Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Base Camp
Old 08-13-2017, 03:07 PM   #1
2017 Basecamp
Hermon , Maine
Basecamp lug nut socket
My new 2017 Basecamp has pretty wheels, but the lug nuts are recessed into cavities barely larger than them. None of my sockets fit in the narrow space. What brand of socket are you all using?
Bullwinkle is offline   Reply With Quote
Old 08-13-2017, 03:28 PM   #2
Retired.
. , At Large
You will need what is called a "thinwall socket".
Old 08-13-2017, 03:41 PM   #3
gwolson50's Avatar
2017 Basecamp
Scarborough , Maine
Bought one at Home Depot. Kobalt 337755. 13/16
gwolson50 is offline   Reply With Quote
Old 08-13-2017, 03:57 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use air impact sockets for lug nuts. They are made to tighter tolerances and have a thinner side thickness than my old Craftsmens sockets.
MICHAEL
Old 08-13-2017, 05:16 PM   #5
2017 Basecamp
Conway , Arkansas
Your 2017 BC was supposed to come with a lug nut tool. Many did not, including mine. I eventually got one from my dealer. I asked for it when I picked my BC up from having the axle replaced.
Gail Miller is offline   Reply With Quote
Old 08-13-2017, 06:09 PM   #6
2017 Basecamp
Hermon , Maine
First off, my dealer seems primarily concerned with selling interstates and Mercedes Benz cars. They don't really know much about the trailer and info from them has been less than satisfactory. For example although I recently purchased the trailer, it was delivered to me in winterized state. I took considerable work to get it set up. Also the toggles for the tents were not installed. You might ask why did I just not just return it to them for sorting out? Well, although they are the nearest Airstream dealer to me, they are 2 1/2 hours away, so it is simply easier to do it myself. I have found info on these forums invaluable and thank all the posters for that.
Getting back back to the lug nut issue. I had ordered a thin wall socket from Amazon but it came with a plastic sleeve designed to reduce marring of the wheels, which make it too thick. I just removed that sleeve and it now works.
Thanks to all for the information
Old 08-14-2017, 05:57 AM   #7
2017 Basecamp
Kings Park , New York
If you have a spark plug socket lying around that will work as well. I am using that along with a 3/8" breaker bar from Harbor Freight.
MrKenmore is offline   Reply With Quote
Old 08-14-2017, 07:42 PM   #8
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I really hope that you are NOT torqueing up the wheels with just a 'breaker bar'!
My FC SPEC call for 110 ft. lb. torque. I 'm sure that other models with Aluminum wheels use a similar figure.
You NEED to use a calibrated torque wrench to safely tighten the lug nuts to the specified figure; before every trip. (The nuts can loosen, and you will gain a little movement.)
These torque figures were calculated by engineers, who publish the figures.
If you have a wheel failure, by not using the spec., the results are on you.
MelGoddard is offline   Reply With Quote
Old 08-17-2017, 01:51 PM   #9
2017 Basecamp
This is merely for an emergency flat tire situation. No different than a lug wrench. I don't carry around my torque wrench in anticipation of changing a flat.
Old 08-17-2017, 02:34 PM   #10
WELL.I DO!
And yes, I did have a flat in June.
What made the day was that I had just purchased a TPMS. "Tire Minder-55".
On the very first trip out, it 'squealed' out, that I was losing tire pressure.
I had picked up a screw in the tire, on the '401' highway.
The tire was changed, using "Coach-Net" service, and my torque wrench, and I carried on smiling.
In over ten years of RVing, I had never had a flat.
That $400+ expenditure had just saved me several thousand dollars repairs etc.
What can I say to that??? 'The GODS were smiling on me that day.
Old 09-07-2020, 11:20 AM   #11
2017 Basecamp
Ventura , California
2017 Basecamp Lugnut socket ???
Alright _ I 've purchased 2 so far - can find a socket that will fit the lug nuts on my basecamp
The nuts are recessed into the wheel and it requires a thin wall - anyone have source for this? Strange design !
I tried looking for the Kobalt 337755. 13/16 - referred to earlier - can't find anything that refers to a thin wall
thx
otisb is offline   Reply With Quote
Old 09-07-2020, 11:34 AM   #12
Mollysdad's Avatar
I bought this one for my Sendel rims.
It's not a basecamp, but it has the recessed lug nuts.
I use a short extension (3") and a long breaker bar 1/2" drive from Harbor Freight.
https://www.amazon.com/DEWALT-DW2291...499911&sr=8-31
Old 09-07-2020, 12:10 PM   #13
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Search:
Thin wall lug nut socket if the OD is too large.
GCinSC2 is offline   Reply With Quote
Old 09-07-2020, 10:56 PM   #14
2017 Basecamp
Thank you
Is that a “thin wall” that will fit into the tight space?
Old 09-08-2020, 03:14 AM   #15
Sag Harbor , New York
Per the fine print in the product description:
"Thinner than wrench sockets for tough to access areas"
As Michael said back in 2017:
Old 09-08-2020, 03:21 AM   #16
As the OP 3 years ago, could you provide a link for the socket you found . . . this would be helpful for other Basecamp owners IMO.
Old 09-17-2020, 04:54 PM   #17
2019 Basecamp
Whitefish , Montana
I don't know about the regular Basecamp 16 or the new Basecamp 20 but on my 2019 Basecamp X a 19mm deep socket is an exact fit to the lug nut. 13/16" (20.6 mm) would be quite sloppy For my factory wheels and lug nuts a thinwall socket appears to be nice to have but not a necessity.
Basecamp19 is offline   Reply With Quote
Old 09-18-2020, 07:23 AM   #18
2017 Basecamp
I started a new thread as well Since I had so much trouble finding the thing.
Maybe it’s only the 2017 model that has the thin wall.
Ok - it took me three tries but I finally found the right socket
I have a 2017 Basecamp
The wheels are cool but the lug nuts are recessed into the wheel -the space around the nut is so small it requires a special socket - otherwise you are out of luck trying to change the tire !
GEARWRENCH 3/8" Drive 2-1/2" Spark Plug Socket 13/16", 6 Point - 80403
Found it on Amazon
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 09-18-2020, 07:33 AM   #19
GCinSC2's Avatar
Found it on Amazon
One concern, I would not select 3/8" drive for high torque applications like a lug nut. What is the torque spec on your trailers wheels? Mine is 100 lb/ft and that's the range for 1/2" drive tools.
Gary
Lug nut socket size jaygoree Wheels, Hubs & Bearings 7 03-04-2015 02:54 PM
batwing antenna 15/16" nut socket won't fit through inside skin richinny Audio, Video & TV 6 01-15-2010 08:09 AM
spindle nut socket size eugnicfrlie Axles 4 04-20-2009 09:12 AM
Where do I get a lug nut socket Antique Pedaler Wheels, Hubs & Bearings 3 11-27-2006 05:59 PM
Lug Nut Socket Help... AZstreamin Wheels, Hubs & Bearings 20 09-21-2006 06:04 AM
