View Post
Bo&Susan could use the window frames that are riveted to the shell ... theirs are all chopped up!
Bob I just talked with Susan and learned she has a 62 Airstream. Since the body and caps changed in 64, will my window frames from the(67) fit her her 1962 trailer. Her trailer has 7 segments, mine has five. I'd hate to pull all those rivets and ship her something she can't use.
Wally H
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 01-30-2010, 10:12 PM   #82
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Wally H
Guess the bottom line would be the dimensions of the riveted frame ... simple enough to suss ...
Xbob2 is offline   Reply With Quote
Old 01-31-2010, 01:06 PM   #83
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Back to the 56FC
Last week between distractions I finally got the first 4' of new plywood in place. I won't bolt it down until I get the next piece in position.
I removed the torn up wheel well, curb side,and had the local sheet metal shop make me a new one. Of course the street side had to be take off to have a good template. I guess that's the way it goes, you take more apart than you want to, to fix a problem. I apologize for the fuzzy wheel well photo
Once the next piece of plywood is installed, I'll remove the section by the door and find out how much welding it's going to take to repair the step mount. I'll take lots of photos.
H
Name:	Old torn up wheel wel.jpg
ID:	95145   Click image for larger version
Name:	First piece of plywood and new wheel well.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 06-05-2010, 12:36 PM   #84
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
57 13 segment Ohio built # 3459
I just couldn't pass this one up. I love the large side windows I really didn't need another one since I haven't spent any time with the 56 lately. Once all the lower body aluminum is replaced, the three segments replaced, and the windows are repaired, it will be a good candidate for a new interior. Is it worth all the work?
Name:	Badges   Flying Cloud   O  3459.jpg
ID:	104086   Click image for larger version
Name:	street side looking forward.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 06-05-2010, 05:39 PM   #85
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Brad is the plug at the antenna or inside the trailer?
I completely fell behind on this thread. The antenna plug is the one on the outside of the trailer and is white with two slotted screw wire connections.
Thanks.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-05-2010, 07:23 PM   #86
asbury park , New Jersey
ok, seriously, what the heck. are airstreams just falling out of thin air out there?!?!? really. this is getting silly.
NJtoNC is offline   Reply With Quote
Old 06-05-2010, 08:24 PM   #87
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
believe it or not there seems to be a $500 or so airstream on craigslist around here once or twice a month if you want to drive somewhere in the state to get it. Most are from the west side so everything wood is rotten, mold everywhere, and rust, but hey just time and money fix that.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 06-05-2010, 09:46 PM   #88
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
And you know "nothing" about those "$500.00" Airstreams, do you Scott?
Marc
Old 06-05-2010, 10:58 PM   #89
goransons's Avatar
1963 22' Safari
I watch many of them, but have no real driveway or storage area. If I lived on a farm I'd have one heck of an airstream hoarding problem. Fortunately Wally has the same problem. But yes I will be adding another 63 to the list soon, a 30'. Just have to go pick it up.
Scott & Megan
Old 06-08-2010, 08:35 AM   #90
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
The rest of the story
What are your plans for the 30'er Scott?
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 12-29-2010, 05:21 PM   #91
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
There is, coincidentally, a 1956 whale tail Flying Cloud for sale near me for $1500 right now...
Vintage Airstream 22' Flying Cloud
TX-16
Dave Park is offline   Reply With Quote
Old 12-29-2010, 06:38 PM   #92
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hey Dave....I saw that on Craigs....BAD>>>>BAD>>>>BAD.
So bad I can't believe it. The bad part is that I probably know the seller. Why in the world sacrifice a really good Whale Tail Cloud just to pilfer the windows...for an obviously other project. Those windows are available other places.....save the whole Cloud.
Old 12-29-2010, 08:27 PM   #93
Dave Park's Avatar
2005 22' Safari
There's another one in the background. :/
I have an account with Binswanger glass so I can get great prices, so for me the glass is not an issue.
However, I am mistrustful of his statements about the frame, which are "weaselly worded" to say that he knows a part of the frame is ok.
That said, even for a ground-up restoration with a heavily repaired or replaced frame, $1500 is in the ball-park. The glass would be around $150 all in.
If someone in another area is interested in this trailer, and wants me to go look at it, I can.
TX-16
Old 12-29-2010, 09:25 PM   #94
pbearsailor's Avatar
Port Hadlock , Washington
I don't read that like he's taking the glass out, though, Dave. He's taking the Hehr windows like Robin is saying. Starting a 50's restoration without the Hehr windows is going to make it very very difficult. Got to be about the most difficult thing to come up with.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-29-2010, 10:02 PM   #95
Dave Park's Avatar
2005 22' Safari
Well, in that case, to my mind he's destroying a historical artifact, more or less.
TX-16
Old 12-30-2010, 02:17 AM   #96
Baltimore , Maryland
they cannot all be saved.
Old 12-30-2010, 07:01 AM   #97
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Sad...Franks right.
whale tail
Leaky AC on new Flying Cloud scubadog Furnaces, Heaters, Fireplaces & Air Conditioning 91 07-16-2013 12:42 PM
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
