Old 11-16-2008, 11:06 PM   #1
2007 Base Camp
Las Vegas , Nevada
Battery Help on my Basecamp
Last summer, we made the step from tent camping to RVing by purchasing a Basecamp. After our first trip, which was fine, our battery never seems to hold its charge at all anymore. I know nothing about batteries, so any help will need to be in layman's terms. Also, I don't know how to access the battery.
lokomonkey is offline   Reply With Quote
Old 11-17-2008, 03:12 AM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hi locomonkey; Welcome to the forums locomonkey. While I am not familiar with the location of the battery in a Basecamp, [most likely a small trap door from the outside] your battery requires constant maintenance. It needs to be charged regularly as it is used. Pending on the type of the battery it may need distilled water added to if the electrolyte level is low. If your battery was left for a long period without a charge it may have sulfated and unable to take a charge. Best for you is to pick up a battery maintenance booklet at your local battery store. Thanks "Boatdoc"
boatdoc is offline   Reply With Quote
Old 11-17-2008, 06:26 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The battery was the first thing we had to replace on our Classic.
Seems it stayed to long on shore power while on the dealers lot and was boiled dry.
This was our solution.
Battery Chargers by BatteryMINDers.com
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-17-2008, 08:41 AM   #4
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
The battery is located on the RS front underbelly. You have to raise the hitch jack up high enough to crawl underneath to dismantle the mounting bracket/ battery box. If your Basecamp does not have the optional Glassmat battery, I would recommend upgrading to one.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 11-18-2008, 11:37 AM   #5
I approve of this message
ostream's Avatar
2006 28' International CCD
Redmond , Washington
Couple of suggestions -
1. Re-post to the "Electrical" forum. There is a "battery" sub-forum with folks with lots of battery/charger knowledge.
2. Consider upgrading to high quality AGM battery (i.e. Lifeline). Often the weak link is the factory installed battery
3. Check out 3 stage charger/maintainer like the "BatteryMINDer".
ostream is offline   Reply With Quote
Old 05-24-2009, 06:10 PM   #6
2007 Base Camp
Las Vegas , Nevada
Battery problems still + ....
We ended up buying a new battery AND a battery tender. Now, each time we put the Basecamp in storage, we remove the battery (wish they would have made it more convenient to access) and hook it to a battery tender at home. This seems to be working well, except I must be hooking the battery up wrong or something. The lights are working, the sink is working...but the radio and the "lighter" plugs are not. Can someone enlighten me on the art of correctly hooking up the battery?
Also, one of our tail lights is out. would that be a result of my shoddy battery hookup?
Old 05-25-2009, 11:13 AM   #7
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
The radio and lighter plugs are on 12 volt circuits. Have you checked the fuses in the power supply near the back RS corner? The door pops down and there are fuses for the 12V DC and breakers for the 110V AC.
If your power supply is working properly, plugging in the trailer to the external AC line should keep the battery charged... it is a multi-function panel. If you want to keep using a battery tender, you can get an adapter that hooks to the battery with a plug in, then use a matching connector to hook to your charger. Motorcycle battery tenders usually come with these.
The tail lights are also 12V DC... if it isn't a fuse, you can check the three pins that bridge the trailer to door connection. Make sure they are making contact. It's unlikely the whole LED light blew... so a fuse or connection would be the place to start. Make sure your trailer connection isn't the problem as well...
It's still not a bad idea to take the battery out over winter... but for a week or two, that's a lot of work...
Friday is offline   Reply With Quote
New Member, New Basecamp ABC004 Base Camp 63 10-29-2011 02:48 PM
Interested in Basecamp pgg61 Base Camp 5 07-14-2008 06:33 AM
Basecamp - $28,000us dufferin Base Camp 19 04-23-2008 03:07 PM
'08 Basecamp rhoward Base Camp 14 11-29-2007 12:48 PM
Basecamp negatives christopher4 Base Camp 15 10-10-2007 12:46 PM
