Old 02-12-2015, 12:06 PM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Have you seen:
Reflective Shock Cord - Paracordplanet.com
Made in USA... wherever THAT is...
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-13-2015, 08:35 AM   #16
2007 Base Camp
Hot Springs , Arkansas
Thanks Bill. One question, I don't quite understand the last picture. Could you elaborate? This is great info, I don't know how I was going to accomplish this. I thought at first that I would just unpack all the old tents and go from there, but his is going to be much easier.
Jed Simpson (jedsbmw@att.net)
Clampett is offline   Reply With Quote
Old 02-14-2015, 06:51 AM   #17
Motorcycle Enthusiast
sgtbill's Avatar
2007 Base Camp
Columbus , Indiana
The two poles with the plastic balls on the end are the same size and run parallel to the sides of the Basecamp when the Kelty is up and on the trailer. The other three are installed perpendicular to those two poles with the longest being closest to the trailer and the shortest being nearest the end of the tent. The shortest of these three poles has a shorter end section than the others. All the other poles seem to be made up of standardized lengths of stock pole material. Except that one short perpendicular pole which has a 11.5 inch end piece.
If someone is building the poles for you to a specific length it may not matter how the poles are sliced.
Bill Russell
Sergeant Major
US Army, Retired
"The cure for anything is salt water - sweat, tears, or the sea." Isak Dinesen
sgtbill is offline   Reply With Quote
Old 02-14-2015, 07:28 AM   #18
Puyallup , Washington
we sold our FC19 and truck, now thinking of getting a base camp to camp and haul my R1200 GS ADV, what do you tow behind. We have a Toyota FJ cruiser now and it can tow 5K, would have to get the RV wiring plug installed
BTW - I'm doing a 4 corners ride in July 2015
srpuywa is offline   Reply With Quote
Old 02-15-2015, 07:09 AM   #19
sgtbill's Avatar
2007 Base Camp
Columbus , Indiana
We tow behind a Toyota Highlander Hybrid. It is barely enough and I certainly wouldn't get anything larger to tow behind the Highlander. The 1200 GSA will fit in the BaseCamp but it will be tight. I use a Condor chock to secure the front wheel. The chock is attached to the BaseCamp floor with a mounting kit but we had to install it up into the pantry well so the rear wheel would clear to back ramp. That back ramp/steps is not designed to be load bearing.
Here are a couple of photos that I hope help.
This one shows the mount installed on the Basecamp floor. The Condor chock attaches to this mount using a screw pin. It is rock solid once it is locked down.
This is the only shot I have of the Condor chock (It's in the lower left of the photo). After arriving at the campground and unloading the bike I unlock the chock and sit it outside the BaseCamp so we can unfold everything. Notice the ends of the lateral member of the chock have been ground down. We did this so it would fit up into the pantry far enough for the rear wheel to clear the ramp/steps.
If the FJ is rated to 5K it should do fine.
Bill Russell
Sergeant Major
US Army, Retired
Old 02-17-2015, 08:59 AM   #20
thanks for the info - something to think about
......And Then The Torch Went By....... Stovebolt Off Topic Forum 16 02-10-2010 08:59 PM
Passed on the opportunity. Sneakinup Our Community 3 09-15-2003 04:13 AM
