Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1956 - 1959 Flying Cloud
Old 11-14-2009, 06:31 PM   #21
Catman6's Avatar
1986 Argosy
Denver , Pennsylvania
Originally Posted by Xbob2 View Post
Lets see ... she didn't kill you for BUYING them but would kill you for SELLING them? She have an available sister?
I so second that one!!!!
Catman6 is offline   Reply With Quote
Old 11-15-2009, 07:57 PM   #22
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
After working on the interior paint removal for a couple of weeks I got back to working on the frame. I thought that scraping rust was a pain until I started applying the POR-15. The POR-15 is great stuff, but one doesn't realize how many hard to get at areas there are on a frame and how tough it is to keep the stuff from dripping onto you as you crawl around in the dirt under the trailer. I thought I had protected myself from the POR-15 until I removed my coveralls and found three black spots (dime size) on my T shirt. You guessed it, I also have three nice black spots on my chest
Question... Is there a need to put a thin layer of insulation or some other material between the frame and the plywood to cushion the two. Did the factory just use the plywood to hold the insulation in place when they were putting a trailer together?
I plan to start replacing the first 4' of floor tomorrow so let me know about the cushion between wood and metal.
Name:	Rear frame  cleaned and  POR-15 painted.jpg
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 11-15-2009, 08:00 PM   #23
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
It was my perception that the insulation was set over the top to make installation easier not anything as far as the plywood to frame joints.
Frame looks great!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-15-2009, 10:01 PM   #24
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Yes, mine had it over the rails.. Yes, AS did it originally... No, I don't think it's a good idea... all the rust on my frames was from the insulation holding the moisture against the frame rails under the wood... even if the wood looked ok, some of my crossmembers turned to dust due to the rust there.. in summary... don't do it!
Nice framework by the way... can we see pics of the other trailer too?
Marc
Old 11-15-2009, 10:07 PM   #25
nmbosa's Avatar
Nowhere , Washington
Wally, you've got a couple of very nice looking trailers. I'm with XBob2 watching with envy. As far as the cushion between the frame and the plywood, I'm not sure if it's needed, but I'm planning on using foam that is used in construction between foundations and the sill plate as a vapor barrier between the steel and the plywood. A buddy of mine who is working on my trailer restoration used this on his trailer, and it seems like a good idea. Airstream's old method of putting the insulation on over the frame seemed to have simply trapped a bunch of moisture on the top edge of the frame and caused a lot of rust. [On edit, I was writing my response when Marc posted his and I see he had the same thought about the rust.]
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 11-15-2009, 11:03 PM   #26
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Marc
Thanks for the great advise.
Here are a couple of photos of the Overlander. I sure hope you guys don't think I have the energy that Scott Goranson has. I'm almost old enough to be his father I'll be working on the Flying Cloud first and will be collecting stuff for it's big brother. My wife was O.K. with the second trailer, but the little guy must be finished before I work on the other.
Name:	56  home at the barn.jpg
ID:	91102   Click image for larger version
Name:	Old timers look good together.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-16-2009, 08:00 AM   #27
I love them both, great finds! I'm looking forward to (many years) of watching your trailer restorations!
Old 11-16-2009, 09:12 AM   #28
Wabbiteer's Avatar
Jupiter , Florida
Nice warm and fuzzy boy meets trailer(s) story... Kinda brought tears to my eyes witnessing the wrath of time though, thanks for posting.
About the plywood to steel interface, I had wood rotted six feet into the trailer where water had wicked above the frame rails - but that doesn't mean not to place some thermal break in between. And being vague is intentional, I slapped plywood back onto bare metal but I was only doing the back sheet, so I don't have a product in mind to suggest....
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 11-16-2009, 09:48 AM   #29
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
YEARS
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-16-2009, 10:36 AM   #30
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
When Oppertunity Knocks
No, No..Wabbiteer .It should have been " Heartless Old Fart talks another Sweet Old Lady out of her trailer!
In all honesty I was on a parts search and the person in Seattle didn't have what I was looking for, but knew a lady that was going to send her 67 Overlander to the wrecking yard. So what would you have done? There was room next to the old barn, so I made a quick trip over the mountain and drug it home. It was free, so I couldn't let it go to waste. Now what do I do?
Maybe a $5.00 raffle or the BEST OFFER?
P.S....The 67 Ambassador next to it was a $600.00 find. It is camp ready.
My friend Mike,the owner of the barn, bought it. My friends think I need intervention or AA...Airstream Anonymous. Scott just rolls his eyes
Name:	front street.jpg
ID:	91112   Click image for larger version
Name:	Mising Main Door.jpg
ID:	91114   Click image for larger version
Name:	Nice Trees.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-16-2009, 07:24 PM   #31
goransons's Avatar
1963 22' Safari
Wally I'd suggest trading material there, see if someone needs a new project, or some donor panels and can help you trade for the window parts etc you need. There are other airstreamers on here sick enough to own multiple units that may have extra parts laying around, plus you saved it from the scrap pile, at least for now.
Scott & Megan
Old 11-16-2009, 08:29 PM   #32
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I don't know if you would call us owners "sick", maybe aafflicted??? I have 4 myself: a '97 30' Excella 1000, a '73 27' Overlander, a '75 Argosy 24' and a 73 Argosy 22'. And...I know where there is 68 Overlander for sale. Wife said no more right now.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 11-16-2009, 08:42 PM   #33
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
You need to get your priorities straight here!
Xbob2 is offline   Reply With Quote
Old 11-16-2009, 09:58 PM   #34
goransons's Avatar
1963 22' Safari
If Only Wally's Wife's sister was still single right?
Scott & Megan
Old 11-17-2009, 07:41 AM   #35
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Amen!!
Bruce
Old 11-17-2009, 07:27 PM   #36
YEARS
Oh come on, you've spent some time around here. You knew what you were getting into!
Old 11-20-2009, 07:55 PM   #37
goransons's Avatar
1963 22' Safari
Ok Wally, the "cat lady" of stray airstreams.... tell everyone about what you just drug home....
Scott & Megan
Old 11-20-2009, 08:01 PM   #38
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Wally??? We're all waiting to hear what you brought home.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-20-2009, 08:11 PM   #39
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
It's just a little old two wheeler.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-20-2009, 09:19 PM   #40
goransons's Avatar
1963 22' Safari
Don't make me post pictures....
Scott & Megan
whale tail
Leaky AC on new Flying Cloud scubadog Furnaces, Heaters, Fireplaces & Air Conditioning 91 07-16-2013 12:42 PM
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
