Old 09-02-2017, 11:03 AM   #1
Colfax , California
New Basecamp Propane Cover?
Check out this video that came in my email this morning. If you look close, it shows a quick shot of an aluminum propane box instead of the black plastic one.
The video also shows a Basecamp with the plastic cover. I wonder if the aluminum cover is part of the proposed fix for the fridge cooling problem?
https://www.airstream.com/blog/airst..._hsmi=55913524
Bborzell is offline   Reply With Quote
Old 09-02-2017, 11:08 AM   #2
Colfax , California
False alarm
It's a shot of the early model.
Old 09-02-2017, 01:05 PM   #3
2017 Basecamp
Conway , Arkansas
I'm pretty sure that aluminum propane box was on the 2007 Basecamp. If you look at the video, that Basecamp doesn't have the side door.
Gail Miller is offline   Reply With Quote
Old 09-02-2017, 01:07 PM   #4
2017 Basecamp
Conway , Arkansas
I commented before I saw this post from you. :-)
Old 09-02-2017, 05:30 PM   #5
camperguy58's Avatar
Folsom , California
No side door, old wheel wells, the original bc
Name:	old basecamp.jpg
Pat
2012 Jumping Jack
Looking at Sport 22FB, maybe 16RB
2017 Honda Ridgeline Black Edition
Folsom, CA
camperguy58 is offline   Reply With Quote
Old 09-02-2017, 05:40 PM   #6
Folsom , California
But I do like how they send out a video raving about the basecamp, not addressing any issues, and then show the old model.....who does that?
Where's the video saying, we are working hard to make this model worth of the AS name and we will make it all right..,,
Pat
2012 Jumping Jack
Folsom, CA
Old 09-02-2017, 06:59 PM   #7
Colfax , California
It does make me wonder about the relative heat retention between the two covers. On mine, I got a surface reading over 170 in direct sun at 90 degree ambient temperature.
If a thin wall aluminum tank cover with louvers would retain 20-25% less heat, it might give the vent openings behind the tank cover a fighting chance.
Old 09-02-2017, 07:59 PM   #8
Folsom , California
Why not just ditch the cover? Better airflow, and you could keep the standard tanks (since you can swap them at almost any gas station), or go for a nice pair of polished tanks.
Pat
2012 Jumping Jack
Folsom, CA
Old 09-02-2017, 08:13 PM   #9
Folsom , California
And I was just thinking, isn't the lower vent an intake for the refrigerator - the fresh air intake for combustion - so if you had a propane leak and no shroud......?
Maybe yanking the fridge and replacing with a Yeti isn't such a bad idea. You could stack either two Yeti 35's or maybe a 35 and a 50 - not as much capacity as a 3 cu ft fridge, but no power draw and problem solved!
Pat
2012 Jumping Jack
Folsom, CA
Old 09-13-2017, 07:53 PM   #10
Colfax , California
AS told me that the black plastic cover serves an additional purpose of blocking wind blown rain from entering through the front fridge vents.
Old 09-13-2017, 08:32 PM   #11
2017 Basecamp
Conway , Arkansas
What keep rain from blowing in the vents when they are mounted on the side? Wouldn't an aluminum cover on the BS also keep rain out? More excuses for the big screw up of putting the fridge in the front. :-)
Old 09-13-2017, 09:29 PM   #12
Trae and Ann's Avatar
2017 Basecamp
Garland , Texas
I guess my plastic cover must be defective too ...
Trae and Ann is offline   Reply With Quote
Old 09-14-2017, 01:22 AM   #13
Colfax , California
Originally Posted by Trae and Ann View Post
Attachment 294773
Not sure what is happening there. We have been through hundreds of miles of rain including torrential South Carolina downpours and have had no water intrusion.
Are you sure that this isn't condensate from the fridge?
Old 09-14-2017, 05:41 AM   #14
Long Island , New York
Echo alert!
Gotta move the fridge to one side and add a roof flue IMO.
Basecamp propane cover chaeha LP Gas, Piping, Tanks & Regulators 1 03-09-2017 11:16 AM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 01:14 PM
To cover or not to cover vents? Director 1965 Overlander 4 10-28-2007 08:01 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 12:48 PM
