07-14-2019, 07:03 PM
Dillon
Ford Escape tow a Basecamp
Anyone towing a 16 foot basecamp with a Ford Escape? Currently own 2011 Ford Escape AWD with V-6/240 hp, rated by Ford at max towing weight of 3500 lbs.
Thanks.
07-15-2019, 07:36 AM
Colfax
Thanks.
I hope not. The unloaded tongue weight on my BC is 420 lbs; well in excess of the 350 max tongue weight rated by Ford. Mine travels anywhere between 420 and 470 lbs.
07-15-2019, 08:06 AM
2013 20' Flying Cloud
Westerly
, Rhode Island
07-15-2019, 08:04 PM
2019 22' Sport
High River
, Alberta
Etrailer sells bolt on receivers rated for 500 lbs or more tongue weight for about $150. A brake controller and proper wiring are needed, but apart from that I’d expect an Escape to make a decent tow vehicle. Wheelbase is short, but so is the rear overhang. I’ve driven a few and found them to be stable and decent handling. Stick with the 2.0 turbo though. The smaller engine will need constant boost to even pull a Basecamp at highway speed.
07-15-2019, 08:05 PM
2019 22' Sport
High River
, Alberta
Another comment - you will need a weight distributing hitch. Do a little digging on this forum - Andrew T has explained how to connect the chains to the trailer.
07-16-2019, 09:23 AM
2017 Basecamp
La Quinta
Towing with 2012 escape limited
I have towed my basecamp with my 2012 escape limited with the 3liter v6.. installed hitch and ebrake electronics. Not so hard. Its OK for flat and short runs. A bit hard on long grades. V6 winds up to 4500+ rpms.
Handling seems OK in the wind.
Windy roads OK too.
I have recently switched to a 2008 jeep grand cherokee, 5.7liter hemi with factory tow package. Pulls a basecamp nicely.
I think the escape with v6 is challenged some when pulling a basecamp. Short runs, non-mountain driving would be OK.
07-16-2019, 09:35 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
tongue weight will be an issue - while the FE could tow the BC not sure about axle and hitch receiver capability. IMHO you would be wise to contact FORD (not just talk to a dealer) - do your "due diligence" research, there is a lot involved to marry a TW to any AS.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
07-16-2019, 10:03 AM
Colfax
With respect to the hitch that eTrailer sells, there is more involved. They provide the common “weakest link” caution when matching the hitch up with the Escape. Here is their reply to a question about whether the hitch will allow towing greater than factory spec rating.
“The Draw-Tite Max-Frame Trailer Hitch Receiver part # 75751 is Class III hitch with a 2" receiver tube opening. It has a maximum gross trailer weight (GTW) rating of 4,500 lbs and maximum tongue weight (TW) rating of 675 lbs. While using a weight distribution system with this hitch, your GTW increase from 4,500 lbs to 5,250 lbs but the tongue weight capacity remains the same.
The above figures are accurate and taken directly from Draw-Tite. However, although the hitch is rated at 4,500 lbs GTW and 675 TW, the vehcile is likely not. Almost all of our trailer hitch receivers are rated well beyond the capabilities of the vehcile. Both the vehcile and hitch will have ratings for max GTW/TW however, the lower of the two ratings will be your limiting factor.”
There ain’t no free lunch.
07-16-2019, 11:15 AM
2019 19' Flying Cloud
Canyon Country
What I did with a search for a good TV: I did a good research for a small SUV or Crossover appropriate to tow a 3500 lb popup. Ford informed me that Explorer with V6 with factory installed package can tow up to 5,000 lbs but without the factory installed tow package, the max tow weight would be 2000 lbs even with V6 engine. The tow package consist "tow" button, wider radiator, engine & tranny cooler with sway control.
Now Escape is considerably smaller. I had originally thought I would buy an Escape but did not because from the research, the Escape would not be a good TV to tow 3500 lbs popup.
I also discovered that if I did DIY hitch, engine/tranny cooler myself, the max tow weight for the Explorer would still be 2000lbs.
I sold my popup and bought AS Sport Bambi 16 because of the limitation of safe towing . It is just a starter AS and I will move up after I buy an Expedition.
I hope you would do the same.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
07-16-2019, 02:44 PM
lookingin
Golden
Tow Vehicle Considerations
"I also discovered that if I did DIY hitch, engine/tranny cooler myself, the max tow weight for the Explorer would still be 2000lbs"
How is it possible that these improvements keep the tow capacities the same, is this from Ford?
07-16-2019, 03:18 PM
Vancouver
, British Columbia
You can increase some capacities by doing modifications, generally, but you can't change the original factory rating. The manufacturer isn't going to rerate an owner-modified vehicle.
I wouldn't worry at all about towing a Basecamp with the OP's Escape. A 3500 lb tongue weight limit is arbitrary, and is because of either the original receiver strength, or a concern for axle loads. I would look at installing an aftermarket hitch to address the tongue weight issue, and I would ensure that I did not exceed the axle weight ratings. Problem solved.
240 hp is plenty of power. That is the same as many heavier vehicles that are routinely towing 7000 lbs comfortably.
07-16-2019, 03:21 PM
Canyon Country
The DIY tow package does NOT include wider radiation, tow button that has features for transmission and suspension, and finally the suspension for towing.
The shortcut DIY hitch installation does not really work. I learned that in the hard way with my previous Explorer Sport.
07-16-2019, 03:24 PM
Canyon Country
3500 tongue weight limit????? don't you mean 350 lbs tongue weight limit?
07-16-2019, 03:49 PM
Canyon Country
FYI: I would not buy a 22 ft AS Sport which weights 4600 lbs fully loaded even though my Explorer can tow up to 5000lbs. Have to add wife, dog, food, firewood, water weight which would go over the weight limit anyway. Gonna need to get me an Expedition for that 22 footer.
07-16-2019, 04:01 PM
Vancouver
, British Columbia
Actually, I meant a 3500 lb tow rating/350 lb tongue weight limit.
Thanks for catching it.
07-17-2019, 04:39 AM
2017 Basecamp
La Quinta
Towing with 2012 escape limited, more
After reading the other posts, a few more comments.
I have used the 2012 escape 3l V6 for several trips.
Including coastal trip in California.
Also a trip to Mammoth from LA.
I installed the Curtmfg 13650 class 3 hitch.
Plenty of strength and not so hard to install.
I installed the Tekonsha 90885C ebrake controller.'
I already had a 5pin harness. needed more wiring for the 7pin ebrake.
Install was a bit hard, had to run wires up to the battery.
Works well.
Did not consider a weight distribution hitch. Needed to get an adjustable height ball to dial in the level of the BC. but the rear of the escape did sag a bit more than I like. but was OK. could not load much in the escape.
I still recommend going to the TV with a V8 and factory tow setup. Long run a better choice.
07-28-2019, 09:02 PM
2018 Basecamp
San Diego
Towing Basecamp with Toyota Highlander
Hi. . .we tow our Basecamp with a Toyota Highlander, factory equipped for towing (5000 lb rating, 500 lb tongue weight). We also have a weight-distribution hitch (Equalizer) on our Basecamp. My experience is that we can tell when the trailer is attached to the car, in terms of acceleration and power in particular. I would not recommend that you try towing the Basecamp with a car that is only rated to handle 3500 lb.
