11-09-2006, 07:08 PM
#21
West of Fort Worth
Good pictures - that always makes these progress reports come alive. You have entered a huge project as you know - these progress reports will probably help with your motivation because other members will show interest and make suggestions, or relate what they did on their project. Good luck, keep posting!
11-10-2006, 08:35 AM
#22
1967 22' Safari
1960 Caravel
Edmonds
Good progress so far! You gotta love it when you have an Airstream that passed through the hands of a creative PO - just never quite know what you'll find. Good luck and keep posting your progress!
Mel
11-10-2006, 09:30 AM
#23
1963 16' Bambi
Yreka
Howdy Urbanfood, I have a 1955 FC that I've taken the shell off. My wife and I were so busy traveling in our 63 Bambi this summer that I didn't get any farther on the project. Know that it's winter I plan on getting back to it. Your trailer looks to be in much bettet shape than mine was. I plan on doing my own thing with the design of the interior when I get to it. Great pictures. Keep them coming. Have you worked on any interior plan ideas yet. I'd be interested in your ideas.
Don
11-10-2006, 12:52 PM
#24
1956 22' Flying Cloud
Venice
thanks for the kind words. don, i've been following your FC post, great work. i'm hoping to get the shell off within the next week and hopefully have back on within a month.
here is the floor plan i'm going to do. i need to figure out the details of the wet bath, but it should work. the only portion going to the ceiling is the wet bath walls and the vent for the kitchen sink. i'll shroud it in metal or something cool. the wall at the end of the kitchen counter toward the bed is a little higher than the counter to give a little more privacy but keep things open (it can't go to the ceiling because of the window). the low space between the bed and wet bath can be storage. i put the kitchen curbside because i wanted the gaucho in the location i'm showing it because that's a good place to sit and look out the door and window.
here's what i have planned for plumbing/electrical locations;
black, grey, and freshwater mounted in the floor on both sides of axle.
hot water heater and water pump under the sink.
furnace under the gaucho. does that make sense?
battery box under streetside dinette w/ 2 27 series batteries with fuse box converter and other electrical stuff. one thought is to put the batteries on the tongue behind the tanks (would this make the tongue weight too heavy?). is there something i can put on the other side of the dinette to counter balance? also, what about sleeping over the batteries even though they'll have a vented box and they'll be at your feet?
i can fit a house a/c unit in the window above the gaucho for the couple of months i'd actually need it. that way i don't have to disturb the profile of the roof and i don't need permanent a/c. plus i already own the a/c.
i'm going to install a couple of fantastic fans at the existing openings at each end of the coach in the ceiling and have one for air intake and the other for exhaust.
two burner stove with convection microwave below.
the above are only my thoughts so far (and not necessarily correct) and any feedback or recommendations is welcome as this is an evolving process.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
11-11-2006, 12:34 AM
#25
West of Fort Worth
Yes, that's where many of them are, including my '72 Globetrotter.
Some folks get nervous about putting a second battery on the tongue but I've seen it done.
If the battery is in a sealed box, and vented to the exterior I see no issues. Perhaps someone else sees a problem that I don't.
These are great, work good
Dave
11-11-2006, 12:40 AM
#26
1963 16' Bambi
1962 22' Safari
Yreka
I vote no on the AC in the window... We have one installed under the goucho... others have done the same. No sense in spoiling the view... But, I know how we need our AC in the summer... so sometimes we do what we gotta do...
Keep up the good work, maybe it will inspire my hubby to work on his flying cloud! (Better weather would, for sure!)
Mrs. NorCal Bambi (traveling in S Tardis)
11-11-2006, 08:19 AM
#27
1951 21' Flying Cloud
Western
, Kentucky
One small thought. If you reverse the hinges of your wet bath and swing the door the other way you could create a semi private space for changing clothes in the back of the trailer. With careful planning you could create a door large enough to go completely across to the opposite counter area. Your children may be small now, but they do grow up.
Greg Jones
11-11-2006, 08:30 AM
#28
1963 16' Bambi
Yreka
urbanfood, thanks fot the floor plan. I like your layout. We will probably go with twin beds in the back. Crawling over someone in the middle of the night is not the best idea when one gets older. Sleeping all night doesn't seem to be an option. Don't know if you have looked at Uwe's thread yet. he put his airconcditioner under and on the inside.
Don
11-11-2006, 10:29 AM
#29
Venice
i like the idea of the a/c under the gaucho instead. does anyone have any pictures of that installation? i'd want to do it so i can take it out, i.e. a nonpermanent solution. i could install an access door that is closed and locked when the a/c is not in.
captain jones - love the idea of reversing the door swing. i can certainly make it so it just about goes to the counter area. that will create a great little changing area. thanks for that idea!
norcal - i thought about the crawling over each other but my wife are still in the cuddling phase of our marriage so hopefully the bed will work for the next several years. if it changes, i could always sleep on the floor
david
11-11-2006, 05:28 PM
#30
1971 21' Globetrotter
Arvada
cool
Great minds must think alike, as I am planning an almost identical floorplan for my 1971 21' Globetrotter. I will have a window in my bath area though. I need to also install a gray water tank and I really need to start looking for a black water tank to wrap aroung the wheel well.
11-11-2006, 10:06 PM
#31
1963 16' Bambi
Yreka
Laughed out loud. Thanks.
Don
11-12-2006, 05:24 PM
#32
Venice
david
11-13-2006, 08:37 AM
#33
Fullerton
No David your not missing anything. Here is how it went together:
1- plywood with insulation stapled to bottom was bolted to frame
2- c channel screwed to plywood floor
3- bellyskin wrapped around bottom and riveted to channel to hold in place
4- shell back on, shell, u channel, and belly skin riveted together.
I didn't realize that you were moving this fast....very good. Just remember to make a floor pattern before it starts to fall apart on you. Back in the 50s the curves could vary from side to side and it will be a pita to get your shell back on with a bad fit. A lot of people don't have a floor to work with and lower the shell down and trace around it for a floor pattern.
I numbered and marked our c channels on the floor pattern that I made. Some of the channels got too tweaked to reuse but at least we will know exactly where to attatch to the floor and what sizes to make.
I don't know if it has been mentioned to you yet but...do not throw anything away. Even if you are planning to have new cabinets the old cabinets will come in handy for patterns of the wall curves. They really don't take up much room when you pack it away neatly. We have our whole interior stacked in a small space.
Even if you are doing a new interior, people that are doing a restore will really appreciate the smallest of parts. You can pass them on or ebay them to help pay for your new stuff.
Great to see your progress. Thanks for posting!
Lynn
11-13-2006, 09:30 AM
#34
Venice
hi lynn,
thanks for the clarification on how it goes together. that's what i thought but i guess with all the pages i've been reading, it's easy to get confused and i was expecting something different, but now i get it.
i did save all the cabinetry work. the PO really did a hack job on some of the stuff and modified some of the cabinetry. the curved panels will be useful for templates. i'm excited to reuse the overhead bins as they're aluminum, nice and light and should clean up nicely. what i essentially bought was a shell.
did you remove all the interior panels? i'm a little worried about removing the 13 interior panels from the front and rear and getting them lined back up and looking correctly.
david
11-14-2006, 12:35 AM
#35
Fullerton
Havent done it yet but it is my understanding that the upper ends don't need to come apart completely. You actually leave most of it together and just remove rivets that connect the edges so it comes out in the dome shape with most of the pieces still riveted together. I think it would be a bear to get it back together if you took every piece apart.
We just have the lower skins off now and don't plan to remove anymore until we start rewiring. We may try to work around taking those ends out if we can.
On first thought we wanted to replace all of the insulation until we took the lower skins off and saw how clean everything was. It pretty much looked like new. I think I will be able to sleep in there if we don't replace the insulation behind those ends if thats the only reason we have to get in there.
Lynn
11-14-2006, 12:54 AM
#36
Fullerton
I forgot to mention something from your previous post regarding the window air conditioner...John and I were at a rally in Temecula and it was scorching hot out there. A couple of people had portable scaffolding rigged up with window air units sitting on them and blowing into a side window.
I had thought about doing this and taking one of our small window units with us as needed. I am not much of a desert camper so it will be a rare occasion that we should need air when camping so I hate to take up valuable space for a couple of times a year. Also can't use air unless you have hook ups or run a generator.
I wouldn't permanently install an air conditioner hanging out a window but as an occasional solution this worked. We took some pictures of the set up and have them here somewhere.
We may just install one under the gaucho. Uwe did a really nice install on a window unit under his bed. It is in his 63 for me thread.
Lynn
01-28-2007, 02:18 PM
#37
Venice
hi all,
after a two a half month hiatus, i'm ready to get back to work on the cloud. between the holidays and the fact that i just finished studying for my california oral architect's exam, i haven't had any spare time. now i can see how these projects can drag on for a year or more
looks like there's lots of activity to catch up with on the board. i'm going to get the framing installed this week and get the shell ready to pull off (just in time for the rainy season).
good to be back here.
david
02-09-2007, 11:08 PM
#38
Venice
finally it's off!
david
02-09-2007, 11:48 PM
#39
1963 16' Bambi
Yreka
It's looking good. What a great step to have completed. Also great that you "C " channel is in good shape.
Don
02-10-2007, 04:54 PM
#40
Venice
"nasty" is my word for today. it took me about 4 hours to remove the bellypan and it was absolutely dirty and disgusting. i think it'll be the worst part of the job.
the belly pan was in four major pieces and a couple of minor ones and i was able to save them which will help me make the template for the new bellypan which hopefully won't be too bad.
the floor is in bad shape, however it is still together, so i need to figure out how to make a template. the curved portions of the c-channel are in great shape and are made of a stiffer aluminum. the straight channel pieces are pretty good for the most part but the aluminum is flimsy.
on first inspection, the frame looks to be in good shape. the PO cut a piece out of a couple of the outriggers to make room for a drain pipe but those can be easily replaced. i may add a few more in too.
david
