Old 06-06-2018, 01:38 PM   #1
2003 34' Classic
Welland , Ontario
Basecamp
I have a 2017 Basecamp
I had trouble getting the table off the pedestal
and solved the problem by adding a extra O ring to the table.
Goodgercan is offline   Reply With Quote
Old 06-07-2018, 11:18 AM   #2
Pueblo , Colorado
I had an issue getting the table off the small posts after sleeping on them. I removed the post with the table attached, flipped it upside down on the cushion and put my knee on the bottom the table. Then I pulled up firmly with one hand while tapping the sides of the post with the palm of my other hand.
It took a little patience, and you don't want to hit the post so hard you damage it, but the post came out in under 20 seconds.
SSChameleon is offline   Reply With Quote
Old 06-11-2018, 07:09 AM   #3
2017 Basecamp
ABQ , New Mexico
Great idea! I've been using a rubber strap wrench but this sounds like a better solution.
YoungishJedi is offline   Reply With Quote
Old 06-11-2018, 07:20 AM   #4
Long Island , New York
There have been a number of fixes posted for this. If you put “Basecamp table leg stuck” in the blue search box above, the results will show the fixes. Right now I can’t seem to post the URL.
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 06-11-2018, 07:21 PM   #5
PS -- FYI here is that URL for the search results:
https://www.google.com/search?q=base...=airforums.com
Old 06-12-2018, 05:17 AM   #6
2003 34' Classic
Welland , Ontario
I am his wife and I make up the beds and take them down! No taps or hits needed with the extra “O” rings. The tops just lift off. Easy pea set!
Old 06-13-2018, 03:04 PM   #7
2017 Basecamp
Kings Park , New York
I find it easier to remove the low table top with the post still screwed to the floor.
MrKenmore is offline   Reply With Quote
Old 06-17-2018, 07:32 AM   #8
Lmnhead's Avatar
2017 Basecamp
Decatur , Georgia
Im interested in trying the extra O-ring solution. Our Basecamp is in storage, so would someone be so kind to tell me what size O-rings to order (or post a link)?
Lmnhead is offline   Reply With Quote
Old 05-15-2019, 06:57 PM   #9
2003 34' Classic
Welland , Ontario
I ring on Basecamp table
Order the same size O ring that came with the trailer
Old 05-16-2019, 05:02 AM   #10
Lmnhead's Avatar
2017 Basecamp
Decatur , Georgia
Yeah, I posted that question 11 months ago and figured it out since. If anyone else is interested in trying out this solution, the product is 328 Silicone O-ring, 70A Durometer, 1 7/8" IN, 2 1/4" OD, 3/16" width.
We did not find that this solution was particularly helpful. The tabletops are still difficult to remove from the short legs. The extra O-ring maybe helps a little, but did not solve the problem in our case.
New Member, New Basecamp ABC004 Base Camp 63 10-29-2011 02:48 PM
Basecamp - $28,000us dufferin Base Camp 19 04-23-2008 03:07 PM
Basecamp Sighting! thecatsandi Base Camp 17 04-26-2006 09:14 AM
2007 Airstream Basecamp Trailer Colonial Airstream Commercial Listings 4 01-14-2006 09:59 AM
theVAP Episode 7: BaseCamp is here Safari Tim Our Community 0 12-08-2005 10:19 AM
