Old 03-08-2012, 05:48 PM   #1
Melody Ranch's Avatar
1956 22' Flying Cloud
1956 16' Bubble
1947 22' Liner
Valley View , Texas
Images: 78
Dooor lock/window relationship
Over the years, and after looking at numerous Flying Clouds of the early/mid fifties......I have noticed a correlation between the broken H-20 Door lock handles and the broken/mangled small opening windows beside the doors. If the handle is broken...the small window is too. It appears as though the ham fist who broke the handle then decides to gain access by breaking (usually prying and mangling the small aluminum window frame, figuring that it is smaller, therefore, cheaper to repair.) right beside the door. PLEASE!....if it is you.....break the large window and do not mess up the small window frame.
By the way.....if you have an extra Flying Cloud small window frame could I get it from you?
No! I am not the ham fist that did the damage here.
Old 03-08-2012, 06:03 PM   #2
mapleton , Utah
If you mean the small crank operated windows at either end of the front gaucho, I will probably be removing mine as I will be going back in with a dinette and they interfere with the seat backs. How soon do you need one?
rumrunner is offline   Reply With Quote
'72 Overlander window sealing...???? Sodbust Windows & Screens 5 05-17-2012 07:12 AM
Replacing window glass in '50s Airstream zgears Windows, Doors, Locks & Vents 3 03-03-2012 07:36 PM
Removing window entirely jtsanchez Windows, Doors, Locks & Vents 8 02-28-2012 06:39 PM
Broken window - how to replace? MyParadise 2002 - 2005 International 0 02-27-2012 11:22 AM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
