Old 11-05-2017, 04:34 PM   #1
2017 Basecamp
Preston , Washington
Base Camp Combi Drain Valve
Ok, it's winterization time and silly me I looked at the manual trying to locate the hot water heater drain valve for my Truma Combi. According to the manual and online tutorials it should look like this:
No no no. After much searching this is it, under the roadside bench just in from the Combi unit. The valve is shown in the "drain" position. I hope this helps other Base Camp owners with winterization.
Donn
Donnh is offline   Reply With Quote
Old 11-09-2017, 01:51 PM   #2
2017 Basecamp
Kings Park , New York
Thanks Donn. I'll be taking a swing at this tonight!
MrKenmore is offline   Reply With Quote
Old 11-10-2017, 11:50 AM   #3
2017 Basecamp
Have fun and let me know how it works out. I'm new to this and decided not to blow out the system with air and did not fill the pipes with antifreeze. I did dump antifreeze into the traps and drained the water pump. However, I live near Seattle and we don't get the hard freezes you probably would get. I grew up in WI so I understand freezing pipes and would probably winterize my BC differently if I lived there.
Old 11-10-2017, 12:59 PM   #4
2017 Basecamp
There is another thread where I run through what I did. I noticed in your pic AS used a different style connector for the pex piping. Interesting. I have odiker style clamps. Looks like you have compression connections. Is yours one of the early or later units?
Old 11-11-2017, 05:12 PM   #5
2017 Basecamp
Hmm, I bought it just a few months ago and it's listed as a 2017. So, newer?
Old 11-13-2017, 03:57 PM   #6
2017 Basecamp
McCall , Idaho
No I don't think so. I think you are looking at a shut off valve.
The drain valve looks just like the picture..at least on my BC
JumpJet is offline   Reply With Quote
Old 11-14-2017, 12:03 PM   #7
2017 Basecamp
It is a drain valve, I must have a different style then. I turned it and water ran out through a tube straight down to the outside.
Max incoming psi for Truma Combi water heater Bborzell Base Camp 3 06-09-2017 10:16 AM
Sterling Power Pro Combi S Pure Sine Wave Inverter Charger Don Diego Batteries, Univolts, Converters & Inverters 8 12-27-2013 06:16 AM
New Airstream Model -- Base Camp yukionna Base Camp 60 08-13-2005 05:07 AM
