Originally Posted by camperguy58
Thanks for your feedback.
So without getting into the story, I've now owned and camped in a 2017 basecamp received mid Feb and a 2018 basecamp received Sep 2.
Things I've noticed are the overall construction and craftsmanship are better on the 18. I have none of the issues that I originally had. It's actually waterproof, the table legs work fine, the doors don't open while traveling, etc etc.
Only change I've noticed is the propane lid lost the metal tabs and the lower lip so now it just flaps down. It's more water resistant than the 2017 was and quicker and easier to use. Sometimes I can even get it to magically balance in the upright position so I've got both use of my hands.
Fridge still doesn't work on propane above ~75-80 degrees but there is a fix for that, and the frame by the side door hasn't changed so don't let it blow open and shatter the glass.
I wouldn't hesitate to buy a new basecamp if you're sure the style and size is right for you!
Hope that helps some ppl on the fence.
