Old 11-20-2009, 10:27 PM   #43
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
Maybe a couple more.
Name:	whale tail  the big boom theory.jpg
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 11-20-2009, 10:44 PM   #44
flyrc's Avatar
Yakima , Washington
I'm sure Scott would like to see more. He's such a trouble maker sometimes.
Name:	whale tail  wheel well five lug.jpg
ID:	91322   Click image for larger version
Name:	whale tail door.jpg
Name:	whale tail  ID plate.jpg
ID:	91324   Click image for larger version
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-20-2009, 10:50 PM   #45
flyrc's Avatar
Yakima , Washington
I'm sure I wasn't there when it went from bad to worse.This trailer doesn't have a name and only has 5 lug nuts.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-20-2009, 11:02 PM   #46
flyrc's Avatar
Yakima , Washington
What I brought home
I forgot to up load the picks
By now you will all know what I brought home. What ever you do, don't tell my wife
ID:	91326   Click image for larger version
Name:	whale tail  dirty door.jpg
ID:	91328   Click image for larger version
Name:	whale tail   storage compartment.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-21-2009, 07:02 AM   #47
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
By the Serial Number 7628 it can be identified as an early 1954 22' Flying Cloud built in California. It also has tail lights that I believe were only used in early 1954, which is another clue, as are the side marker lights that were last used in early 1954. Is it another whale tail, which would mean it also has a sloped rear end? Or is the rear end vertical, like the 53's and earlier?
In any case, nice find, but another one needing a LOT of work!
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 11-21-2009, 07:27 AM   #48
flyrc's Avatar
Yakima , Washington
sloped rear ?
Sorry about posting the same photos twice. I was tired and trying to get the photos out of an email and through photo shop. It became confusing, there were 34 to sort through.And about the rear end, I'll have to pay closer attention
Name:	storage  curb side.jpg
ID:	91332   Click image for larger version
Name:	54 FC  Whale Tail   crazy tail lights.jpg
Name:	Hold downs on   checking air pressure.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-21-2009, 07:32 AM   #49
1962 22' Safari
2016 30' Classic
Images: 41
Sloped Rear: From 1950 to early 1954, the rear panel on all flat end Airstreams was vertical which gave a "squared off" look from the side. In early 1954 they started making the rear panels slope outward from top to bottom, which gave a "fast bacK" appearance from the side that makes the trailer look like it is moving even when it is standing still. This sloped rear end continued thru 1968 until the body shape changed for 1969.
I believe California switched from the 13-panel rear end caps to the 9-panel whale tail end caps at the same time they switched from the vertical to sloped rear ends. This happened early in the 1954 model year.
Joe
WBCCI/VAC #6768
Old 11-21-2009, 07:59 AM   #50
flyrc's Avatar
Yakima , Washington
What a nice interior NOT!
I sure hope the fire didn't hurt anybody. What ever exploded went up through the front vent and a second piece went through a front segment. The back 6 or 7 feet of the shell isn't attached to the floor. All the floor feels like you could step through it. I brought tires, Roger checked and packed the bearings. Because I wasn't able to trailer it, I attached the straps and hoped for the best. I had to tow it 90 miles and half of that had to be freeway.
Without Rogers help this wouldn't have been possible. He found the beast,talked the seller down to my price, and then made sure it got out of his yard
Name:	whale tail 022.jpg
ID:	91338   Click image for larger version
Name:	whale tail 023.jpg
Name:	whale tail 025.jpg
ID:	91340   Click image for larger version
Name:	whale tail 026.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-21-2009, 08:14 AM   #51
flyrc's Avatar
Yakima , Washington
What a shop!
When I met Roger he showed me his 62 TW, and his 61 Bambi, it has a crushed in top, and then I saw the Caravel I work on gravel and crushed rock, so the concrete floor and the 4 point lift got all my attention. I can't tell you anything about the Caravel.
Name:	Shop  wouldn't it be nice.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-21-2009, 08:38 AM   #52
flyrc's Avatar
Yakima , Washington
Trip Home
I had to stop at George, WA. to calm my nerves and get something to drink. Or was it the other way around This was the halfway point, the rest of the trip was to be freeway.Ten miles down the road I had to cross the Columbia River at Vantage and the wind can cause 18 wheelers problems.I about when I approached the bridge and saw the wind socks were full.I had two quick thoughts, would the straps keep it on the frame,and would it become a Flying Cloud and slam the railings? We made it across safely and the rest of the trip was just dealing with the 18 wheelers.The door was removed because it was only attached with baling wire.
Name:	Half way home   George, WA..jpg
ID:	91343   Click image for larger version
Name:	54 Flying Cloud   back at Bobs.jpg
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-21-2009, 08:54 AM   #53
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Yup, definitely a slanted back. Congrats on the finds, though I think if I'd run across a deal like this I'd have turned right around and passed the savings onto somebody else.
bredlo is offline   Reply With Quote
Old 11-21-2009, 11:32 AM   #54
flyrc's Avatar
Yakima , Washington
Brad, I'll be glad to "pass" it your way. Someone will need what it has to offer.
Wally H.
Parts needed
range or parts
Dometic 50 or parts
Old 11-21-2009, 04:40 PM   #55
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
You're a sick man Wally! Love it! When you mention "Roger".. is this Zep? Nice shop.. if it is Zep, I can totally tell by his work...
So what's the plan for the, what, FOUR AS's you have?
How much jewlery have you bought the wife lately?
Marc
Old 11-21-2009, 06:53 PM   #56
flyrc's Avatar
Yakima , Washington
Originally Posted by Xbob2 View Post
Soooooo, dose this mean the overlander is for sale?
I do have a great deal for you on a 54 Flying Cloud
Wally H.
Parts needed
range or parts
Dometic 50 or parts
whale tail
Leaky AC on new Flying Cloud scubadog Furnaces, Heaters, Fireplaces & Air Conditioning 91 07-16-2013 12:42 PM
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
