Old 02-21-2019, 12:58 PM   #1
2017 Basecamp
St George , Utah
Power switch position for battery charging
We are moving our 2107 Basecamp to a covered storage facility. The solar panels won't be able to keep the batteries charged. The facility does have power outlets and they recommend leaving the trailer plugged in.
Do I need the main power switch in the on position to keep the batteries charged when connected to mains power?
Lee-Robert is offline   Reply With Quote
Old 02-21-2019, 03:25 PM   #2
2014 25' FB Flying Cloud
Hillsborough , North Carolina
Battery Minder
Consider a Battery Minder.
Provides trickle charge / Desulfation.
Hook it to the batteries and leave trailer in Storage mode.
Anyone want to comment on the over-charging risk using the on-board battery charger that comes with the Basecamp for long term?
GeeSag is offline   Reply With Quote
Old 02-21-2019, 03:31 PM   #3
Long Island , New York
What does your owner's manual say?
Old 02-21-2019, 03:33 PM   #4
2007 22' International CCD
First of all, the typical Airstream's batteries won't charge unless the use/store switch is set to "use". That connects the batteries to the output of the convertor. Note that the red LED on the use/store switch panel DOES NOT tell you the thing is set to "use". It only tells you either the battery or the convertor is putting 12 volt power on the circuits of the trailer. The best way to be sure is to disconnect shore power, press "use' on the switch, and see if the red light is on at that point. That tells you the batteries are actually putting out power. Then go ahead and plug shore power back in.
That said, unless you are absolutely sure your 2017 has the newer, better 3-stage convertor installed to properly charge the batteries, you need to religiously check and refill the water in the batteries as needed at least once a month. I'm assuming you have conventional "flooded" lead-acid batteries.
Some have suggested using a plug-in timer to limit convertor power to 4-5 hours a day to avoid excess battery water consumption. YMMV.
I use solar panels to keep my batteries charged in open storage, and still, although the MPPT charger is a decent one, find the batteries in my rig (2 6 volt GC-2 Golf cart deep cycle flooded batteries in series) need a little squirt of water about once a month. I have a battery watering system that makes this quick and easy.
On edit: A battery minder is also a darn good alternative, connected direct to the batteries with the use/store switch set to "STORE."
Old 02-21-2019, 03:43 PM   #5
Is the Basecamp Use/Store setup the same as regular Airstream trailers?
Old 02-22-2019, 04:39 AM   #6
2017 Basecamp
St George , Utah
Not sure. There is an on/off battery disconnect switch. The manual says it disengages, or engages, the 12 volt power supply from the batteries to everything except the LPG detector. The switch is used to cut power when the trailer is not being used, or being put into to storage to preserve the battery charge.
Old 02-22-2019, 04:54 AM   #7
2017 Basecamp
St George , Utah
Nothing regarding charging the battery through the connection to shore power. My Basecamp has solar panels. They keep the battery charged when the battery disconnect switch is in the off (storage) position.
Old 02-22-2019, 04:58 AM   #8
Thanks, so Rich’s earlier comment probably applies . . . to keep the switch on/use when you are on shore power. The question remains whether your converter is a single stage old one or a multi stage newer design. See Post #4 on this too.
Peter
Old 02-22-2019, 05:02 AM   #9
2017 Basecamp
St George , Utah
Thanks. I'll see if my dealer, or Airstream, can tell me which convertor that I have.
Old 02-22-2019, 05:08 AM   #10
2017 Basecamp
St George , Utah
The manager of the storage facility told me that the mains (shore) power they supply acts as a trickle charger. I know that cheaper trickle chargers are not a good idea because they are always feeding a charge; whereas a Battery Tender doesn't. I'll ask him about the behavior of their power supplies.
FWIW - my Basecamp has an AGM GPL-24 battery. I believe that these are sealed and don't require adding water?
Old 02-22-2019, 05:10 AM   #11
That is correct IMO. Your AS paperwork should include a pamphlet from the mfg. of the converter.
Old 02-22-2019, 05:20 AM   #12
2017 Basecamp
St George , Utah
Unfortunately; it doesn't.
Old 02-22-2019, 05:34 AM   #13
2017 Basecamp
St George , Utah
Thanks to everybody who replied. I believe that I have my answer. The battery disconnect switch needs to be in the on position
Old 02-22-2019, 09:59 PM   #14
Life is a Highway's Avatar
2019 25' Flying Cloud
Lady Lake , Florida
Tenders
Good advice!
I have a Battery Tender 4 amp, Battery Minder is also quality. This is the best way to maintain the batteries while in storage. Make sure you are on the positive of battery one and the negative of battery two.
Life is a Highway is offline   Reply With Quote
Shore power not charging battery after battery replacement P and Y Batteries, Univolts, Converters & Inverters 15 11-22-2016 08:36 AM
Battery Storage Switch Position Chill Inn Batteries, Univolts, Converters & Inverters 14 05-20-2016 01:02 PM
81 Excella 280 battery charging switch position silverback Classic Motorhomes 11 02-04-2012 07:46 PM
can't locate six position switch on my 345 johnboy28540 Generators & Solar Power 4 03-13-2009 05:26 PM
Parts source for four position light switch overlander76 Electrical - Systems, Generators, Batteries & Solar 6 11-16-2003 08:24 PM
