Old 11-08-2018, 03:06 PM   #1
2018 Basecamp
Fircrest , Washington
Using tank heaters while towing
Hi, new to forums so please excuse any gaffes. Have a 2018 basecamp and am wanting to travel in cold weather. I understand the furnace/water heater supplies heat to fresh and waste tanks to keep from freezing. The basecamp also has a 12v tank heater. I donít want to use propane while towing and am wondering if there is any reason the 12v tank heater canít be used while towing. I imagine the tow vehicle would keep the battery charged. Thanks for the help
Ccube is offline   Reply With Quote
Old 11-08-2018, 03:58 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The tank heater pads are likely good for about 10 degrees of protection. If your TV is supplying 12V to the Basecamp (some do / some don't) there is no reason not to run the heater pads while towing. If there is no 12V from the TV then it's a good way to kill your battery on a long drive.
The risk here is that the tanks really are not as big a deal freeze wise as the faucets and drains. (= faucets are small and freeze quick, tanks are big and freeze slowly). You also want to be sure that the inside of the trailer stays warm(ish) while you are running down the road.
Old 11-08-2018, 04:19 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I just run the furnace when in transit and itís cold out. I run the fridge too (on 12v/propane). No biggie and the trailer is warm and food is cold when I get to where Iím going
wulfraat is offline   Reply With Quote
Old 11-22-2018, 10:08 AM   #4
2018 Basecamp
Memphis , Arkansas
Glad to have solar to stay powered up on battery.
BC18 is offline   Reply With Quote
Using frig while in transit B&J On The Road... 64 07-04-2015 07:42 AM
Avoiding Chicagoland while towing? EZ-Pass when towing? JustSomeGuy On The Road... 86 04-24-2015 11:33 PM
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 11:20 AM
Fridge on or off while not using moho? Alumatube Refrigerators 5 08-14-2007 10:36 AM
Using gas water heater while in transit phippsto On The Road... 3 01-24-2006 07:18 AM
