Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Base Camp
Old 05-19-2018, 08:16 AM   #1
2018 Basecamp
Ottawa , Ontario
Need help..truma code 45 restore voltage?
Hello...we dont know what to do with the message code 45? Somebody would know what to do? Thanks, cat
Marierca is offline   Reply With Quote
Old 05-21-2018, 06:11 AM   #2
2020 16' Bambi
ABQ , New Mexico
What are running and how when you see this message? For example: Are you running the furnace on electric?
YoungishJedi is offline   Reply With Quote
Old 05-21-2018, 06:49 AM   #3
Fort Davis , Texas
Found this link to a UK forum thread referencing Error Code 45.
http://www.ukcampsite.co.uk/chatter/...TopicID=334776
Apparently this error indicates a loss of AC power.
Pat
pdavitt is offline   Reply With Quote
Old 05-21-2018, 09:05 AM   #4
2018 Basecamp
Ottawa , Ontario
Thanks for the response...
Hello, thanks, yes the message is with the truma working on electric..for both water and or heat...we will contact our rv dealer on monday..
All is good with gaz..so thankfully, we were fine for the week end!
We tried to locate the fuse, but no easy to see...
Old 05-21-2018, 11:20 AM   #5
2018 Basecamp
Fairview , TX
Had the same problem. Called Airstream and they walked me through diagnostics. Ultimately I had to press a reset button located on the heater unit. That corrected the problem.
Airkeeper is offline   Reply With Quote
Old 05-21-2018, 02:39 PM   #6
2018 Basecamp
Ottawa , Ontario
Hello again..was the rest button hard to locate on the truma? Thanks ��
Old 05-22-2018, 02:15 AM   #7
2018 Basecamp
Fairview , TX
Truma: Removed cover on street side of Truma. Tight quarters but was able to detach the snap off cover. The reset button is at the bottom of a recessed hole on the back side of the unit connection..I used a short section of hot glue stick to press the button reset button on the back (my finger was too large & a screwdriver too stiff). Error code (W 45 H) went away and it now heats water. Works great on electricity or gas. I can possibly forward the picture that Airstream provided. Need email
Address.
Old 05-22-2018, 06:17 AM   #8
2018 Basecamp
Ottawa , Ontario
Truma - on elctric 15amp
Hello again, can we test the truma on electric on 15 amp? We arr back at home with no access to 30 amp connection.
Old 05-24-2018, 07:53 PM   #9
2018 Basecamp
Ottawa , Ontario
Smile Problem solved
The resolution was to simply re- plugged the truma ...the plug is under the bench where the truma unit us...
Old 06-01-2021, 12:09 PM   #10
2021 16' Basecamp
CHARLESTON , SC
Address.
Hi i am having this same issue and wanted to know if you could send me the picture you have? Thank you.
kpthornhill is offline   Reply With Quote
Truma AquaGo tankless water heater waninae39 Water Heaters, Filters & Pumps 41 05-06-2019 08:00 AM
Max incoming psi for Truma Combi water heater Bborzell Base Camp 3 06-09-2017 10:16 AM
Truma Info? DSM2570 Modifications 2 01-15-2016 03:17 PM
Instead of a Generator, Truma launches VeGA nmayer1 Electrical - Systems, Generators, Batteries & Solar 2 11-15-2012 08:54 AM
