Old 02-07-2017, 06:41 PM   #1
North Tonawanda , New York
Basecamp Generator
Should have a brand new basecamp in next month ( ordered late last year) and have been reading the forum with excitement and enjoying the threads of your experience. I wondered if a 2000 watt generator will suffice for the basecamp air conditioner to start up and run. Any feedback back would be greatly appreciated. Thanks
Twowheels is offline   Reply With Quote
Old 02-07-2017, 06:45 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Hi, and welcome to the forum. It is generally accepted that 2400 watts is pretty much the minimum for running an air conditioner.
Old 02-07-2017, 07:24 PM   #3
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
So to further expand on the answer above, you will need (2) 2000 watt gennies in tandem, or a larger 3000 watt model.
Many choose the tandem smaller units as they are not as heavy (about 45 pounds) so easier to move and store.
There are a lot of good videos on Youtube showing how these setups work and how loud these are.
That being said, if you stay at most campgrounds and state parks, there will be electric hook ups.
On the contrary, most national parks, and rustic areas, friend's lake houses, music festivals, and game day tailgates will not have electric available. If you won't really need the AC in these instances, then the smaller size generator will be great to run the lights, microwave, tv, etc. So you also may want to take a wait and see approach since these are an investment.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 02-07-2017, 07:42 PM   #4
2016 16' Sport
Miami , Florida
You could get one Honda 2000 and a micro air easy start for the ac.
Shiny16 is offline   Reply With Quote
Old 02-07-2017, 07:44 PM   #5
Thanks for the feedback and good advice, I think I'll do just that "wait and see"
Old 02-07-2017, 07:51 PM   #6
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
http://www.airforums.com/forums/f37/should-i-keep-my-2-x-honda-2000i-generators-153360.html
SCOTTinNJ is offline   Reply With Quote
Old 02-07-2017, 08:25 PM   #7
Rg416's Avatar
2019 22' Sport
Cohasset , Massachusetts
I also have a Basecamp on order, and have been hoping someone who knows would figure this out. Not sure if this helps, but all the other Airstreams have larger BTU a/c units than the Basecamp. The 16' Sport has 11,000, 22' Sport is 13,500, and many others are 15,000 BTU's. The Basecamp a/c unit is only 9200 BTU's and I'm hoping the Honda 2000 can handle it. I seem to remember somewhere here someone with a new Basecamp saying that it should work (on paper at least), and they were going to test it. Hoping to hear.
Rg416 is offline   Reply With Quote
Old 02-07-2017, 09:16 PM   #8
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Anything over a 2000w generator creates a handling & weight issue. Buy one, either Honda or Yamaha brand as they are without a doubt the best and both have parallel capabilities meaning if needed you can purchase a second one & connect them for 4000w total.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 02-12-2017, 04:44 PM   #9
Long Island , New York
FYI on p. 8-16 of the BC Owner's Manual [p. 78/86 in the PDF]:
https://www.airstream.com/wp-content...ers-Manual.pdf
it says the A/C draws 16 amps, which is near the limit of the Honda 2000 I believe. This is a starting amperage of course. Not sure if the circuit breaker for this circuit is the kind that can accomodate motor start up.
Good luck.
Peter
Old 02-12-2017, 05:07 PM   #10
Rg416's Avatar
2019 22' Sport
Hi, from what I've been able to find searching around the internet it looks to me like the a/c on the Basecamp is a Coleman Mach 8 Cub (9200 btu) with a black shroud? Maybe someone who has a Basecamp with a/c can confirm this? The pictures I've seen online match the Airstream pix. If this is the correct unit, it looks like the standard operating wattage is 1270, and 1550 watts for desert (full power I guess). I know when the a/c kicks on there's a surge, but it looks like there are a few hundred watts to spare. The Honda is 16.7 amps, so it's near the limit to start it, but should work. On paper anyway. Here's a link for the a/c, I think...
http://www.airxcel.com/docs/default-....pdf?sfvrsn=12
Old 02-12-2017, 05:55 PM   #11
BC AC draws 16 amps per info in Post #9.
Old 02-19-2017, 07:05 PM   #12
Rg416's Avatar
2019 22' Sport
Hey I was at the RV show in Atlantic City this weekend and an Airstream rep was at the Colonial Airstream area. I asked him if it is true that a 2000 watt generator can run the 9200 btu a/c, and he said yes, that's the way they planned it. But don't use much of anything else electric at the same time.
By the way, it was striking to see the dramatic quality difference between Airstream and any other travel trailers that were there. They're totally awesome. And there was a lot of buzz around the Basecamp!
Old 02-25-2017, 10:18 PM   #13
Miami , Florida
Check the specs on this one. They claim the lowest DBA. Looks great with many features.
https://www.amazon.com/Generac-6866-.../dp/B0128KR4EE
harveyd396 is offline   Reply With Quote
Old 02-26-2017, 04:37 PM   #14
Have a Basecamp on the way, the 1600 running watts is what concerns me. A article I read stated 3.4 btu will consume 1 watt, if this is true the math puts this on the edge under the best conditions for either the A/C or the heat strip .
1600 watts x 3.4 btu = 5440 btu.
2000 watts is 6800 btu.
Am I over thinking this ? I am open to feed back if anybody has a different calculation.
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Basecamp Sighting! thecatsandi Base Camp 17 04-26-2006 09:14 AM
2007 Airstream Basecamp Trailer Colonial Airstream Commercial Listings 4 01-14-2006 09:59 AM
theVAP Episode 7: BaseCamp is here Safari Tim Our Community 0 12-08-2005 10:19 AM
