Old 08-12-2018, 06:58 AM   #15
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Originally Posted by Airspry View Post
We are still looking for a window for the lower of two on the curb side just in front of the door. If anyone knows of one, please let me know. The measurements of the window itself are approximately 17.5" h x 17.75" w.
I found that good HVAC guy can make a window frame. You will most likely have to improvise on a few of the moving parts, but know one will know but you. BTW I had one made for me. I supplied the aluminum and he only charged me $50.00.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 08-15-2018, 02:15 PM   #16
1957 22' Flying Cloud
Providence , Utah
Thank you Islandtrader
Thank you for the advice. We have been thinking about reaching out to HVAC folks for some other parts. I had not thought of getting their help on the window.
Airspry is offline   Reply With Quote
Old 11-19-2018, 12:16 AM   #17
Providence , Utah
It's slow, but there is progress
It has been a while since I shared our progress. It has been slow going.
The good news is that we found a window for the curbside beside the door. It has two smaller windows. I have not removed the old frame yet but will do that as soon as I've rebuilt the two new windows. One is badly corroded so it will be a challenge.
Otherwise, we built a new floor. It's marine plywood with insulation sandwiched in between. Here's a picture so you can see what we did. The idea is to avoid insulation in the floor that will get wet and just provide rodent housing. Our next step is to install Marmoleum over the floor.
We just found a garage in the neighborhood where we can work this winter. We need to learn to rivet in order to get her back together. We'll practice before working on the trailer.
Name:	Windows rebuilt front & street.jpg
ID:	328151   Click image for larger version
Name:	Window in backJPG.JPG
Name:	back curb window.jpg
ID:	328153   Click image for larger version
Name:	new floor foam showing small.jpg
Old 11-19-2018, 08:06 AM   #18
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
It will be interesting to hear how the additional wood bracing between the frame and plywood floor works once you have the trailer back bouncing down the road. I would be concerned that this will force the floor bolts to be longer and this reduce structural rigidity.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 11-20-2018, 11:16 PM   #19
Providence , Utah
Hi Joe,
I sure hope that it is ok. Building the floor this way took a long time. If it doesn't work well, we'll be in a world of hurt.
Old 11-22-2018, 07:08 AM   #20
1956 22' Caravanner
I know this is after the fact...I just laid the floor down and then glued the insulation to the floor. After that then put the belly pans on. The air space barrier is on the bottom side which will insulate the floor from heat and cold...
Old 11-22-2018, 08:23 AM   #21
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Secure your body shell
Hi Airspry:
Nice to see some progress, however slow it might be. I tend to be a tortise myself.
Is your aluminum body shell staked to the ground on the inside with ratchet straps or something? I have seen photos of loose lightweight shells blown away in a strong wind and get terribly bent, creased, crumpled and ruined. Secure that shell if that hasn't yet been done.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 11-23-2018, 01:22 PM   #22
Providence , Utah
Thank you for sharing your approach. We decided not to replace the belly pan as it seemed to provide rodent housing. Time will tell if that was a good idea. It has been fun watching your renovation. Thank you for sharing your progress.
1957, flying cloud
« Help!! 1957?? | Top | - »
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-11-2010 03:40 PM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-04-2010 03:40 PM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
New Adventure - 1958 Flying Cloud twnkoptimist Member Introductions 3 06-05-2007 02:39 PM
