Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Base Camp
Old 09-14-2016, 01:36 PM   #81
Mantua , Ohio
What is that in front of the tire? Drain, stabilizer down? Very low! If that is is the sewer drain, wow!
Old 09-14-2016, 03:19 PM   #82
Sag Harbor , New York
Wow!
98% sure that is the drain and the storage tube just forward of it. [edit -- viewed on my 15" laptop with the attachment opened up -- pretty clear IMO]
Could they make it any lower?
Even a small boulder sticking up is going to do some damage as the boondocker tries to navigate into certain sites.
"No Pass" on BC2!
PS -- thanks for the links and image SilverGate.
PS2 -- Look under the streetside rear quarter -- there is that anti-tip protrusion sticking down, I thought I had seen, like a soft-bottomed "V". That is gonna get sheared off in no time IMO!
PS3 -- At least one photo in the slide show does not show any sewer drain, perhaps for the basic model with a Marine-type self-contained head? Or did they use progress photos which do not show the finished product? TBD!
Old 09-14-2016, 03:26 PM   #83
cameront120's Avatar
1972 25' Tradewind
Does Airstream ever do any consumer testing before releasing a trailer to the public? It seems that the too low sewer drain, etc. would have been identified and eliminated prior to production had they done so. Looking at it, it seems so obvious I'm surprised they let it out the door.
North Vancouver, BC
Old 09-14-2016, 08:04 PM   #84
wkf
Elkton , Maryland
Saw one at the Hershey RV show today. Wish I had seen this about the drain to check it out. The back windows did look to be just vent windows, which is disappointing. Unfortunately, they did not have either tent.
It does seem quite nice.
wkf is offline   Reply With Quote
Old 09-14-2016, 08:55 PM   #85
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Welcome to AirForums!
SilverGate is offline   Reply With Quote
Old 09-14-2016, 08:59 PM   #86
SilverGate's Avatar
2007 23' Safari SE
Airstream Basecamp in the news:
Airstream compacts its sleek aluminum construction into Basecamp trailer (again)
Old 09-15-2016, 02:02 AM   #87
Thanks for the link. The photo in the middle of the article shows the sewer dump quite clearly:
http://newatlas.com/airstream-baseca...=true#picture5
and it sure looks low . . .
From the article:
________________________________________________
Airstream's CEO and president Bob Wheeler puts it like this:
"All you need to do is head out and decide whether to go right or left at the end of your driveway."
Just make sure you don't turn too sharp to the left as you leave the driveway, especially if the curbing at the street is fairly high.
Old 09-15-2016, 03:43 AM   #88
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
But picture, I think 11, clearly shows a protective cover with 2 latches. It looks like it would be latched closed for travel.
SeaLevel is offline   Reply With Quote
Old 09-15-2016, 04:20 AM   #89
Maybe, but then why show side views with it on the road with that bulky assortment hanging down? Also, where is the storage tube in the "clean" side view?
That clean side view is either a progress print of an incomplete Basecamp, or maybe a stripped down basic version without options. Let's look at the Specs page and see what is Standard and what is Optional.
Edit -- the features page says the China Toilet is standard FWIW.
https://www.airstream.com/travel-tra...camp/features/
Hopefully the dealers can chime in here.
PS2 -- SeaLevel, the hatch with two clasps ["protective cover"] is ALSO visible in the top photo which shows the bulky drain assembly hanging way down, so guessing the electrical shore power cord is inside that hatch? TBD.
PS3 -- In the clean side shot, there is no hint of the black/grey holding tank which is visible in many of the other shots from both sides IMO. I am increasingly thinking this side shot from the street side was taken during the design and prototype phase of this project, and may not be a final version. IMO
Old 09-15-2016, 04:33 AM   #90
Dealers -- Please clarify the sewer drain questions being discussed, when you can. Photos with a tape measure showing ground clearance would be helpful. Does the entire bulky assemblage pivot up into the body, to be hidden behind that small door? Or is the "clean"'side photo of an incomplete trailer, a "progress print" if you will?
Please also detail the waste water holding tank location, and it's apparent absence from the "clean" side shot in which there is no sewer dump assembly hanging down in front of the street side tire.
Peter
Originally Posted by Overlander & Sea View Post
P
Not sure on the exact date, but our demo (which will also be our first) should be here next week.
Originally Posted by ellenbelle View Post
Also, regarding the waste pipe near the ground... I can't imagine that is so. They made a big deal of telling us that the design has taken into account that the Basecamp will be going over rough terrain (thus the slight upturn in the back, for going up steepish hills). It's probably a camera angle...
Old 09-15-2016, 04:55 AM   #91
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale , Arizona
Maybe AS will offer their usual fall discounts?
cactusjk is offline   Reply With Quote
Old 09-15-2016, 05:50 AM   #92
Mantua , Ohio
If it has a cassette toilet there would not be a normal black tank, only a tank probably serviced through outside.
Old 09-15-2016, 06:44 AM   #93
Mantua , Ohio
The pictures from the west dealer showed a cassette toilet, maybe a regular one is an option. I'd go with the cassette if it helped ground clearance.
Old 09-15-2016, 07:03 AM   #94
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
https://m.facebook.com/story.php?sto...63186110368190
Courtesy of Colonial
MICHAEL
Old 09-15-2016, 07:20 AM   #95
Thanks Michael, that video is not on their YouTube channel yet, but should be soon IMO:
https://www.youtube.com/user/colonialairstream
Not a member of FaceBook here . . .
Peter
Old 09-15-2016, 07:26 AM   #96
Mantua , Ohio
Is this the video where he mentions a porcelain toilet and tanks? If so, why did the pictures from the dealer out west show a cassette toilet?
Old 09-15-2016, 02:18 PM   #97
The video Michael posted works on my iPad. Patrick says it will be posted on their YouTube site as soon as possible.
Old 09-16-2016, 09:20 AM   #98
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Had a canned response from the local dealer from entering the information to download the brochure.
Will be interesting to see how long these initial units sit on the dealer lots.
Old 09-17-2016, 10:47 AM   #99
Wondering if the demo models have arrived at any of the dealers yet?
No new videos on Colonial's YouTube site yet -- probably after the Hershey show next week?
Their FB video on the Basecamp works now from this page:
https://www.facebook.com/Colonial.Airstream/?fref=nf
but the sound is inconsistent here FWIW. [down the page a bit]
Peter
Originally Posted by denver133 View Post
Local dealer here in Denver quoted me a fully loaded at $40k and will have one hopefully by this upcoming weekend.
Originally Posted by switz View Post
Desert Autoplex in Mesa says they will have a total initial allocation of nine units not including the "Demo".
Originally Posted by DrSig View Post
Yup, I was there Saturday, they don't have it in yet, but will be getting it in soon. Can't wait to see it.
Here on the central coast we will also be getting our demo in at the end of the week and we apparently have six coming to each store (we have two locations). I believe they have been ordered with all the options as well, but won't know that for sure til we see them.
Old 09-17-2016, 05:31 PM   #100
Bethany Beach , Delaware
Can a Jeep Wrangler Unlimited w 3500# capacity handle the BC?
Jrobert19930 is offline   Reply With Quote
New Airstream Model -- Base Camp yukionna Base Camp 61 12-30-2022 10:02 AM
Base Camp Anyone? Foiled Again Base Camp 61 08-30-2010 09:55 AM
First Trip in the Base Camp Caryl Base Camp 37 05-11-2007 10:24 PM
Base Camp Taillights 48_liner Lights - Interior & Exterior 8 03-03-2007 09:39 AM
A Base Camp In Person Chaplain Kent Base Camp 22 11-12-2006 05:41 PM
