Old 01-26-2019, 12:37 PM   #1
Bentonville , Arkansas
Damage to holding tank?
Hey guys- was cleaning my Basecamp up today and noticed this: the dump valve connection to the grey tank and a panel on the bottom of the tank with screws coming out.
Has anyone seen this before? I'm in a cold climate: could this have been caused by freeze damage or something on the road?
Any help is appreciated.
ID:	332386   Click image for larger version
trd09 is offline   Reply With Quote
Old 01-26-2019, 01:27 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I don't see damage.
That metal is a protective cover, not the tank. The tank is inside the cover. There should be a layer of insulation between the cover and the tank.
The screws hold the access panel in place. Tighten the screws and keep any eye on them. Since I have no experience with a Basecamp, I'm not sure if the access is factory made or created by someone after manufacture. My water tank had access, but I had to add access to the waste tank.
Is the water from your "cleaning", or is something leaking. If a leak, then yes damage.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 01-26-2019, 01:50 PM   #3
Thanks for the response. Check out the gasket/caulking...is that separation normal?
Old 01-26-2019, 03:26 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes... gasket, caulking or as in our case, clamping.👎
Our flange was overtightened to the point of distortion and cracking.
ID:	332395   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 01-26-2019, 04:27 PM   #5
Thanks all. The water is from a self-service car wash. I'll tighten the access panel screws.
Old 01-26-2019, 04:53 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
That separation in the caulk is not unusual. It is a maintenance issue that you need to take care of. It's a mouse/critter entrance if you leave it open.
The movement/flex of the tank and pipe between empty and full is substantial, so there has to be a space between the plastic pipe and the metal pan to allow for that movement. Airstream used to install a rubber sheet/gasket to fill that space. Looks like they have gone cheap, not an improvement.
Alan
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
