Old 12-13-2016, 07:23 PM   #1
Davenport , Iowa
Basecamp Hitch Recommendations?
Hi all -- this is my first post on this forum so forgive me if it is redundant or somewhat trivial:-).
I will be getting a new Basecamp soon to be towed by my 2016 Jeep Wrangler Unlimited Hard Rock. My Airstream dealer is small, and I left feeling they were married to Blue Ox brand hitches. The Blue Ox Sway Pro model is what they recommended for the Basecamp for me. After reading this forum (and this is my first tow trailer ever), I'm not convinced this is the best hitch for the Basecamp.
I called Airstream and they wouldn't recommend one. I called LaZDays and they recommended an Equalizer rated at 10,000lbs.!!! I called Sutton in Oregon and they said too strong of a hitch could bend the Basecamp's frame, and they suggested the Center Line Husky lightweight. The limited "hitch info" in the Basecamp forums I've read has mentioned the Anderson weight distribution hitch a few times.
Anyway, all I know right now is that it needs to be a "weight distribution hitch". Here are some numbers in case they may help you recommend the best hitch to help me:-).
Basecamp hitchweight is 400lbs. Wrangler Unlimited receiver supports 350lbs hence need for weight distribution hitch. Basecamp unladen weight is 2,6xxlbs and laden is 3,500lbs. Thank you in advance for your suggestions and this very informative forum,
Rob
IAortho is offline   Reply With Quote
Old 12-17-2016, 07:43 PM   #2
Colfax , California
Hi Rob...
I won't speak for anyone but myself on your question, but it is possible that your question has yet gone unanswered because folks might be hesitant to chime in on a hitch suggestion because your Wrangler is right at the tow weight limit for a loaded Basecamp. I don't know the wheelbase of your Jeep, but shorter TV wheelbases add complexity to the equation.
Were I you, I would forgo soliciting advice from both forums and trailer dealers. On the first count, your best response would be from a Wrangler owner who has considerable miles towing a trailer similar in characteristics to the Basecamp. I'm guessing that you might be waiting some time for that person to wander by.
As for dealers recommendations for hitches, most are likely to only be knowledgable about what they sell and a suggestion to over equip is very possible. You might even run into a sales person whose limited knowledge about even those hitches they sell is difficult to discern.
Manufacturers of hitches are pretty much the only entities who have a broad range of opportunity to experiment with or otherwise learn from experiences of many different users of their products with a wide range of TV and trailer combinations. I have talked to technical staff for several of the major hitch players and have yet to come away with the sense that someone was talking over their head or otherwise farting and tap dancing about factors to consider when choosing an appropriate hitch for specific needs.
Good luck.
Bborzell is offline   Reply With Quote
Old 12-17-2016, 09:41 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Basecamp hitch recommendations?
Based on my experience towing a small Basecamp sized Airstream I am comfortable recommending either the Anderson or Blue Ox Sway Pro systems. I have used both. Personally I would lean toward the lighter and very effective Anderson for such a light weight trailer. You would not go wrong with either system. Also in my experience dealers recommend what they sell without really considering what is best or appropriate.
MICHAEL
Old 02-05-2017, 06:18 AM   #4
Long Island , New York
Welcome to the forum, Rob! WD hitch questions from other new Basecamp owners are coming up in various threads [including the BC Fans thread], so I was wondering what hitch you ended up getting for your Wrangler?
Peter
Rob
Old 02-17-2017, 09:48 AM   #5
2017 Basecamp
Kings Park , New York
I am curious as well. TV is a 2017 RAM 1500 with 5.7 Hemi. I actually got the RAM to replace my 4 door Wrangler. I never liked towing with the wrangler. Even a utility trailer full of gravel was an "experience". I haven't picked up the BC yet. It's at the dealer so I just need to go get it. I'd like to go with the proper equipment.
MrKenmore is offline   Reply With Quote
Old 02-17-2017, 12:09 PM   #6
LongShot's Avatar
2015 19' Flying Cloud
Ashland , Kentucky
Images: 8
I used to own a FC19 and towed with Mercedes M-Class 350 Diesel. This combination worked perfectly with the Husky Centerline hitch system with weight distribution which was really required with the softer suspension on the Mercedes. A couple of important things to note about the Husky system (1) it's really heavy! It's designed to distribute weight and help with sway control - both of which it does excellently, and (3) did I mention it's really heavy?
The weight is becoming a bit of a concern for me as I get older; moving that system off and on is a bit of work. I do fear that as get get on in years, either (a) I'll just leave it on or (2) I'll end up buying a motorhome (not likely to happen) or (c) I'll just have to find some young stud-like person and pay them to set-up and dismantle when I want to go camping.
Final thought on Husky Centerline: Highly Recommended but HEAVY!
Just another thing to think about.
One Long Shot
Beastie - 19'FC
The Big Beast - GMC Yukon w/Max Tow Package
Held together with the Husky Centerline Hitch
LongShot is offline   Reply With Quote
Old 02-22-2017, 12:43 PM   #7
Davenport , Iowa
Well, I don't have any solid answers for folks since I haven't taken delivery of the Basecamp yet -- will do March 3. The two hitches I've gotten the best info on are for the Ea-Z-Lift 600 and the Equalizer 600. I'll try to read up on them tonight and see what, if any difference, there is between them -- weight, ease of use, control, etc. Excited to get this mobile fishing camper!
Old 02-22-2017, 01:58 PM   #8
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I tow our 2300 lb 64 Bambi 2 with the #600 Equal-I-zer set very softly on our VW Touareg. So there's little equalization but good bounce and sway control.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, '11 Touareg TDI
Santana tandem bike
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-22-2017, 04:55 PM   #9
2017 16' Sport
loves park , Illinois
Towing..
Hello, I also have a 2016 Jeep unlimited 4x4, it has the standard factory hitch, nothing special at all. I just picked up my 2017 sport 16 bambi yesterday, towed it several hundred miles with zero issues, pulled great, smooth had some wind to deal with at the end but all was good. I took a hard look at the Base Camp before I bought the Bambi, you will have no problem pulling the Base camp with a standard factory hitch, call your Jeep dealer for prices.. Best of Luck! oh, and mine is a Rubicon, so we both have the upgraded trans cooler etc. from the factory
chasrolex69 is offline   Reply With Quote
Old 03-06-2017, 06:52 PM   #10
2017 Basecamp
Flagstaff , Arizona
I tow my Basecamp with a Toyota 4Runner and the Blue Ox Sway Pro. It is very solid on the road, even in the gusty winds we had in northern Arizona.
basecamp516 is offline   Reply With Quote
Old 03-08-2017, 09:04 AM   #11
2017 Basecamp
Issaquah , Washington
Standard Hitch
We have a Jeep Grand Cherokee and just use a standard hitch to tow our Basecamp - it works great. We also have a wireless brake assist, which is helpful for slowing the trailer down behind our rig. Have fun!
PNWRich is offline   Reply With Quote
Old 03-12-2017, 02:24 PM   #12
Fort Walton Beach , Florida
I tow with a Toyota Tacoma and use Blue Ox sway pro
ToddA is offline   Reply With Quote
Old 03-12-2017, 02:43 PM   #13
Gainesville , Florida
Do you mean you tow just on the ball mount and no WD or sway control. That must be a wireless brake controller, a necessity.
avionstream is offline   Reply With Quote
Old 03-13-2017, 02:07 PM   #14
2017 Basecamp
Yes, sir. We considered a sway bar but there is no room for one on the Basecamp - at least not the one we were looking at - and we were told that it would be overkill anyway. So just the wireless brake assist and it works great.
Need hitch recommendations sewmary Hitches, Couplers & Balls 5 03-04-2010 05:08 PM
Hitch recommendations please!! pinktrailer Hitches, Couplers & Balls 4 10-20-2009 06:02 PM
towing the 32 excella vs 34 excella hitch recommendations lakelady Hitches, Couplers & Balls 21 03-21-2008 08:13 PM
Bambi Weight Distribution Hitch Recommendations gorrissen Hitches, Couplers & Balls 9 05-02-2006 01:35 PM
Hitch and brake controller recommendations for Excursion/28' Safari PWRSTRK Hitches, Couplers & Balls 15 08-17-2004 09:45 PM
