Originally Posted by dickgeo
After the axle recall and a major hail storm in Denver I finally have my Basecamp in my driveway and ready to go.
I am new to solar charging and do not understand the readings on the solar panel readout.
What are solar charge amps and solar charge hours.
also how low can my battery voltage be and still be useful
Many thanks
Hi
If you have the standard readout, solar charge hours are a bit useless. You really don't have the data you need to get much useful from that number. There are fancier systems that will give you better data.
Solar charge amps is the current coming out of your solar charger. It is not the current going into your battery. You may have loads turned on that will use the current instead. It at least gives you an idea of how much your solar is putting out. That's not to say how much it *could* put out, it will only source current up to the point you have a load (gizmo or battery charging) that uses the current.
Battery voltage is one way to tell if your battery is ok. If the batteries are at 70F and the readout is calibrated and if you have no loads causing drops ....
12V is the point you stop using the battery. If the battery is hotter, the magic voltage is a bit lower (maybe a half volt lower). If the battery is colder, the magic voltage might be a half volt higher. Without a temperature readout attached to the battery, it's a bit of a guess.
That's the quick and dirty version. There is a lot more information around here on the forum and on the internet.
