Old 11-10-2017, 07:13 AM   #1
2018 Basecamp
Evanston , Illinois
Anti-sway, friction control bar?
We have a new basecamp airstream. We're pulling it with our Jeep Grand Cherokee. Any suggestion for which anti-sway or friction control bar to use?
Thank you for your help!
CamperGirls is offline   Reply With Quote
Old 11-10-2017, 07:40 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The design of friction sway bars is similar no matter who makes it. ON my 2 Airstreams I have 2 different friction bars. Both are bolted to the tongue. The Reese has a pretty hefty sleeve bolted to the frame which also controls the setting.
For my 2nd trailer I have a pretty generic sway bar, actually 2, They both attach to mounting points consisting of about 1" balls, one on the tongue and one on the hitch. They are more easily removable and less expensive than the Reese. The first one of these I got on eBay. I have had it for years but the ball sockets are a bit thin, I forgot this one on my last trip and bought one at Camping World. It was inexpensive and well made.
I would imagine on your basecamp you would use a pretty light setting. One consideration is being able to adjust the setting when hooked up. On my trailers the propane tanks get in the way of handle to adjust the setting
requiring setting tension before attaching the bar to the hitch, no big deal.
Friction Anti Sway Bar Supports Slip dbj216 Hitches, Couplers & Balls 27 09-27-2016 06:56 PM
Anti-Sway Bar or WD with Anti-Sway for 19' FC? CanonFan Towing, Tow Vehicles & Hitches 32 09-20-2016 05:29 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Sway Control - Old friction vs: New leverage & friction A W Warn Hitches, Couplers & Balls 43 07-14-2011 04:46 AM
Reese friction anti-sway bar broke Phantom Hitches, Couplers & Balls 18 11-28-2009 10:02 AM
