Old 02-27-2017, 10:19 PM   #1
Issaquah , Arkansas
Amazing First Trip But Not Much Hot Water...
Had an amazing first trip in the Basecamp. All went well but had issues getting the hot water to work well. Any ideas?
annebelle is offline   Reply With Quote
Old 02-28-2017, 04:32 AM   #2
Long Island , New York
Welcome to the forum! It will be helpful if you could provide more details. Were you using propane or electric to make hot water? Other propane appliances work OK, such as cook top burners? Furnace ignites and heats alright?
Were your batteries fully charged, and what was the battery voltage reading on your monitor panel?
If on shore power did other 120 volt items work?
Etc. etc.
Peter
PS does the Basecamp water heater even have a 120 volt heating element?
Old 02-28-2017, 06:57 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Please explain the situation more clearly.
Was there a problem with the water heater? (the water heater needs repair)
Or, was the water heater making plenty of hot water but there's not enough hot water flowing at the outlet? (the winterizing valves not reset to correct positions or the strainer screens at the shower and faucets may have trash in them blocking flow)
ps: don't forget to re-winterize the plumbing if your trailer will be exposed to freezing weather between now and your next camping trip.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 02-28-2017, 10:59 AM   #4
Rg416's Avatar
2019 22' Sport
Cohasset , Massachusetts
That's distressing. I haven't used it yet as we're waiting for our Basecamp delivery.
The Basecamp has a Truma Combi Eco Plus. It's supposed to be very good. Over 90% efficient and all that. It's a heating furnace and hot water heater combined in a small light package. The Plus models mean they can work on propane or electric, or a combination of both.
There is a small (5 gallon?) tank holding water, supposedly to give you hot water faster than a tankless on-demand water heater. I don't know if it maybe lacks the btu's to continue really hot water on demand once the tank runs out? (I have a tankless water heater at my house and it does a great job of producing hot water that never runs out like a tank. Downside is that it takes a gallon and a half or so to get hot. I now capture that water in a bucket to water plants.) There are some videos showing how to set/program the control panel. Check Truma's website.
There are various settings on the control pad, including a Boost mode for faster heating of the cabin or the water. And you can set a timer to have hot water ready before you get up.
I'd suggest asking your dealer why it's not working to your expectations. Maybe a Basecamp owner who has used it can explain the settings better.
Hope that helps a little.
Rich
Rg416 is offline   Reply With Quote
Old 02-28-2017, 11:27 AM   #5
2017 25' International
Framingham , Massachusetts
Winter bypass valve not turned off?
quietguy is offline   Reply With Quote
Old 02-28-2017, 01:40 PM   #6
2018 16' Sport
2018 16' Sport
Long beach , Mississippi
Did you have it set to Boost, and did you let it heat up 40 minutes or so.
jaz
Jazgrass is offline   Reply With Quote
Old 02-28-2017, 01:59 PM   #7
Box Elder (formerly of Center Moriches, NY) , South Dakota
Do you have an outside shower? If the outside shower valves are open, even though no water may be coming out, the fact that said valves ARE open can adversely affect water temps at other faucets.
NY24 is offline   Reply With Quote
Old 02-28-2017, 02:09 PM   #8
Rg416's Avatar
2019 22' Sport
The outside shower is just a pass through in the bathroom wall for the indoor handheld shower unit.
Old 02-28-2017, 04:32 PM   #9
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Wow, that's a lot of great suggestions! At this point it's probably worth waiting a bit to see what Annebelle has to say. As has been noted, more details will be very helpful to those who clearly want to offer her some good advice.
Rocinante is our 2014 International Signature 27FB
Old 02-28-2017, 09:47 PM   #10
Issaquah , Arkansas
Hi - thanks for the quick responses. Here is more detail - I had both propane and electric on and other appliances were working from both. There was just a little bit of hot water but then it ran out to cold. The furnace was working great and batteries were fully charged. My worry is that hot water is an issue if you are using the furnace (it was cold outside - 34 degrees). No strainers blocked as this was our first time out and the bypass was off. I tried Boost but no luck....I will check on the other things that were posted this weekend. Thanks!!
Old 03-01-2017, 12:09 AM   #11
Thanks for the updated details. The Basecamp has a new system which combines the functions of heating water and heating the interior air like a furnace. This is explained on p. 5-13 of the owner's manual [PDF p. 41/86]:
https://www.airstream.com/wp-content...ers-Manual.pdf
You should have a detailed instruction manual from the mfg. for the "Truma Combi CP Plus" unit. In particular, the AS manual page referenced above says:
__________________________________________________ ________
"1. Heating Mode - The furnace automatically selects the proper operating level based on the difference between the desired temperature set at the control panel and the current room temperature. If there is any water in the water container, it will be heated automatically. The water temperature will not be regulated, but it will reach a maximum of 162°F. [emphasis added]
"2. Hot Water Mode - Hot water mode is ideal if only hot water is required. The lowest burner setting suffices for heating water. In hot water mode, the burner will switch off as soon as the water reaches the temperature selected at the CP Plus Control Panel."
__________________________________________________ _________
There is an illustration of the control panel on the right side of the page. Apparently you can choose between the two modes above, and I am guessing that in the really cold weather, you were automatically in the "Heating Mode" because the unit sensed the cold interior temperature, and prioritized the propane energy to go to heating the interior air, and NOT the water.
Someone with more knowledge of this new system will have to fill in the details. Thanks for starting the discussion annebelle, as this is important info to have about the new Basecamp. A possible weak link in the design chain IMO, to have one unit replace the two traditional appliances of water heater and furnace.
Ah, compromises . . .
Good luck!
Peter
PS -- The mfg. manual is one of these, but I don't have time to find the right one [within the edit time window here]:
https://www.google.com/search?q=trum...utf-8&oe=utf-8
Old 03-01-2017, 05:37 AM   #12
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Does the Basecamp utilize the Alde system? If it does go to the Classic section in the forum's and select newest model years. Within that section you'll find literally hundreds of post on how to set the system up. If not Alde, I have no idea. Good luck
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-01-2017, 05:39 AM   #13
PS -- annebelle, after the BC interior has reached an acceptable temperature, you might try forcing the unit into Hot Water Mode, to see if you can get more hot water flowing. The mfg. suggests that this unit is almost like a "hot water on demand" system, so if you give it a few minutes to make hot water, it should give you plenty IMO.
Worth a try . . .
Old 03-01-2017, 05:41 AM   #14
See Post #11.
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot Water Not Hot wepply Sprinter and B-van Forum 12 10-19-2015 08:01 PM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
got water!!! but not hot..... turfclubroad Water Heaters, Filters & Pumps 6 09-10-2009 02:04 PM
Hot water to sink but not tub? ovrteakettle Water Heaters, Filters & Pumps 1 07-23-2009 01:07 AM
