Old 09-28-2008, 09:22 PM   #15
soldiermedic's Avatar
Florissant , USA
Thanks for the plug Richard.
Depending on the shape of your interior, I wouldn't consider selling it for under $3000-$4000. I paid $2500 for mine not including gas to fetch it. I have probably spend $1,000 on tools and parts so far needed for restoration. It isn't fast, it isn't cheap....but it's an Airstream!
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 09-28-2008, 09:32 PM   #16
1956 22' Flying Cloud
Tellico Plains , Tennessee
Thanks again!! Now I can look at this thing in the morning with a different perspective.
grayj is offline   Reply With Quote
Old 09-28-2008, 09:52 PM   #17
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by grayj View Post
Thanks a lot for your quick help. I already found out more here in a few minutes than I ever could have on my own. ...<snip>...Thanks again!!
A good example of two of the great things about this forum...the depth of knowledge here and the willingness to share that knowledge with fellow streamers...just because they can.
See you down the road!
TB & Greg and Abbey Schnauzer
#3954
Old 09-29-2008, 04:15 PM   #18
urbanfood's Avatar
Venice , California
it's a flying cloud as already pointed out but i'm not sure it's a '56. do you have the VIN # located near the door?
i have a '56 and my access panel is on the curb side, yours is in the rear. mine was made in los angeles, yours was made in ohio so that could have been a difference between the two, not sure. the VIN # will tell you for sure, if you can look it up and post it, that would be great. the street side windows are different as well. my guess a '55 flying cloud.
your cloud as is is worth around 3K or so, probably worth 20kor so all fixed up. you could easily spend 10K-15K in the restoration process if you did more of the work yourself.
i'm in the process of a shell-off renovation, here's my cloud for reference;
http://www.airforums.com/forums/f411...oud-27533.html
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 12-29-2009, 09:16 AM   #19
Melody Ranch's Avatar
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I need some info.....ready for the move
Can anyone familiar with the Flying Cloud tell me the hitch height....for my hitch ball set up?
What information is there on this type wheel well....on a 56 Cloud?
Will a 225 x 75 x 15 tire fit (replacing the 700 x 15 on it now.) I read on one of the Cloud Forums that some trouble ws involved with this update.
Help, help i need somebody help socool69 Hitches, Couplers & Balls 9 12-09-2014 05:24 AM
Help me identify my 1956 Airstream please! Ravyn1711 Airstream History 11 11-07-2010 12:34 PM
1956 Sovereign...help! mjmcwhorte 1955 - 1959 Sovereign 2 09-25-2005 04:50 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
New tires for my 1956 Bubble.... kzener40 Tires 8 07-27-2002 12:41 PM
