Old 12-22-2018, 12:27 PM   #1
2019 Basecamp
NA , Louisiana
Max Cold PSI for Basecamp X 235/75R15 Tires
Just a heads up, my Basecamp X has an incorrect label on the side for the tires. It shows the specs for the original tires, not the X tires. Techs at my dealer said both tires use 50 PSI, which is incorrect per the Airstream documentation. See attached photo from the Airstream Basecamp Manual showing the Max PSI for the X tires is 35 PSI.
LABC is offline   Reply With Quote
Old 12-22-2018, 08:27 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You should go by what is printed on the tire itself.
wulfraat is offline   Reply With Quote
Old 12-23-2018, 06:18 AM   #3
CapriRacer
CapriRacer's Avatar
I'm in the , US
What is printed on the tire is a maximum, not a recommendation.
CapriRacer
Please visit my website: https://barrystiretech.com/
CapriRacer is offline   Reply With Quote
Old 12-23-2018, 07:40 AM   #4
wulfraat's Avatar
Agreed. I thought your post was regarding MAX PSI for your tires and where to get the correct number.
Agree that actual is likely different. I have max 80psi on my 30' and run at 65 per load charts for the tire.
Old 12-25-2018, 10:47 AM   #5
2019 Basecamp
Eden , Utah
After reading the initial posting, I checked our Basecamp X, it too has the incorrect stickers on the trailer; the stickers reference the 18" tire standard on the Basecamp. I also checked the tires, they read 350 kPa, or 51 PSI max cold pressure. I will be contacting Airstream customer service to determine a normal recommended operating pressure. LABC, thanks for the heads up.
MTB Basecamp is offline   Reply With Quote
Old 12-25-2018, 08:01 PM   #6
2019 Basecamp
NA , Louisiana
The original picture I posted is from the Airstream Basecamp Manual.
Old 12-26-2018, 06:02 AM   #7
CapriRacer
CapriRacer's Avatar
I'm in the , US
I just noticed something odd. For the Basecamp X model, the pressure specified is the *Rated Pressure* (the pressure where the load carrying capacity maxes out) for the Standard Load (SL) tire - which has a load index of 105, where for the other models, the pressure specified is the *Max Pressure* for the Extra Load (XL) tire, which has a load index of 109.
That means the Basecamp X tires are specified to have less load carrying capacity - plus they are specifying different kinds of pressure - and that just doesn't make sense.
CapriRacer
Old 02-21-2019, 02:05 PM   #8
2019 Basecamp
Eden , Utah
This is what I received back via email from Airstream, concerning the incorrect tire labeling.
"We are aware of the issue here and are working with NTSHA to correct this. There is a process that we must follow to file this properly with them. Once this is complete, you will receive a letter in the mail with instructions on how to get this done. You may notify your Airstream dealer that you have been in contact with us if you would like for it to be noted."
A call to customer service recommended an operating pressure of 50 psi; which is inconsistent with the Basecamp X manual.
Old 02-22-2019, 06:26 AM   #9
CapriRacer
CapriRacer's Avatar
I'm in the , US
There's an interesting comment in the above post:
……. " ….. and are working with NTSHA to correct this. There is a process that we must follow to file this properly with them. Once this is complete, you will receive a letter in the mail with instructions on how to get this done. …..."
Having worked on recalls, this is exactly what I would have said when a recall was being set up, but hadn't yet reached the point where it could be announced. Lots of i's to dot and t's to cross.
CapriRacer
Old 02-27-2019, 05:17 AM   #10
Bentonville , Arkansas
Just recieved a letter yesterday informing me of a recall. New stickers are on their way.
trd09 is offline   Reply With Quote
Nokian Rotiiva AT 235/75R15 116/113S RLS Tires 51 02-11-2018 02:09 AM
Michelin LTX 235/75R15 XL Upgrade? switz Tires 234 06-28-2014 03:46 PM
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
Michelin 235/75R15 LTX M/S vs Marathon ST225/75r15 EXCEL88 Tires 3 06-16-2008 07:41 PM
