Old 06-29-2019, 04:47 PM   #1
Colfax , California
While checking out battery terminals today...
I discovered what appears to be a severed wire on one of the electrical devices.
Might be that cutting the wire is a particular setting. Have an email in to dealer to get some clarity.
ID:	344853   Click image for larger version
Bborzell is offline   Reply With Quote
Old 07-01-2019, 05:50 PM   #2
Colfax , California
Cancel the investigation...
This wire gets snipped when AGM batteries are installed in the system.
Never mind.
Old 10-09-2019, 08:36 AM   #3
2017 Basecamp
Preston , Washington
So, I just installed new AGM batteries. Do I snip the wire? What’s it for?
Donnh is offline   Reply With Quote
Old 10-09-2019, 09:28 AM   #4
2012 Avenue Coach
Corpus Christi , Texas
The Atkinson solar controller is pretty well accepted to be lousy. Get yourself a programmable mppt Victron 100/30 or 75/15 with built in bluetooth. Then you can use the load out connection on the new controller to re-purpose the cat5 wire that runs to the beautiful milled-aluminum Sunexplorer display and replace it with this to gain a couple of usb charge outlets.
rowiebowie is offline   Reply With Quote
Battery connectors popped off terminals Knudsvig Batteries, Univolts, Converters & Inverters 23 10-28-2017 06:57 PM
Airstream Parking near Cruise Ship Terminals 64airstream On The Road... 13 09-23-2016 12:31 PM
Battery Terminals Hans627 Batteries, Univolts, Converters & Inverters 3 06-13-2016 06:43 AM
Need help - battery charging terminals Nightwatch Batteries, Univolts, Converters & Inverters 3 04-17-2012 08:58 PM
Exposed battery terminals nickcrowhurst Batteries, Univolts, Converters & Inverters 7 12-20-2008 02:51 PM
