Old 08-25-2018, 09:53 AM   #99
Becky BaseCamp
2017 Basecamp
Lowell , Michigan
Platform Bed with piston lift
We found we rarely ever sat indoors in our Basecamp and the act of taking down and putting up the bed was tiresome. And finally, accessing the storage was a burden. Decided to remove the bench seats and hinges and replace with 40# gas piston assisted platform bed we made that rests upon the short table legs. Cover it with a Tochta 7" custom cut rv mattress and now sleep like never before! With the 40# assist one person can easily lift and hold the platform up while another accesses the storage. We're considering replacing them with a pair of 60# pistons to see if that would hold the platform up.
ChrisandDave is offline   Reply With Quote
Old 08-25-2018, 01:16 PM   #100
Becky BaseCamp
2017 Basecamp
Lowell , Michigan
Suction cup hooks
Love these suction cup hooks I got on Amazon. We have six of them we travel with. In the kitchen I use them to hang dish towels. Back by the bed we hang headlamps, hats and sweatshirts. We even use them on the outside of the Basecamp for wet towels and clothes. The suction is super strong and Iíve never had one fall. YutaoZ 2 Pcs Stainless Steel Powerful... https://www.amazon.com/dp/B01IP6JVIC?ref=yo_pop_ma_swf
ID:	320797   Click image for larger version
Old 09-24-2018, 02:51 PM   #101
2018 Basecamp
Ottawa , Ontario
Back door - clear plastic behind screen to stop wind
we wanted to keep the view while blocking the cold fall wind. The solution was to back the insect screen with clear plastic!
ID:	323601   Click image for larger version
Marierca is offline   Reply With Quote
Old 09-24-2018, 02:54 PM   #102
2018 Basecamp
Ottawa , Ontario
Small table inside
It is getting cold here in Canada...we might spend a bit more time inside...a small table will be practical for breakfast and small snacks!
ID:	323603   Click image for larger version
Old 09-24-2018, 03:04 PM   #103
2018 Basecamp
Ottawa , Ontario
Good idea...any traces when you remove them?
Old 09-25-2018, 05:43 PM   #104
Becky BaseCamp
2017 Basecamp
Lowell , Michigan
No. They come of clean.
Old 09-29-2018, 08:08 PM   #105
ChrisandSue's Avatar
2017 Basecamp
Edwardsville , Illinois
Due to continued intermittent problems with the Basecamp fridge, we decided to add a 12-volt compressor fridge. I've installed two ports, one for it to run off battery and the second for the fridge to run off the MPPT solar charge controller that I added. Attached are photos.
ID:	324025   Click image for larger version
ChrisandSue is offline   Reply With Quote
Old 10-01-2018, 07:38 AM   #106
2018 Basecamp
Ottawa , Ontario
Table new ideA
Another idea for a small table..Click image for larger version
Old 10-01-2018, 07:41 AM   #107
2018 Basecamp
Ottawa , Ontario
Fire pit direct connect
We love the fire pit..and we cook with it!Click image for larger version
Old 10-01-2018, 07:44 AM   #108
2018 Basecamp
Ottawa , Ontario
Awning..tarp...
To stop the wind...we joined two tarps...
Old 10-01-2018, 09:57 AM   #109
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
The small table and trays look great and would work for a trailer too. We are always looking for ways to take food to potluck or outside. Are the trays just sitting on the table or attached.
ID:	324179Click image for larger version
ID:	324180Click image for larger version
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 10-01-2018, 12:59 PM   #110
2018 Basecamp
Ottawa , Ontario
Hello -the tray is just sitting on top of the table. So - very practical to bring stuff in and out of the trailler!
Old 10-04-2018, 06:02 PM   #111
2018 Basecamp
Ottawa , Ontario
Shower curtain
To keep the cleaning to a minimum, We have added shower curtain in the wet bath using two tension rods.
Old 12-28-2018, 03:38 AM   #112
2017 Basecamp
Falls Church , VA
Originally Posted by RocIngersol View Post
Hello Basecampers,
RocIngersol here with another modification/hack adding front exterior glass protection to prevent glass breakage from errant rocks/debris while under tow.
Please reference attached pictures.
The total cost was bout $85 for the 0.157" plastic waterproof panels (home depot) and UV extreme outdoor Velcro tape (amazon).
The first picture shows the unit with the Velcro, followed by the panels and finally with the panels installed.
Velcro is attached to all four sides of the panels.
There is an approximate 1/4" air gap between the panels and glass and does provide good protection for flying rocks - they bounce right off. Obviously, very large rocks/debris will cause damage.
The panels are for under towing conditions only and come off while camping (put in back of pickup) or inside unit when stored.
Just sharing information.
Best Regards,
RocIngersol
Hey RocIngersol, how did those DIY window covers work for you? Any issues with them coming lose while towing?
-Jared
JTRX is offline   Reply With Quote
Axle hacks sdsmarts Axles 4 04-03-2015 10:20 PM
