Old 08-25-2011, 11:35 PM   #99
MontanaAIR's Avatar
1958 22' Flying Cloud
Billings , Montana
I'm still here!
I'm still here guys! Just rounding out a great summer and spending a lot of time in the mountains with my wife and boys. The trailer is fully gutted down to the ribs and bare floor. Before moving forward I'm going to get the trailer weighed. I'm curious how much it will be when we are done! Going to get working on the body, windows, focus on floor/frame and start mapping out electrical. I'll post some pics!
MontanaAIR is offline   Reply With Quote
Old 10-18-2011, 02:55 PM   #100
MontanaAIR's Avatar
Billings , Montana
Replace Tongue? Ready to lift body, windows removed.
Fall is holding on and allowing me to do work! Windows removed and new glass is ordered - going with tempered to ensure safety. Shell has been braced inside and should be separated here in the next week from the floor. Still working out the axle details here locally and have been torn with torsion vs. original springs. I am however going with straight axle to give a little lift to the trailer for towing.
One reason to remove interior end caps - bird's nest and wasp nest! Birds must of been there for years!
Help me here - the tongue worked flawlessly while towing the trailer back home 450+ miles. Should I replace it? The jack lift works great too but I have tried everything to get the wheel off the bottom and fear that cutting it off is the only way to remove it. So a new lift is in the future too?
ID:	143106   Click image for larger version
ID:	143108   Click image for larger version
Old 10-18-2011, 03:06 PM   #101
ddstech's Avatar
Folsom , California
I had my coupler and jack replaced. Just wanted the assurance of having something more modern and possibly safer.
ddstech is offline   Reply With Quote
Old 10-18-2011, 04:35 PM   #102
nmbosa's Avatar
Nowhere , Washington
I'm very happy with my conversion to torsion axle from the original springs. A buddy of mine who did the conversion on his '59 Flying Cloud did all the welding on mine. Check out his blog entries on the frame and axle. Might have some helpful tips since you have the same trailer.
Frame work
Axle
I kind of regretted replacing the toungue jack before it had failed. I really like the look of the original jacks with the rivets, and the heavy duty steel wheel. However, if it fails and drops the trailer on its nose, that would really suck. Probably better to replace it.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 11-17-2011, 01:26 PM   #103
MontanaAIR's Avatar
Billings , Montana
Restoring / Polishing Windows and the small stuff
Until I can get my trailer indoors to work on it I have been fixing and polishing up the windows. It definately is a process but the results are fun and fantastic! I started on the bathroom window just in case I messed something up, it wouldn't be a main viewed window and it's smaller than most of the other windows. Devil in the details, original screws from the main center brace are not immune to some polishing! Also cleaned up the window hardware and loved the idea of hammered steel paint as seen in other posts. Now just waiting on VTS to get galvanized screen back in stock to put everything back together.
ID:	145465   Click image for larger version
ID:	145467   Click image for larger version
Old 11-17-2011, 01:38 PM   #104
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
WOW!!! Those look great. You should go into business just doing windows.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-17-2011, 10:27 PM   #105
MontanaAIR's Avatar
Billings , Montana
FF
Thanks Brad! My wife says the same thing! Really enjoy fabrication and working on the trailer, who knows what the future may hold! Speaking of windows, I have you on my list to get in touch with. I would like to re-create the front window caravan sticker I posted about months ago and you mentioned you could help out, I will message you.
Old 11-17-2011, 10:33 PM   #106
MontanaAIR's Avatar
Billings , Montana
Originally Posted by nmbosa View Post
I'm very happy with my conversion to torsion axle from the original springs ....
I kind of regretted replacing the toungue jack before it had failed. I really like the look of the original jacks with the rivets, ... Probably better to replace it.
Norm
Thanks Norm, definately some great info you provided on the axle issue. Your buddy's blog is great! Really enjoyed the material and info, I've bookmarked it for future reference!
Old 11-17-2011, 11:01 PM   #107
MontanaAIR's Avatar
Billings , Montana
Replace Jack and Coupler
Love your '58 and I've taken your advice. New coupler and jack on its way. I have to cut the sweet old wheel off the jack to remove the jack but the wheel will stay with the trailer.
Jeremy
"The one who says it canít be done should never interrupt the one doing it."
Old 11-20-2011, 09:51 PM   #108
ddstech's Avatar
Folsom , California
Windows
What tool did you use to polish the window frames? They look perfect.
Old 01-19-2012, 06:43 PM   #109
mapleton , Utah
post #95
Just FYI I bought the flying cloud from Jason in Sept. It is now down to the frame and shell and believe me the extra parts are much appreciated.
I also saw his other caravelle project and it is very nice indeed!
Tim
rumrunner is offline   Reply With Quote
Old 01-23-2012, 01:09 PM   #110
MontanaAIR's Avatar
Billings , Montana
Tim
Hi Tim, That is great to hear! Jason is really a great guy and has a true passion for Airstream restoration. He came all the way from Utah to Montana for those parts, I was happy to see them go to a good home! Keep me posted on your Cloud project.
Jeremy
Old 01-23-2012, 01:13 PM   #111
MontanaAIR's Avatar
Billings , Montana
I've been using a bench buffer with incredible results. Takes steady hands and good movement to make sure the frames don't zip off into space or my face! Gloves and eyewear protection are a must. I'm going to post a video soon on a blog I started of the process.
1958, flying cloud, montana, restoration, vin
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
F150 towing a 25 FB Flying Cloud Forger Tow Vehicles 7 03-24-2011 07:59 PM
Monogram plaque on 1958 flying cloud johncurtis Airstream History 21 03-18-2011 09:48 PM
2011 Airstream 20 FLYING CLOUD 2011 eBay Watch Airstreams on eBay 0 01-21-2011 06:20 AM
1950 Flying Cloud Needs Window Replacement happy123 Windows, Doors, Locks & Vents 2 01-10-2011 05:56 PM
