By the Serial Number 7628 it can be identified as an early 1954 22' Flying Cloud built in California. It also has tail lights that I believe were only used in early 1954, which is another clue, as are the side marker lights that were last used in early 1954. Is it another whale tail, which would mean it also has a sloped rear end? Or is the rear end vertical, like the 53's and earlier?
In any case, nice find, but another one needing a LOT of work!
__________________ Joe
WBCCI/VAC #702 & #6768
Sorry about posting the same photos twice. I was tired and trying to get the photos out of an email and through photo shop. It became confusing, there were 34 to sort through.And about the rear end, I'll have to pay closer attention
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
Sloped Rear: From 1950 to early 1954, the rear panel on all flat end Airstreams was vertical which gave a "squared off" look from the side. In early 1954 they started making the rear panels slope outward from top to bottom, which gave a "fast bacK" appearance from the side that makes the trailer look like it is moving even when it is standing still. This sloped rear end continued thru 1968 until the body shape changed for 1969.
I believe California switched from the 13-panel rear end caps to the 9-panel whale tail end caps at the same time they switched from the vertical to sloped rear ends. This happened early in the 1954 model year.
I sure hope the fire didn't hurt anybody. What ever exploded went up through the front vent and a second piece went through a front segment. The back 6 or 7 feet of the shell isn't attached to the floor. All the floor feels like you could step through it. I brought tires, Roger checked and packed the bearings. Because I wasn't able to trailer it, I attached the straps and hoped for the best. I had to tow it 90 miles and half of that had to be freeway.
Without Rogers help this wouldn't have been possible. He found the beast,talked the seller down to my price, and then made sure it got out of his yard
Wally H.
Parts needed
range or parts
Dometic 50 or parts
When I met Roger he showed me his 62 TW, and his 61 Bambi, it has a crushed in top, and then I saw the Caravel I work on gravel and crushed rock, so the concrete floor and the 4 point lift got all my attention. I can't tell you anything about the Caravel.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
I had to stop at George, WA. to calm my nerves and get something to drink. Or was it the other way around This was the halfway point, the rest of the trip was to be freeway.Ten miles down the road I had to cross the Columbia River at Vantage and the wind can cause 18 wheelers problems.I about when I approached the bridge and saw the wind socks were full.I had two quick thoughts, would the straps keep it on the frame,and would it become a Flying Cloud and slam the railings? We made it across safely and the rest of the trip was just dealing with the 18 wheelers.The door was removed because it was only attached with baling wire.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Yup, definitely a slanted back. Congrats on the finds, though I think if I'd run across a deal like this I'd have turned right around and passed the savings onto somebody else.
You're a sick man Wally! Love it! When you mention "Roger".. is this Zep? Nice shop.. if it is Zep, I can totally tell by his work...
So what's the plan for the, what, FOUR AS's you have?
How much jewlery have you bought the wife lately?
Marc
Marc
No not Zep. This is Roger and Bonnie Miller from Ephrata, WA.
About the wife. She isn't into jewelery and has even brought up the idea that we need a smaller house, a big shop, and more land
My friend in Outlook says Airstreams are like kids, once you have two or three, whats a couple more.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
