-I tried running a charger for my phone in the 110v outlet. Nothing. Am I rightly assuming those outlets won't work unless you're hooked to shore power or to a generator?
The power panel in the Basecamp does not work as a converter when on battery power... meaning you will get regulated 12VDC from the cigarette lighter plugs, but no 110VAC from the plug ints. The AC is only live when plugged in...
-If so, this raises another potential issue with heat. I bought this heater for the trailer thinking I could run it over night. But if my assumption above is correct, that's not possible without running shore power or a generator, correct? Then what?
We use a small electric heater and must be plugged in. Even a wee 1000W heater would kill the single car-size battery in a Basecamp quite quickly. A generator is an option, but even the quietest little guys are not likely allowed to run during quiet hours. I demoed a Yamaha 1000W... very nice... expensive though.
-The water tanks were winterized so I ran the water out of the faucet to get the tank near dry. This of course backed the sink up because the drain plug wasn't open outside. So I opened it. And the mess went on the ground (of course). So I grabbed the second tank from under the sink thinking there's be a hose to hook to the drain outside--but there isn't. What's the proper process for this waste water issue?
We use a flat waste-oil collector and dump it in the sani-dump. A short garden hose could be run to in-ground septic if the site had it...
-Similarly, I don't think I recall ever seeing a standard garden hose-sized waste water outlet on any other trailer I've used. So when I do come to a camp that has full facilities, how will I hook into the sewage?
Just stick the hose in the hole, take a rag with you to stuff around the hose so the stick doesn't come out. I prefer non-serviced sites for this reason...
-I tried to start the burner on the stove and didn't hear a clicking from the sparking mechanism to light the gas. I also didn't hear gas flowing (though the tank showed the gas being opened. Is this run from some power source other than the house battery?
Make sure the valve in the tank compartment is open, then check under the trailer right side near the front... there will be 2 quick fittings, one is in use. It runs up to the burner. The other can be used for a BBQ allegedly. These fittings take a beating on gravel roads... As mentioned, the sparker runs off the
12V battery... so it must be alive (or you are plugged in and the converter is working). Check that it is plugged in and if I recall there might even be a switch?
-Finally, the water tank under the sink is dirty. No big deal. I can clean it. But the hose on the pump motor has this brown dingy wax-like substance all over it. I rubbed it off the hose, but am I to assume the water in the tank really shouldn't be thought of as drinking or cooking water?
It's easy to get lazy and leave water in the tanks... because they are clear and get exposed to light, they will get mould or algae pretty quick. We use a separate drinking water supply and don't use the sink much due to the small size and lack of hot water. Grab the Javex (bleach) and use a mild solution to disinfect the tanks and the pump. Once it is clean, as long as the water is relatively fresh it is safe. I find the water too warm to drink after a day or so...
