Old 04-14-2017, 03:28 PM   #43
Long Island , New York
Thank you to Gail Miller for the resources linked below. On p. 8-13 etc. of the owner's manual, there are some notes on winterizing, and the valve being discussed in this thread is mentioned I think, but I don't see any photos or diagrams identifying it thoroughly. [PDF p. 76/86]
FWIW
Originally Posted by Gail Miller View Post
After I read that Airstream updates the owner's manual based on feedback, I found these on the Airstream website:
Parts Book:
https://www.airstream.com/wp-content...Parts-Book.pdf
Owners Manual: (Dated March 2017) (Mine is dated December 2016)
https://www.airstream.com/wp-content...ers-Manual.pdf
Old 04-17-2017, 07:17 AM   #44
2017 Basecamp
Kings Park , New York
Originally Posted by YardDog View Post
Working with Airstream now on troubleshooting my system. I was provided an updated plumbing drawing, I figured I would share so others can see how the bypass valve is tied into the system.
Thanks for making this drawing available to the forum. I like having detailed documents like this.
MrKenmore is offline   Reply With Quote
Old 04-17-2017, 11:56 AM   #45
2017 Basecamp
Conway , Arkansas
I wonder if that's a copyrighted drawing?? I added 'unlabeled valve?' to the drawing, via Photoshop.
Name:	Screen Shot 2017-03-14 at 6.05.02 PM.jpg
Gail Miller is offline   Reply With Quote
Old 04-18-2017, 09:06 AM   #46
Maybe the drawing is in the new manual or parts book you posted?
Old 04-18-2017, 11:54 AM   #47
2017 Basecamp
Conway , Arkansas
I do not see the drawing in the Owner's Manual, it is in the Parts Manual, but the valve is unlabeled.
Old 04-29-2017, 06:14 AM   #48
2017 Basecamp
Moultonborough , New Hampshire
Just took delivery of 2017 Basecamp.. appreciate all the good info on forum! We had same issue with bypass valve. Was left open so hot water would only last a few seconds then turn cold. Closed valve, but now there is no hot water pressure. We're hooked to a water supply at camp site. Any ideas?
AT34 is offline   Reply With Quote
Old 04-29-2017, 09:05 AM   #49
Warren , Pennsylvania
Any hot water in sink? Just a shower problem? Do you have cold water at both locations and just no hot? Pop drain valve on hot water tank to make sure it's filling up from your water supply.
Bogy4 is offline   Reply With Quote
Old 04-29-2017, 09:16 AM   #50
2017 Basecamp
No hot water in sink or shower. Just a trickle on hot setting. Cold is working.
Old 04-29-2017, 09:25 AM   #51
Have you reviewed Gail's drawing in Post #45? Apparently this plumbing schematic may be a newer version than what is in your owner's manual.
Near the label "Water Heater Connection" on the left center, there appear to be at least two valves just downstream of the heater in the red line:
1. at the top/start of the red line; and
2. a mixing valve (?) in the middle of the red vertical run (the round thing unlabeled).
I would make sure you have located each and every valve shown in the drawing. You still have a valve closed somewhere in my opinion.
Or, if that is indeed a mixing/tempering valve near the water heater -- to prevent scalding hot water from proceeding through the lines to the showers and faucets -- it may be defective. Here are the search results for "bad mixing valve" which would include other AS models and valves FYI:
https://www.google.com/search?q=bad+...=airforums.com
Good luck!
Peter
Old 04-29-2017, 09:38 AM   #52
2017 Basecamp
Thanks! I agree there is another valve issue. We will check. Chuck
Old 04-29-2017, 09:42 AM   #53
If you can find that mixing/tempering valve, I would just turn its adjusting knob back and forth a bunch of times. There may be crud in there, which manual changes will loosen. If you can hook up to city water and have the hot water running while you do this, it will help IMO. Even on just the pump you hopefully will get some action.
Good luck!
Peter
PS -- The Truma unit is both a furnace AND a water heater, isn't it? I would read their manual, and look for any additional valves etc. they talk about. Maybe there is a stuck or broken check valve inside the Truma unit? As you have probably seen, the earlier posts on this thread also talk about the Truma control panel and how to adjust for hot water. Probably not related to your current problem, but worth a check IMO.
Old 04-30-2017, 01:59 PM   #54
2017 Basecamp
Hot water working!
Yes, you were right, there was another valve in play. Patrick at Colonial Airstream helped us out.
The by pass valve (number 7 in the picture) was open when we picked up the B.C. We closed it after reading the thread. This does appear to be a valve that should be open during winterizing, but closed during normal use, or only cold water flows. We closed it, but then there was no water from hot faucet.
We then opened the valve labeled 8 in the attached picture. And hot water flowed like a dream! This valve is near the back under the triangle shaped cover in the seat next to the furnance.
Thanks everyone. I hope this helps.
Also, we only had the BC for one night..
ID:	284440   Click image for larger version
Old 04-30-2017, 02:02 PM   #55
2017 Basecamp
As I was saying, we only stayed one night in the BC and then we drove it from NJ to NH behind our Highlander. We love it. We did not encounter the problems noted in the threads, so maybe they have been addressed with the new shipments. Terry and Chuck
Old 04-30-2017, 03:23 PM   #56
Good news thanks for the update!
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot Water Not Hot wepply Sprinter and B-van Forum 12 10-19-2015 08:01 PM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
got water!!! but not hot..... turfclubroad Water Heaters, Filters & Pumps 6 09-10-2009 02:04 PM
Hot water to sink but not tub? ovrteakettle Water Heaters, Filters & Pumps 1 07-23-2009 01:07 AM
