Old 10-22-2018, 02:21 PM   #1
2018 Basecamp
San Diego , California
Basecamp tow vehicle question
We just bought an Airstream Basecamp, and now we need to buy a car to pull it. We plan on getting a mid-sized SUV that can pull 5000 lbs Ė either a Toyota Highlander LE+ or a Honda Pilot EX. One of the significant differences is that the Honda has a lighter suspension, and thus less bumpiness but more sway of the car itself on rough roads and going around corners. So any of you have experience with a lighter vs. a tighter suspension, or directly with either of these cars? We are wondering which level of suspension is better for towing, and also which suspension is better for avoiding passenger carsickness.
seshields is offline   Reply With Quote
Old 10-22-2018, 03:38 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Generally a stiff(er) suspension is better when towing. The real question is always - what is the suspension like under load? There are a lot of tricks that get played these days in suspension design. Indeed showing up at the dealer with three kegs of beer to load down the demo vehicle may or may not work out quite as you planned......
One thing to consider with *any* tow vehicle is what you will have with you on your camping expeditions. The tongue weight of the trailer and the weight of the hitch do impact your tow vehicle. The weight of your passengers and gear in the vehicle also get into the act. Often people find that part of it is more significant than they first thought .... ( = there are multiple ways to overload a vehicle).
Old 10-22-2018, 03:43 PM   #3
2007 22' International CCD
If you are prone to motion sickness, I'd avoid the Honda.
DW is very sensitive to sway, and has no issue with the tighter suspension in our Tundra. The softer Camry also swayed a lot before I got the suspension redone with better, stiffer shocks.
She's wanting a new Tundra with all the goodies for the next tow vehicle--since she bought (and paid for) our first Tacoma TV in '08, she can certainly have exactly whatever she wants...and since she is the negotiator, I can bet it will be at the price she wants as well...
rmkrum is online now   Reply With Quote
Old 10-30-2018, 04:13 AM   #4
2017 Basecamp
Beaufort , North Carolina
tow vehicles questions also
we also recently bought a basecamp. i have a 2008 toyota highlander hybrid and used it one weekend, and was thrilled that i would not need another vehicle to pull it. now my hybrid has gone bad - the hybrid inverter and inverter system - to the tune of $9500. i have to get a different car. i want the smallest possible option - would love to have a subaru outback, but that may be dicey. also considering a used audi q5. has anyone had experience with either of these?
Airabella is offline   Reply With Quote
Old 11-07-2018, 09:51 PM   #5
2017 Basecamp
Albuquerque , New Mexico
I towed my 2017 Basecamp for 1 year with a BMW X3 (no weight distribution or sway control). This was a fantastic combination. My Basecamp does tend to develop some light sway at highway speeds above 70mph. This was not a problem but may un-nerve some people not experienced with towing. I usually loaded any cargo over or rear of the Basecamp axle to keep tongue weight down. Sometimes the suspension would bottom out on big bumps, but overall suspension of X3 was pretty well matched to that of the Basecamp. Biggest struggle and one of the reasons I moved to a different TV was the wear of the rear tires. Most rear independent suspensions introduce negative camber as they take load which results in inside tire wear when running constantly loaded. I went 1/2 way through tires in a year ~5000miles of towing. This is something you'll probably want to mitigate if this is your long term TV.
ArawayCamper is offline   Reply With Quote
Old 03-10-2019, 08:19 PM   #6
dgirvin's Avatar
2019 Basecamp
Kingston , Ontario
I just bought a Honda Passport with the 5000 lb tow package and think itís going to be ideal. Shorter, stiffer and more agile than a Pilot. Iíll send an update after my 4 hour tow home from picking up the BC.
dgirvin is offline   Reply With Quote
Old 03-10-2019, 08:40 PM   #7
2007 27' International CCD FB
Seriously... based on your own input, the X3, without a WD/anti-sway hitch was a terrible tow vehicle.
Putting weight behind the rear axle of a trailer is generally not recommended. At least not without adequate tongue weight, and would be considered a newbie move as that very thing can reduce stability.
I do believe an X3 can be a good tow vehicle, when setup properly.
Please, for yourself, and the safety of others you share the road with, get yourself a WD/anti-sway hitch. It will do wonders for sway, tire wear, and safety.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 03-10-2019, 09:22 PM   #8
2017 Basecamp
Nice work trying to troll me. Iím not taking the bait.
Old 03-10-2019, 10:53 PM   #9
jcl
Vancouver , British Columbia
Trust that you knew your tongue weight and weren't reducing it too much.
Just a comment on the rear tire wear. It is not caused by the camber of the rear suspension when loaded. It is strongly associated with rear wheel toe settings. Too much, and the tires scrub constantly. Because of the camber, that scrubbing shows up as wear on the inside edges of the rear tire, but the solution is to ensure you have the correct alignment. If you do (and ensure you are at the minimum of the BMW range, BMW allows a wide range of settings) you will resolve the tire wear whether loaded or not.
The myth of rear camber being the cause is promoted by aftermarket suppliers of camber adjustment kits. Don't take the bait.
I got upwards of 80,000 km per set of tires (often heavily loaded) over three sets of tires on two X model BMWs, and that is even with changing them early due to wanting the benefits of sufficient tread in adverse weather conditions.
jcl is offline   Reply With Quote
Old 03-11-2019, 12:03 AM   #10
Nice work trying to troll me. I’m not taking the bait.
There's no hook.
Those expensive tires you scrubbed through, could have paid for a WD/anti-sway hitch. Related to what JCL mentions, a lot of independent suspension vehicles will squat when laden and have lots of camber. They also will toe in. Combined to result in the accelerated wear you've experienced.
Old 03-13-2019, 04:16 PM   #11
2017 Basecamp
There's no hook.
The expensive tires cost me about $250. Good to know I can get a weight distribution setup for that cost if I get tired of the F350. Hereís a picture of my last alignment (unloaded) if anyone is interested. Iíll probably fix the rear suspension camber in a rear suspension overhaul at 150k miles or so. Currently around 137k.
Tow vehicle weight to tow 19' Airstream pennylynne 2005 and newer - Bambi all models 18 02-20-2017 11:18 PM
Tow Vehicle - Jeep Wrangler to tow sport 16 iamcrazy Tow Vehicles 22 04-10-2016 07:37 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
