Old 02-27-2013, 10:43 AM   #1
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Torsion axle - 1959
I am weighing the option of replacing my axel or going through the labor of converting my current axel to electric brakes.
Does anyone have the measurement requires for the 59 Flying could to price the axel?
rowdyATX is offline   Reply With Quote
Old 02-27-2013, 10:50 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
You will hear some people say to go to a torsion axle and that is fine. I like the "pure" vintage look with the spring axle. However, I would change my axle to a more modern one with bigger spindles to allow for a 6x5.5 bolt pattern which will give you more wheel options in you don't stay with vintage wheels. Also the original axles are post WWII surplus that do not have the larger spindles and speed ratings for todays towing.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 02-27-2013, 11:01 AM   #3
rowdyATX's Avatar
1961 28' Ambassador
I went to buy the brakes yesterday to covert my system to electric and by the time they talked me into repacked bearings and running wires, I was looking at nearly the price of just buying a new axel...
Plus, they were unsure if I would be able to mount it to my current set up....
I'm also a fan of the spring axels.
Old 02-27-2013, 11:33 AM   #4
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Southwest Wheel is who I am going to buy mine from. I am going with a Dexter 3500# axle with electric brakes, nev-r-lube bearings and electric brakes.
Bruce
Old 02-27-2013, 11:52 AM   #5
rowdyATX's Avatar
1961 28' Ambassador
Drop or straight?
Old 02-27-2013, 03:24 PM   #6
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
It will probably be a straight. That way I can undersling it or oversling it-mount it below or above the springs depending on desired clearance.
Bruce
Old 02-27-2013, 05:26 PM   #7
JimGolden's Avatar
1977 31' Excella 500
Keep the Leaves....
Stay with leaf springs. They are less trouble in the long run.
Call Dexter, tell them what you have, and they will help you. I would recommend you get a heavy capacity axle with the big drum brakes, but then you use the proper leaf springs for the trailer weight. Should be the last axle you ever need.
Inland Andy may be able to hook you up. I know he does the torsion axles. Not sure if he can get you a leaf sprung one. If so, he's one stop shopping.
But, I wouldn't dream of changing it over. There is no good reason to. Wally went to the torsion axles because they have a lower parts count and are tougher when you're dragging them through a swamp in South America. If you're not going to be doing that, then a leaf spring setup will be superior (with shock absorbers). Wally never envisioned the trailer being 40 years old....
Rubber axles are great until they are 15-20 years old. Then you unbolt them and throw them away.
Best of luck whichever way you go,
- Jim
JimGolden is offline   Reply With Quote
Restoring Torsion Arm/Axle Resiliency Roadanswer Axles 11 10-11-2009 07:58 AM
Torsion axle warranty Inland RV Center, In Commercial Listings 1 07-17-2007 08:14 PM
Fixed or Torsion Axle for 1958 Traveler? prairieschooner Axles 12 09-21-2006 08:46 PM
torsion axle questions nevisstudio Axles 2 09-01-2004 01:36 AM
torsion axle...not sure nevisstudio Axles 6 04-01-2004 08:40 PM
