Old 06-23-2019, 08:14 AM   #491
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by Pocket22 View Post
I just wanted to post an update on our Dometic Fridge RM 2551 in our 2017 23FB Flying Cloud (manufactured in 2016). After picking it up from the service department, it will not work well on shore power, but performs wonderfully on LP. We have run many tests—repeating them before I reposted, —ambient temp, counter temp, inside fridge and freezer temps using regular thermometers and infrared. The freezer works fantastic with well below subzero temps on either shore or LP. The fridge is the only issue on shore power. However, we need for it to work on shore power.
It seems, that if a refrigerator is advertised and engineered to run on either shore power or LP, that it should be able to do both. Our fridge will not cool to food safety temps on shore power, even if ambient temps are temperate and with the addition of three, yes, three fans. Our camping friends tease that we sound like an F-16 preparing for take-off.
Has anyone experienced this same issue—fridge working fine on LP, but not shore power? If so, were you able to have it repaired? The thermistor and cooling unit have been replaced and the fridge area has only worked anemically in shore mode from day of purchase with temps ranging from 45-55 not over-packed with food and minimal opening of door to retrieve food, etc. It is as if it can not recover quick enough to ensure safe temps. Ironically, through all this, the freezer works well, again, on either power.
Thank you kindly for any words of wisdom. I'm glad we joined this valuable group!
Hi
There is only one cooling system in these gizmos. The same system cools the freezer as cools the fridge. If the freezer is getting down to your target temperatures, then the system *is* working. If it gets to the same temperatures on propane as on shore, it is working the same on both of them.
The temperature in the freezer vs fridge sections is purely related to the position of the sensor. You move the sensor to adjust things. Yes it's clunky and not a pushbutton sort of thing. It is how you do it. Too far one way and the top of the fridge freezes. Too far the other way and the fridge is too warm.
If shore power is what bugs you, adjust it when on shore power. Figure on leaving it alone overnight (door closed, normally loaded) before you check the adjustment. The same thing is true of checking temperatures. It takes a while for these fridges to stabilize.
uncle_bob is online now   Reply With Quote
Old 06-23-2019, 08:42 AM   #492
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Treat any sales persons statements as fiction as their job is to sell. They do not have to live with the item after the buyer leaves the premises.
The Basecamp was never properly tested in the Southwest heat. The enclosure was not per Dometic design recommendation at the time from all the readings of user bad experience. The cooling issue has been there since the first unit came off the line.
So the first rule is Caveat Emperor or buyer beware. One must do extreme research before buying. Airstream is squirting the units out so fast that the quality control just does not get implemented in a uniform manner. Even the over $165,000 Classics have major issues let alone the over $200,000 Class B vans.
Airstream is relying on the, at best, incompetent dealerships to do their after the fact quality control. Airstream would be much more profitable if all issues were fixed at the factory before the units left. Then Airstreams would be worthy of their name and have a reputation of quality vs just another problem plagued RV.
Old 06-23-2019, 09:35 AM   #493
Long Island , New York
Normally I don’t like to Quote the previous post, but switz’s cogent summary is worth reading a few times IMO. Amazingly, Airstream does not appear to have been sued yet for the Basecamp fridge’s design defect, by either a consumer or Thor shareholder.
[in my personal opinion]
Peter
Old 06-29-2019, 04:11 PM   #494
Colfax , California
And so it goes...
Just prior to our road trip up north (w/o Basecamp) I called AS to discuss my ongoing problem with fridge heating up and killing food. I wanted to discuss swapping out for the compressor fridge that AS decided was a better option for new Basecamps (which was what I suggest to to them some 18 months ago to no avail).
Customer service response was that the new spec fridge would not fit without major cabinet mods and that they believed that swapping out the humongous heat sink propane box for an aluminum box was working for a number of customers (did I mention that I had made this suggestion to AS 2 years ago following surface box readings of 140 degrees to similar no avail?).
So while we were up north, my dealer ordered, received and installed a new propane box. Been busy with other stuff so I have not begun the fridge monitoring program (mainly because our summer dropped back to fall and it is currently 68 degrees outside at 2 pm).
Don’t know if it will do the trick, but I think it looks a ton better than the black box. Gotta find space for the electrical cord and jacks crank.
Stay tuned for updates.
Bborzell is offline   Reply With Quote
Old 06-30-2019, 03:43 PM   #495
Thanks for the recent update to your thread!
[Post #1 from almost two years ago -- click on orange arrow to go directly there]
Several of us have reported that the Basecamp fridge will not cool to a food safe level while on propane (which is the only option while driving).
Well done . . . to stay on top of this and hold Airstream to its commitments.
Surprising [IMO] that the company and Thor management have not seen their heads roll over such profound design defects like this, and the fleet-wide axle recall because the tires hit the body.
You can't make this stuff up . .
Old 07-05-2019, 08:23 PM   #496
dgirvin's Avatar
2019 Basecamp
Kingston , Ontario
Originally Posted by abutters View Post
Our 2019 BasecampX with a Dometic fridge is performing very well on propane and shore power.
We traveled 2600 miles so far on this trip with daytime temps while driving as high as 96 degrees and the maximum temp reached in the fridge has been 41 degrees after 6 hours on the road traveling at 65 mph. Starting temp is 33 to 34. I use a good digital thermometer that also measure humidity and keep it on the middle shelf. We always follow best practices by packing with cold food and leaving some air space.
The large and fairly loud fan does kick on and stays on until the fridge cools back to the lower 30's but always shuts off well before bedtime and the fridge is basically silent through the night.
We dry camped for several days and the big fan does kick on and off during the day but temps in the fridge stayed in the 30's. We also parked in a friend's driveway for 5 days (in an HOA no less - try that with a 25' Cloud) on shore power in direct sun in hot temps and the big fan cycled on basically the same intervals as it did with propane.
Ours is a September 2019 build date with the redesigned vents and reshaped propane cover but it is still the Dometic fridge. The Norcold arrived in December builds.
I’m having the same experience with mine. This past weekend was in the 90s with high humidity and my fridge (Oct 2019 build - propane/electric. Fridge worked perfectly, kept food cool and made ice cubes in a couple of hours. Fan only ran on propane while on the highway.
dgirvin is offline   Reply With Quote
Old 07-06-2019, 10:11 AM   #497
Colfax , California
Given that I had argued for replacing the black plastic propane tank cover from which I had recorded temperatures exceeding 140 F last year, one might think that I have confidence that the swap to the aluminum tank cover will rescue the Dometic absorption fridge from a life of killing food, but confidence has been an elusive commodity on the fridge front since we discovered our first of too many losses of food some two years ago.
That said, I am back at documenting temps and conditions now that AS has replaced the cover. I will also note ambient temperature as well as surface temp of the new aluminum tank cover and the old plastic cover which is sitting alongside the Basecamp and in the same line of sight of the sun.
As of this morning at 7 am, the outside temp was 62 as was the temp for both covers. Fridge temp was 36F with freezer at -1F.
So far so good. High today is predicted at 88F. Stay tuned.
Old 07-06-2019, 10:47 AM   #498
Colfax , California
That did’t take long...
It is 9:40 am and the outside temp is 80F. Here are some readings with photos.
Difference between how the two covers deal with radiant/reflective heat is pretty telling. The side of the Basecamp was 120F. Over 150F for the plastic tank cover is pretty incredible. The aluminum cover is at 100F.
Fridge is creeping up toward 42F, but I might have caught it on the high end of typical fluctuation. Additional readings will answer that question. Freezer is close to the reading from earlier this morning.
Sorry about the 90 degree flip.
ID:	345602   Click image for larger version
ID:	345604   Click image for larger version
Old 07-06-2019, 02:06 PM   #499
Colfax , California
12:30 pm 85 degrees BC not in direct sun
Black plastic propane cover is 122 degrees, aluminum propane cover is 94, freezer still at 1 degree but fridge box has risen to 46.5 (beginning to think that the box is not well insulated). Exhaust air from top vent is 105.
Old 07-07-2019, 09:21 PM   #500
2019 Basecamp
NA , Louisiana
Was this experience entirely on propane? No shore power used at all?
LABC is offline   Reply With Quote
Old 07-07-2019, 09:26 PM   #501
2019 Basecamp
NA , Louisiana
Are you using shore power to get the initial temps down? My 2019 BCX will not take the temp below 60's on propane in 95+ degree weather.
Old 07-08-2019, 02:43 AM   #502
dgirvin's Avatar
2019 Basecamp
Kingston , Ontario
I ran the fridge for the first 1 1/2 days on props to get it cooled down. It had made ice cubes by the end of the first day. Fan ran most of the day while on propane. After 2 days I was on shore power and it worked perfectly. The fan never came on on shore power. Last day was back on propane with fan running most of the day and temp stayed the same.
Old 07-08-2019, 08:17 AM   #503
abutters's Avatar
2012 25' FB International
2019 Basecamp
Yulee , FL
24 hours prior to our departure from FL we did start out on shore power. We also precooled the fridge with a couple of ice packs. But we did that with our 25' International , our class B Phoenix Cruiser and our class A Trek. It's always been the case for us that RV refrigerators cannot be expected to perform as our home refrigerator.
With that said I agree with the consensus that the Dometic fridge and the black propane cover should both be upgraded respectively to the new fridge and the aluminum cover. Because although we experienced satisfactory results traveling in June through the south and midwest I am not so sure that when we venture west in August and dry camp along the Colorado river in Moab that we will be happy with the current arrangement.
abutters is offline   Reply With Quote
Old 07-08-2019, 10:35 AM   #504
Colfax , California
There has been a fair amount of chasing temps over the past few days. This morning the box was 36 and the freezer -3. This has all been on AC here at home.
Biggest eye opener is the difference between the two propane covers. Though it is 65 degrees outside, the aluminum cover is reading 82 degrees with the sun on it while the black cover is sitting at 135 degrees. Add the large mass of the black cover to the higher surface temperature and you get an enormous heat sink.
Even with the poor cabinet ventilation design, the black plastic propane tank cover is the kiss of death to any chance of reliable heat exhaust through the front vent for any BC with the absorption fridge.
Reports of some decent performance under warmer conditions are not surprising to me as the number of variables affecting overall performance is high and changes with locality, humidity, sun angle, etc.
My suggestion to anyone with a BC with an absorption fridge who is not entirely satisfied with their fridge ability to keep food safe once the box has been appropriately cooled prior to a trip is to consider the propane cover change.
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 03:23 PM
Is it ok to run fridge on propane while towing ? steve.thomps LP Gas, Piping, Tanks & Regulators 154 06-19-2014 07:00 PM
Old vs. new gas fridge performance mcneon Refrigerators 8 01-26-2004 06:47 AM
