Old 02-23-2008, 09:09 AM   #1
Beagle's Avatar
2007 Base Camp
Houston , Texas
Basecamp Door & Hinges
I had my Basecamp parked in my driveway with the steps down and the doors closed, but not latched. The next morning I found one of the doors on the ground. Apparently a gust of wind whipped the door open, the nylon strap was ripped off from where it is riveted to the trailer, and the hinges broke apart. The hinges look heavy-duty, but closer inspection reveals that only about an eighth of an inch of metal is all that is used to keep the hinges together. I also find that when the doors are open, they can slam shut with a light breeze. I use a bungee to keep them open. I am going to have to remove the interior aluminum panels to replace the hinges. Does anyone have any similar experiences or creative suggestions to help eliminate the problems?
Beagle is offline   Reply With Quote
Old 02-23-2008, 09:13 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
2008 - Is it under warranty by Airstream? Won't they fix it?
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-23-2008, 09:50 AM   #3
Beagle's Avatar
2007 Base Camp
Houston , Texas
Thanks for the quick reply! Unfortunately, Airstream's warranty dept. considers it 'wind damage' and will not cover it. I'm simply glad it didn't happen 1000 miles from home!
Old 03-04-2008, 04:11 PM   #4
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
If it were my trailer, I think I'd bite the bullet and have my dealer fix it. There is a lot of sub-structure fior both the door and body that may also be damaged.
FWIW, the plastic holders A/S supplies for the prop rods suck - they snap off REAL easy. I made new ones from some 3/4" angle steel, they hold up well.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 03-05-2008, 05:52 AM   #5
Beagle's Avatar
2007 Base Camp
Houston , Texas
Airstream sent me a pair of the door stays (prop rods) and they do suck. I replaced the hinges myself and camped last weekend. The plastic clip that holds the rod to the door snapped off in a slight breeze! I rigged some tie down straps on both the interior and exterior for the remainder of the trip. Thanks for the insight with the steel. Do you have any pics?
Old 03-06-2008, 11:36 AM   #6
bobfowler's Avatar
1972 Argosy 20
Images: 14
I'll try and shoot some pix this evening of the mod and get them posted.
Bob Fowler
TAC - NJ-007
Old 03-06-2008, 12:07 PM   #7
2012 25' FB International
Evanston , Illinois
FWIW, I saw the same thing happen to a Basecamp on a dealer's lot.
Hi-Ho Silver!!
JerryMcMunn is offline   Reply With Quote
Old 04-22-2008, 02:31 PM   #8
bizcamp's Avatar
2006 Base Camp
Earlysville , Virginia
I use a large triangular doorstop from lowes. I am partial to the orange ones..
stick them in the space between the body and door and the wind or door bumpers won't get you.
Bizcamp
bizcamp is offline   Reply With Quote
Old 07-19-2008, 09:46 AM   #9
bizcamp's Avatar
2006 Base Camp
Bullet Proof Door solution!
Go to Auto parts store or your nearest junkyard and get some of those hood lifters. Bolt them on the stairway and doors and when you open up.. its like being on the set of Startrek when the propguys shove the doors open. Remember that sound? I think I'll set that up.
Biz
He didn't expect; he was not disappointed!
Old 09-09-2009, 05:27 PM   #10
Rivet Gunner
ArveeBob's Avatar
2007 Base Camp
Tacoma , Washington
Thumbs up Need to Know Basis
PLz Do tell how you replaced the hinges
ArveeBob is offline   Reply With Quote
Exterior Door Hinges HowieE Doors & Locks 7 11-09-2012 12:13 PM
Door hinges loose Blimphauler Doors & Locks 7 11-20-2006 03:22 PM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
bolts for door hinges kelleus Doors & Locks 1 09-19-2006 05:47 PM
Door Hinges Ed Keyes Doors & Locks 4 09-06-2006 03:48 PM
