New to the Basecamp, Airstream, and trailering, so this is all an adventure to me. I found most of the electrical components, but I can't figure out where the battery is. When the dealer installed the solar panels, they put the control panel in the left from cabinet under the sink. Is the battery down there?
The battery is under the cabinet that is beneath the sink. I think the bottom boards lift up/pull out, although I have not looked under there myself yet.
Once you get the covering off, does anyone have hints or directions on how to work on and/or remove the batteries! With the door of the cabinet on, there's not enough width to remove the cover. Just trying to get two hand into the space is difficult. Suggestions???
To get to the batteries: 1- Remove glass door below the sink (loosen plastic screws on with top and bottom hinges and slide door our). Batteries are under cabinet floor. 2- Remove backboard (4 screws in corners) against wall and lift out 3- Remove 4 corner screws in cabinet floor and lift out 4- Batteries are in metal box (lift metal lid 4/5 inches and push on lid towards wall to disconnect lid from back of metal box) Remove lid 5- You now have access to batteries - if the are AGM they will weigh somewhere between 55 to 60 pounds each! Hope this explanation helps gain access to the batteries and remove them - Dave
PS: Might want to put some duct tape on the leading edge of the board holding the utensil drawer because it is sharp and can cut your scalp if your hit your head on it when pulling the batteries!
