Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1956 - 1959 Flying Cloud
Old 11-14-2009, 03:39 PM   #1
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Whale of a deal - '56 Flying Cloud
After a year searching for parts for the 64 globetrotter I finally came to the realization that it was too far gone to salvage (it had been rolled into a mountain side and severe structual damage and cosmetic issues) and while helping a fellow airstreamer find parts he informed me he knew where there 5 13 panel trailers.
He led me to believe I might be able to buy one and I couldn't pass up a two for one sale (for $2200 I got both).
One is a 56 Flying Cloud, the other is a 56 Overlander, both gutted, but both whale tales. Both require full restorations, which should keep me out of trouble for awhile.
Here's the Flying Cloud
Name:	56 Flying  Cloud  front.jpg
ID:	90916   Click image for larger version
Name:	56 F-C  Whale Tail.jpg
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 11-14-2009, 03:44 PM   #2
Kevin245's Avatar
Hey Wally,
Congrats on your new projects.
Kevin
William C. Swinney
Old 11-14-2009, 03:45 PM   #3
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Interior Photos
Here's the interior as found. How in the world did they use a 24"x24" shower?
Name:	Bath partition and closet.jpg
ID:	90919   Click image for larger version
Name:	Gas Lamp location.jpg
ID:	90921   Click image for larger version
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 03:45 PM   #4
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
OMG! What a deal! I believe that would be considered theft in most states!
FLYNCLD is offline   Reply With Quote
Old 11-14-2009, 03:48 PM   #5
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
They have potential. LOL- have fun!
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 11-14-2009, 03:53 PM   #6
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
As with most restoration projects I'll have to start replacing floor since the back 6" are gone, and I presume the same is the case in the front. Floor by the door is nonexistant.
At one time the PO had a tire blow and destroyed the street side wheel well, which a local sheet metal shop has fabricated for me.
Someone scabbed on a makeshift black tank, and the toilet rust-mounted to it. There was homemade gray water tank that was 6"x6"x60" slung under the belly just behind the wheel wells. Neither will possibly work so after the floor is replaced I'll start the tank search.
Name:	Back bedsupport on wall and missing floor.jpg
ID:	90923   Click image for larger version
Name:	Bad wheel well cover side view.jpg
Name:	old toilet and improvised tank..jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:01 PM   #7
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
I pulled the lower skins down, and removed the belly pan and the back 8' of floor.
There was some frame damage, but had a local welder come in and make the repairs.
Name:	hole in frame.jpg
ID:	90926   Click image for larger version
Name:	Rusty frame member.jpg
ID:	90928   Click image for larger version
Name:	Pink bath wall.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:02 PM   #8
Kevin245's Avatar
While I worked overseas I had a similar sized shower in my flat. It wasn't bad for me unless I dropped the soap. You had to open the door and step outside so you could reach in to retrieve the dropped item.
Kevin
William C. Swinney
Old 11-14-2009, 04:06 PM   #9
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Soooooo, dose this mean the overlander is for sale?
Xbob2 is offline   Reply With Quote
Old 11-14-2009, 04:12 PM   #10
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
I got sidetracked after reading a forums post about paint removal and decided the pink had to go and that I'd like to not make that mess on the new floor.
I never thought I would work so hard and it would take so long to get rid of that many layers of paint. The latex wasn't so bad, but getting that last layer of Zolatone was a real
I tried every stripper in the book and finally read a post that recommended 0000 steel wool to get through the last of the Zolatone layer. I highly recommend the steel wool because it saved my bacon.
After two weeks and $200 worth of paint remover I decided that buying new lower metal will be by far the best way to go.
I really like the look of her tail in all natural. Don't you?
Name:	Front curb  Don't  buy  pink.jpg
ID:	90932   Click image for larger version
Name:	Interior stripped rear curb.jpg
Name:	Interior stripped street rear.jpg
ID:	90934   Click image for larger version
Name:	looking back   street side.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:17 PM   #11
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Front end cap interior center panel
The front end cap, interior center panel is discolored, almost like a water marked hue/stain. I started trying to remove it with a cyclo with F7 (see photo) and only was able to break through it in a few places.
Does anyone have any suggestions on how to address this? Should I try to sand it with 1600 WD paper or, high speed buffer, or should I pull rivets and replace the panel?
If replacement is the only option, do you think it can be done without pulling the whole end cap down?
Name:	front cap cyclo made the stain.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:18 PM   #12
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
My wife would kill me... Here's the Overlander
OLD TIMERS LOOK GOOD TOGETHER
Name:	Old timers look good together.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 04:29 PM   #13
1962 28' Ambassador
1962 30' Sovereign
Beautiful! Single or double axil?
Old 11-14-2009, 04:35 PM   #14
1962 28' Ambassador
1962 30' Sovereign
Lets see ... she didn't kill you for BUYING them but would kill you for SELLING them? She have an available sister?
Old 11-14-2009, 04:46 PM   #15
BeBop's Avatar
2000 27' Safari
Berkeley , California
I think one of the attraction of the older units is no compound curves. Good with a shear and rivet gun?... you can maintain that skin forever. But from the looks of it, you don't have to, as it appears to be pristine! What a find X 2!
Congratulations!
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline   Reply With Quote
Old 11-14-2009, 05:21 PM   #16
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
The Overlander is a double axle trailer and I've been told it had a center bath.The Overlander project isn't going to happen any time soon. It was such a good buy that I couldn't pass it up. It has much better metal than the Flying Cloud, but absolutely no interior. I plan to gather stuff for it as I work on the Cloud.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 05:27 PM   #17
pbearsailor's Avatar
Port Hadlock , Washington
Congrats on a pair of great finds, Wally. Looks like you've got quite a bit to work with there.
I too had some bad spots on my inside endcap. Tried every grade of Nuvite and worked and worked at it and just couldn't get it. I did finally go to a series of WD paper, starting at 400 and going up. Still not perfect, but I'm happy with it now and would do it again that way.
And I agree, stripping the old Zolatone is just a bear.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 11-14-2009, 05:41 PM   #18
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
Congratulations!
On our last trip to Northern CA. to see my 96 year old Dad, My wife, Janni spotted a 13 panel trailer and that was the start of our search. She loved all the panels. I looked through the vintage photo archives and decided I wanted a whale tail. So when I found them I didn't sleep much until they were both back at the barn
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-14-2009, 05:45 PM   #19
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Wally'd be much further if he wasn't over here helping as the "bucker" for my panel replacement. I should also mention he's one heck of a good wheelbarrow operator.
Was a great find, the pictures don't do it justice. Wish my paint stripping was going that well/fast. Hoping he'll come give me lessons
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-14-2009, 05:48 PM   #20
1962 28' Ambassador
1962 30' Sovereign
K ... watching with vulture eyes ...
whale tail
Leaky AC on new Flying Cloud scubadog Furnaces, Heaters, Fireplaces & Air Conditioning 91 07-16-2013 12:42 PM
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
