Old 10-08-2017, 05:47 PM   #57
2017 Basecamp
Conway , Arkansas
Originally Posted by Tom P. View Post
My shower door developed a wicked bow - might replace. In the meantime, I put handles on inside so I can pull shut and engage turn - buttons for door tight against gasket. Works for now... Not sure it'll last. I am liking the oxygenics head more and more btw.
I added handles to the inside of my bathroom door today too.
ID:	296537   Click image for larger version
Gail Miller is offline   Reply With Quote
Old 10-10-2017, 06:05 PM   #58
2017 Basecamp
Conway , Arkansas
Door hack to prevent breaking out window
I added this strap to my exit door to prevent it from flying back in strong wind and breaking the front window. I believe 4 folks have had that happen. I am rather short, so this is not in my way when I get in or out. I used a horse tie-down strap from the feed store. It had a bit of bungee cord at one end.
ID:	296677   Click image for larger version
Old 12-03-2017, 04:14 PM   #59
Tom P.'s Avatar
2018 Basecamp
Essex , Massachusetts
Added runners to drawer - works just like home! Made a new drawer with thicker bottom to accept screws and dividers for my specific implements. Wanted this since day one. 22" guides juuust work. You can juuust reach to screw them down in the back, beyond the recess where the original tray sat.
Name:	2017-12-02 19.07.19.jpg
ID:	300275   Click image for larger version
Name:	2017-12-02 19.08.53.jpg
Tom P. is offline   Reply With Quote
Old 12-05-2017, 11:44 PM   #60
Dallas , Texas
I run my propane converted generator off the external LP port
slurpee is offline   Reply With Quote
Old 12-06-2017, 06:46 AM   #61
2017 Basecamp
ABQ , New Mexico
Great job! That has always been one thing that's annoyed me.
YoungishJedi is offline   Reply With Quote
Old 12-09-2017, 07:52 AM   #62
2018 Basecamp
Evanston , Illinois
Originally Posted by Trae and Ann View Post
Attachment 288058
This is our IPad Pro on a mount that can adjust. Download your movies etc and good to go
Love your iPad pro mount idea. Can you tell me the brand name of the mount you are using? This looks like a great gift for our christmas stocking
CamperGirls is offline   Reply With Quote
Old 12-09-2017, 11:42 AM   #63
Trae and Ann's Avatar
2017 Basecamp
Garland , Texas
We ordered on amazon it’s a BESTEK Gooseneck Tablet Mount. Love it
Trae and Ann is offline   Reply With Quote
Old 12-10-2017, 09:12 AM   #64
2018 Basecamp
Las Cruces , New Mexico
Where did you get the handles for bathroom door?
NichoII is offline   Reply With Quote
Old 12-14-2017, 11:18 PM   #65
Dallas , Texas
Simple solution to prop propane cover open - bungee to door
Old 12-15-2017, 10:06 AM   #66
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Bogy4 View Post
Hey All - Anyone upgrade their shower head? If so, please post which one you got. I believe the hot water tank is 2.67gal and the shower head is 2.5gpm. Doesn't leave very long for even a "camper" shower or for 2 ppl who want to shower one after the other.
The usual 500-page RV dealer Accessories catalogs have a range of small products, among them a shower head hose on/off insert. Use any shower head afterwards.
The local big box may have it.
The catalogs are always worth having. The Sears Wish Book of the present era. The bigger the RV dealer the more likely it’s free. Worth a few bucks. Keep a sheet of lined paper and record page number, item, and price (high markup). If nothing else one may be inspired to fabricate or substitute any of a number of “conveniences”.
Add to the sheet anything of interest. Research on this or other forums (sailing, for instance). Consider sheet and catalog as basic reference for the subject of this thread. Go page by page, front to back. Not everything has one use, and not everything is in a section YOU expect.
Old 12-24-2017, 10:26 AM   #67
2018 Basecamp
After seeing Gail Miller’s guard to protect door in case of high winds I liked idea but tried a different approach. I used a rubber retainer installed in such a way we can use door without ducking. I drilled only one new hole adjacent to existing hole in door window frame. We disconnect clasp fastener if/when we use standard hook to keep door open all the way.
NichoII
Old 12-25-2017, 05:08 PM   #68
2018 Basecamp
Valley Vent Fan
Very new to this having bought new BC two weeks ago. Going over lots of things this w/e & wondered why hatch for vent fan in galley doesn’t seem to shut tightly. Wonder if threads on my opening control are stripped....I turn it counterclockwise to open but when I close it the knob begins to ratchet without adding tension as hatch closes. Is this normal or do I need to replace the black plastic screw knob that opens/closes vent. No water leaks from rain yet but it just doesn’t “feel good” when I close hatch.
Thanks for any insight you might have, Robert
Old 12-28-2017, 03:13 PM   #69
2017 Basecamp
Kings Park , New York
The lowering sound / action you're describing is normal. Mine does the same as many other ceiling vents I have operated.
MrKenmore is offline   Reply With Quote
Old 01-21-2018, 03:44 PM   #70
2018 Basecamp
Tucson , Arizona
30 lb Propane Tank Installation on Basecamp
Hello Basecampers,
For your information I have attached some pictures showing a 30 lb (from original 20 lb) propane tank upgrade.
I have removed the black cover and added a rain shield for the upper vent for your information (see my posts regarding refrigerator performance while on propane for more information)
Regards,
RocIngersol
ID:	302783   Click image for larger version
ID:	302785   Click image for larger version
ID:	302787   Click image for larger version
RocIngersol is offline   Reply With Quote
Axle hacks sdsmarts Axles 4 04-03-2015 10:20 PM
