From book ;
The Newbies Guide
to Airstreaming
The entire fresh water system should be sanitized and cleaned at least once a year. The procedure is easy and doesn’t require any specialized tools. Start by looking up your fresh water tank capacity in the Owner’s Manual, or check the “Boondocking” section of this book where you may have already written it down. Multiply the tank capacity by 0.13, and that’s how many ounces of household bleach you should use. Dilute that bleach in a gallon or so of water, and then dump it in the fresh water fill. Be careful not to splash any bleach/water mix on yourself or your clothes. Then finish filling the tank with water. Run each of the faucets (including the shower head) until you can smell bleach. If you have a water filtration system, check the Owner’s Manual before running the bleached water through it.
Let the water stand in the system 3-4 hours, or double the formula for a one-hour standing time. Drain using the drain petcock on the bottom of the fresh water tank (see Owner’s Manual for exact location) or by running the faucets, and refill with fresh water. If bleach taste or odor remains, rinse system with a solution of 1 quart of vinegar to 5 gallons of water. Some folks swear by Vitamin C tablets for this purpose. There are also commercial products to make the water taste better, which you can find in RV and camping stores. Flush the water out again, and refill with clean water.
