Old 06-04-2009, 04:51 PM   #1
Clarksville , Tennessee
Towing
Anyone towing a basecamp with a minivan? Number wise mine will tow the weight but I am wondering about the real world application, I was looking hard at getting a Truck and then a slide in camper but a base camp will bet me out and camping quick with less of an investment and then in a couple of years I can get the truck and camper and still use the basecamp for the kids.
JJ
jerryleejr is offline   Reply With Quote
Old 06-05-2009, 11:35 AM   #2
Anyone?
Old 06-05-2009, 12:04 PM   #3
Road Ruler's Avatar
Images: 38
For many years we towed our 23' Safari with a Nissan Minivan. Worked great with no issues.
What year and type of Minivan do you have?
Old 06-05-2009, 05:43 PM   #4
2009 Toyota Sienna
Old 06-05-2009, 07:40 PM   #5
SteveH's Avatar
Common Sense , Texas
Just curious....what does a Basecamp weigh? I would think you could tow it with almost anything.
Old 06-05-2009, 08:07 PM   #6
Max GVWR is 3500
Old 06-05-2009, 09:07 PM   #7
Road Ruler's Avatar
Images: 38
The 250HP Sienna is much more capable than our 150 HP Nissan. Get the connection and set up right and the Base Camp should be A1 to tow.
Old 06-05-2009, 09:08 PM   #8
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
We have an '06 Tacoma and I find the tongue weight to be the issue. The trailer itself is only 2000lbs empty and tows like a dream... but I cannot lift the tongue myself... I'd estimate it is at least 400lbs on the tongue.
No one seems to know if a WD hitch will even work with the Basecamp - or at least no one has chimed in here... I'm also looking at an airbag kit, but that doesn't really address the tongue weight issue - it just masks it...
Friday is offline   Reply With Quote
Old 06-06-2009, 06:01 AM   #9
SteveH's Avatar
Take a look at this hitch: Single Bar Weight Distribution for Pole Tongue Trailers 3204 : Trailer hitch bike rack and trailer hitches - etrailer.com
It is designed for smaller trailers with a pole type tongue.
Old 06-06-2009, 09:32 AM   #10
2007 Base Camp
I'd like to find some actual measurements for the thing... as it's the only one I think might work. The issue with the Basecamp is there is very little tongue to work with. The LP/AC cover takes up even more space, and the jack can only be mounted in one spot really. It's not even long enough for a swing up jack to be mounted.
I've also seen an adapter that let you use a normal a-frame WD kit with a single pole trailer. I don't think I need a 2 bar setup, but it might work better (or worse) depending on the length of the bars and where the adapter ends up.
It's fairly cheap, but $150 to get it shipped to me, so it's an expensive experiment...
Old 06-07-2009, 09:09 AM   #11
2007 Base Camp
Cypress , Texas
Towing
I've towed the BC with a GMC Envoy inline 4.3l 6 cyl rated at 5500 lbs for towing, and factoy tow package with no problems whatsoever. Even had a 800 lb motorcycle loaded in the BC and while she worked a bit in the hill country...didn't have a problem. Last time out, ran into some strong cross winds and no problem handling. My son is taking my GMC Envoy at 115,000 miles (his car died) and I just picked up up a Buick Enclave SUV with a 3.5l V6 and towing pkg rated at 4500lbs. Based on my experience thus far, I don't think it will be a problem.
As to the minivan, it shouldn't be a problem, but you should check the rating for the vehicle hitch set up.
Good luck
martinto is offline   Reply With Quote
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Hooking up a WD hitch jwilson Hitches, Couplers & Balls 3 04-08-2008 05:09 PM
No towing for me. lendoyle Member Introductions 3 08-30-2006 09:22 AM
Towing - 1965 65trotter 1965 - 1969 Globetrotter 9 08-10-2003 09:19 AM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
